    [Plugin] FredoTools::Convexify - v1.0 - 25 Feb 15
    28 Posts 9 Posters 25.0k Views 9 Watching
    • fredo6F
      Anton,
      Thanks for pointing to this bug.
      Actually, the correction is to replace line 1207 (an error of too quick copy / paste!)
      		#ledges = face.edges.sort { |e1, e2| e2.length <=> e1.length }
      		ledges = ledges.sort { |e1, e2| e2.length <=> e1.length }
      I'll fix and re-release, after looking at the Camel
        Anton_S
        Thanks. I was kind of wondering whether multiple convex shapes could be combined. The algorithm generates too much convex shapes for complex models. It would be nice to have a cleanup method which then combines final convex groups if they together are still a convex shape.
          I am disapointed that the Pilou's model is not a real solid! ๐Ÿ’š
          It should because it has an external closed skin! ๐Ÿ˜‰
          Sure internal is maybe some convoluted! ๐Ÿ˜„
          So next plug will be to tranform it in a real solid! ๐Ÿ˜‰
          In any way another Cristallographic task! ๐Ÿ˜ฒ ๐Ÿ‘ ๐Ÿ˜Ž
          • fredo6F
            Anton,
            This would be another type of decomposition (say a "blockify" method). Convexify does the job, and none of the small piรจces can be combined to form a bigger convex piece. In the camel, many of the mesh quads have a diagonal that is a concave edge.
            For collision, I guess that what you need is an approximate block decomposition that would be visually sufficient to give the impression of contact.
            • fredo6F
              Did you try Solid Inspector by thomthom. I think TIG also has a plugin for that.
                I will try that! ๐Ÿ˜„
                  dkluger
                  I am having a problem with Convexify. I am running SU15 Make. I have this tool on another computer and it runs seamlessly. I can't figure out why it won't work on this computer.
                  Running the tool seems to work at first where I get prompted to use the whole model (if nothing is selected) and then I can select the convex decomposition parameters. Once I click "OK" the green hour glass comes up, but then nothing happens. The second I move my mouse, the hour glass changes to a pointer as if nothing ever happened. Any clue to what's going on here?
                    meak
                    hello,
                    Unfortunately, I have exactly the same problem.
                    I work with pro skecthup 2015
                    • fredo6F
                      Thanks for signaling.
                      This is a bug introduced by LibFredo6 6.8. Sorry for inconvenience.
                      Please install LibFredo6 6.8c, now published on the PluginStore.
                        meak
                        speed and efficiency
                        a big applause
                        thank you a lot
                        is it possible to keep the exploded model?
                          Will be fine if we can exit with an actual position of the animation Explode Convexify colored view!
                          (with colors or not)
                          Or does exist a trick ?
                          (sure I can use other thing like Explode-view, Animator, ... but that give not the colors etc...
                            Seems there is a glitch!
                            Glitch_Convex_V6.skp
                            • gillesG
                              gilles
                              It's seems to be relative with angular tolerance.
                              • gillesG
                                gilles
                                But I may be wrongโ€ฆ
                                  Even more evident for 2 simple circles extruded! ๐Ÿ˜ฎ
                                  Dashed lines should be the good ones!
                                  • fredo6F
                                    Pilou,
                                    This is normal.
                                    The corresponding vertices of the inner and outer circles are not 'aligned', that is, the line joining two corresponding vertices does not go through the common center of the circles.
                                    This is a frequent issue when drawing co-centric circles. Because they are made of segments, it may important to keep them 'aligned'. I must say that the Circle tool does not help too much for that.
                                    If Convexify was 'following' your edges in the current model, the pieces would not be convex or would have to be divided in smaller chunks.
                                      That is some ennoyous! ๐Ÿ˜„
                                      So we must found a trick!
                                      Because make drawings with concentric Circles or Arc-circle are very commune! ๐Ÿค“
                                        Ok I found one ๐Ÿ˜„
                                        Drawing concentric circles on the same alignment! ๐Ÿ˜„
                                        here the red axe!
                                        PS Now if you can exit during the animation for keept the position of objects & colors
                                        that will be cool! ๐Ÿ˜„
