    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 447.6k Views 114 Watching
    • KrisidiousK Offline
      Krisidious
      there are a few exploded view type plugins... I forget the names.
      By: Kristoff Rand
      • ashscottA Offline
        ashscott
        Yeah I have used them, my problem is that layout doesn't seem to recognize their geometry positions unless I save a scene for every single position (like tweens from Keyframe Animation) which is super slow and confusing.
        I just wondered if anyone had a more efficient hack for this
        Just some stuff I do with Sketchup.
          Krisidious
          None of them make the scene for you? I thought they did. made the blown up version and done version.
          By: Kristoff Rand
          • ashscottA Offline
            ashscott
            Oh perhaps they do. I just haven't seen one that translates those positions to layout - layout seems to only be able to read on position of the geometry for each sketchup file.
            Can you remember which plugins you had seen?
              Krisidious
              A have a few ...
              (www.smustard.com)
              http://sketchucation.com/forums/viewtopic.php?t=24390
              Dave has a tut on it.
              (www.finewoodworking.com)
              By: Kristoff Rand
              • ashscottA Offline
                ashscott
                Both great tools, but layout doesn't recognize the geometry positions
                  Krisidious
                  what? it doesn't? you're saying you have a scene with the geometry blown up with the plugin and ;layout won't show it as blown up? share the model?
                  By: Kristoff Rand
                  • bmikeB Offline
                    bmike
                    no plugins, but I use my model and then either pull it apart and save scenes, or if i need multiple views use scenes and layers, to keep the camera in the same location. the problem i had with the plugin(s?) i tried was that i always needed to tweak the 'explode' distance depending on the view and the part... if i had to manually adjust them anyways it made sense just to do it by hand.
                    but that could be tedious if you have lots of products to illustrate.
                    • ashscottA Offline
                      ashscott
                      I think we might be missing each other's points. If I have geometry in unexploded position and create scene 1, it will register the geometry in the position. If I then explode that geometry and create scene 2 the geometry will now be registered in the exploded position. If I go back to scene 1 my geometry can switch back (if I've used the right plugins). But when I send that file to layout the geometry is in the same position for both scenes.
                      Yeah, I was hoping to avoid this πŸ˜•
                        sonder
                        In case anyone is interested, Trimble came to my office and did an in depth series that will be highlighted in much more detail in the upcoming book I'm co-authoring with Matt Donley.
                        http://www.youtube.com/playlist?list=PL-bndkJaV8A6tVUVIlqFHMAcodO8aATrh
                        • ashscottA Offline
                          ashscott
                          This is great work Nick. Thanks very much.
                          I've been working my way through a set of mechanical engineering working drawings and have been surprised how few plugins I really need once I get a good process organized.
                          I recently heard someone referring to the programming language PHP as "messy" and someone replied that PHP isn't messy but is accessible which means that learners can use it fast and as a result can make a mess but once you know how to use it properly you can do amazing things with it (Facebook runs on PHP).
                          I feel that Sketchup falls into this category - there is a lot of messy stuff done with SU because it is so accessible (which is great because the barrier to entry is so low) but once you really know how to use it you can create attractive, tidy, practical work.
                          Nick, you have demonstrated this last point to me many times - thanks.
                          EDIT: Added the first video for to get people started.
                          • jujuJ Offline
                            juju
                            excellent! Thanks for the video link...
                            now stop wasting time on the internet and finish the book already, take my money dammit!
                            • JasonWDJ Offline
                              JasonWD
                              I would be super interested to know if you find a solution to this...
                              I have always been in a position that I need to get drawings out so fast that I just do it the manual way!
                              Normally my furniture drawings have a Furniture_exploded.skp file next to them that I pull all the elements of the model out (for instance) 500mm to get the right look.
                              Explode example
                              Also this kind of thing (can't find the layout file it is attached to). Odd that it has notes in SU for me!
                              SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                                driven
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
                                hi jason, have you tried this one...
                                • JasonWDJ Offline
                                  JasonWD
                                  (sketchucation.com)
                                  I havn't for a while, but yes!
                                  I think the problem is I like to show exploded stuff in Perspective and that creates challenges for seeing everything nicely in the explosion.
                                  The most annoying thing is that it interrupts my workflow because it makes you have another copy of the SU geometry in a separate file just for the explosion
                                    sonder
                                    (sketchucation.com)
                                    Rather than creating a separate file, why not just copy and create a separate group for the expoded view and set that on its own layer; then create the "exploded scene". That way, if each element is a component, you only have to modify once, in a single file.
                                    • JasonWDJ Offline
                                      JasonWD
                                      I think this came about because there were so many LayOut critical scenes in the SU file that if I created a new layer I would have to Update all the scenes with that new layer off. That's my excuse anyway!
                                      • pbacotP Offline
                                        Yeah that's tough, but now you can use the addlayer plugin for those situations.
                                          AirWindSolar
                                          This. Not sure why they won't give an option to have new layers default to off in all scenes, since 99 times out of 100, I'm creating the layer specifically so I can have something show in only one scene. Would be a lot easier to turn it on in that scene than go through all the others turning it off.
                                          And while we're on dumb behaviors, who had the drug addled idea that "save draft" should be the leftmost and most visible button?
                                          • JasonWDJ Offline
                                            JasonWD
                                            When I'm working away in solitude I assume I'm being an idiot and there is a good reason for things being the way they are so just go with the flow and bodge it.
                                            It's nice to know others have the same problems πŸ˜„
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
