    [Plugin] FredoTools::Convexify - v1.0 - 25 Feb 15
    28 Posts 9 Posters 25.0k Views 9 Watching
    • cottyC
      cotty
      Very nice new tool for the great Fredo tools! Thank you!
      my SketchUp gallery
      • fredo6F
        @anton_s said:
        That's amazing! Thanks for great plugin.
        Do you mind if I try converting your algorithm to C++? Could be very useful for various physics engines.
        Anton
        Anton,
        That won't be easy from the code itself and anyway it heavily relies on Sketchup framework to describe geometry (faces, edges, etc....). The best is that I provide you with a short description of the algorithm which could be adapted to your geometrical frameworks in MSPhysics and underlying engine.
          Daniel S
          Hi Fredo!!!
          This plugin can make the decomposition of 3D shapes into "pyramidal" parts?
          Look at this:
          http://www.3ders.org/articles/20141211-pyramidal-shape-algorithm-removes-need-for-3d-print-material-support.html
          http://www.math.zju.edu.cn/ruizhenhu/projects/pym/pym_small.pdf
          Daniel S
          • fredo6F
            I am afraid this is a very different problem, much more complex actually.
            I imagine that if it does matter for 3D printing, then 3D Printing software editors would have embedded this capability in their applications.
              Anton_S
              Thank you Fredo. It seems complicated, but I'm fairly sure its possible to put together a C extension out of this. I'll look into the source and try to break it down. Otherwise, I could stick with Ruby-SketchUp implementation.
              Thanks again,
              Anton
                Anton_S
                I decided to do a little test and got a generation error with that camel, which I got at 3dwarehouse.
                Date: 27-Feb-15 01:54:52
                An error occurred in Convexify 3D Shapes
                Error while processing Convexify
                wrong argument type (expected Sketchup::Face)
                body_Lib6Solid.rb: 1212 -- reversed_in?
                body_Lib6Solid.rb: 1212 -- block in solid_transfer_section_faces
                body_Lib6Solid.rb: 1205 -- each
                body_Lib6Solid.rb: 1205 -- solid_transfer_section_faces
                body_Lib6Solid.rb: 1034 -- solid_split
                body_Lib6Solid.rb: 909 -- solid_split_robot
                body_Lib6Solid.rb: 560 -- robot_execute_protected
                body_Lib6Solid.rb: 506 -- robot_execute
                body_Lib6Solid.rb: 482 -- block in convexify
                Lib6Operation.rb: 325 -- call
                Lib6Operation.rb: 325 -- step_geometry
                Lib6Operation.rb: 286 -- block in yield?
                SketchUp: 1 -- call
                Generation Options:
                Put the Convex shapes on LAYER: Fredo6_Convexify
                Tolerance Concavity: 0 deg.
                Animation algorithm: NO
                A bit different error shows up when I generate with Animation set to 0.2s.
                Edit: Adding next if edge0.faces.size != 2 to body_lib6Solid.rb, line 1210 (after break unless edge0) seems to fix that initial error, and generate convex decomposition without problems. However, changing tolerance makes a different error to appear. Maybe you could look into it if you have time...
                camel.skp
                • fredo6F
                  Anton,
                  Thanks for pointing to this bug.
                  Actually, the correction is to replace line 1207 (an error of too quick copy / paste!)
                  		#ledges = face.edges.sort { |e1, e2| e2.length <=> e1.length }
                  		ledges = ledges.sort { |e1, e2| e2.length <=> e1.length }
                  I'll fix and re-release, after looking at the Camel
                    Anton_S
                    Thanks. I was kind of wondering whether multiple convex shapes could be combined. The algorithm generates too much convex shapes for complex models. It would be nice to have a cleanup method which then combines final convex groups if they together are still a convex shape.
                      I am disapointed that the Pilou's model is not a real solid! 💚
                      It should because it has an external closed skin! 😉
                      Sure internal is maybe some convoluted! 😄
                      So next plug will be to tranform it in a real solid! 😉
                      In any way another Cristallographic task! 😲 👍 😎
                      • fredo6F
                        Anton,
                        This would be another type of decomposition (say a "blockify" method). Convexify does the job, and none of the small pièces can be combined to form a bigger convex piece. In the camel, many of the mesh quads have a diagonal that is a concave edge.
                        For collision, I guess that what you need is an approximate block decomposition that would be visually sufficient to give the impression of contact.
                        • fredo6F
                          Did you try Solid Inspector by thomthom. I think TIG also has a plugin for that.
                            I will try that! 😄
                              dkluger
                              I am having a problem with Convexify. I am running SU15 Make. I have this tool on another computer and it runs seamlessly. I can't figure out why it won't work on this computer.
                              Running the tool seems to work at first where I get prompted to use the whole model (if nothing is selected) and then I can select the convex decomposition parameters. Once I click "OK" the green hour glass comes up, but then nothing happens. The second I move my mouse, the hour glass changes to a pointer as if nothing ever happened. Any clue to what's going on here?
                                meak
                                hello,
                                Unfortunately, I have exactly the same problem.
                                I work with pro skecthup 2015
                                • fredo6F
                                  Thanks for signaling.
                                  This is a bug introduced by LibFredo6 6.8. Sorry for inconvenience.
                                  Please install LibFredo6 6.8c, now published on the PluginStore.
                                    meak
                                    speed and efficiency
                                    a big applause
                                    thank you a lot
                                    is it possible to keep the exploded model?
                                      Will be fine if we can exit with an actual position of the animation Explode Convexify colored view!
                                      (with colors or not)
                                      Or does exist a trick ?
                                      (sure I can use other thing like Explode-view, Animator, ... but that give not the colors etc...
                                        Seems there is a glitch!
                                        Glitch_Convex_V6.skp
                                        • gillesG
                                          gilles
                                          It's seems to be relative with angular tolerance.
                                          • gillesG
                                            gilles
                                            But I may be wrong…
