    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 489.1k Views 114 Watching
    • TommyKT Offline
      TommyK
      @rhciv said:
      I think one of the biggest issues was pixelated lines when printing. This seems to be fixed with rendering the layer before taking to print. Has anyone else had success CD'ing homes to working drawings using only SU & LO? I am using the PRO Trial to see if I can upgrade.
      If the scene that you are trying to render is relatively simple, you can use the "Vector" rendering option on a per scene basis. Vector rendering mode, I believe, outputs vector PDF drawings, so should eliminate any pixelations. This is perfect for construction drawings, where textures are not required. The exported PDF also has the benefit of being smaller in file size. If you need to use complex styles or transparent materials, you should also have decent success with the "Hybrid" mode.
      Having said all that, I don't tend to get any issues in "Raster" (the standard) mode, if I output the PDF in "High" resolution setting.
      I am planning to go completely SU and LO for my next extension project with my CDs. I am planning to use Skalp for detailed sections. Although it's not even out yet, I am completely won over by their videos!
        bulbangs
        Hi everyone, i'm new to using layout to make CDs. Forgive me if this has been asked.
        I'm having trouble when inserting sketchup models into layout. I find that corners are rounded rather than sharp.
        I can draw a box within layout with sharp corners, but i can't seem to find any way to make the corners of inserted models not rounded.
        see image below:
        http://i.imgur.com/WQ0wmIq.png
        thanks in advance
        • zx10r_GazZ Offline
          zx10r_Gaz
          I have tried to replicate this and found if I changed the output to Raster it seems to have done the trick. Unfortunately the lineweight has been lost, but I'm not sure if this is the correct way to go about it as I have been off SU for a long long while now.
          Gaz...
          https://onedrive.live.com/redir?resid=CDDA6035F78C1761!2047&authkey=!AIo4el-_oBPTjwY&v=3&ithint=photo%2C.jpg
            bulbangs
            see image below:
            thanks in advance
            changing from raster to vector or hybrid sharpens the line quality but does nothing though to achieve what i want: namely, sharp, 90degree corners that aren't rounded.. =(
            anyone have any other tips?
            • KrisidiousK Offline
              Krisidious
              make sure that all objects have the correct or desired shape style settings.
              By: Kristoff Rand
                Charlie__V
                I had not noticed this before(unfortunately I do not have an answer).......you appear to be very close up in the attached image........are you creating documents at that scale?
                Obviously the smaller the scale the less likely one will notice the rounded corners.
                Also...It appears (at leat to me)it is related to the pen settings.
                IOW.....in an exported .pdf.......if I turn the display pen settings off...the lines are crisp 90°........I know......Still does not help you.
                C
                • pbacotP Offline
                  It doesn't look like the shape dialog will help with ports. (this deserves a LO thread-not related to this topic). The SU references all appear to have round endcaps. I think the mention of raster is because raster pixelates the lines so they look squarish.
                  The only way to square it would be to explode the port so the elements become LO linework which defeats the SU-LO link.
                  • TandemT Offline
                    Tandem
                    So where is the documentation when you need it?
                    I think bulbangs' question does very much belong to this thread as controlling lines in LayOut is at the core of creating construction drawings.
                    What is the correct workflow? I tried to search the SU Knowledge Base and have to yet find anything there that covers this topic.
                    A detailed Reference Manual for SU and LO (preferably in PDF) would be very helpful and save everyone a lot of time. I am getting very tired of scouring the web for tidbits of information that should be properly documented by Sketchup.
                    </rant>
                    • bmikeB Offline
                      bmike
                      yeah, but buried in here, 14 pages deep, few people, including the SU team, will ever see it.
                      this should be asked in a new thread, and maybe reported as a bug.
                      • TandemT Offline
                        Tandem
                        You are right, plus the goal of the OP was to see/show examples of drawings. Sorry, the title throw me off. 😳
                        • ashscottA Offline
                          ashscott
                          I'm currently working on a project for a kitset company doing some assembly instructions. They have previously just used jpegs from SU to show the parts of the kitset apart so that the user can understand how they fit together but this seems like a frustratingly slow way of doing things. Has anyone managed to do this kind of thing in layout showing parts in different positions based on SU scenes etc?
                          I tried this a long time ago with proper animation but layout couldn't recognize the animated part positions.
                          Any clever ideas are much appreciated
                          Just some stuff I do with Sketchup.
                            Krisidious
                            there are a few exploded view type plugins... I forget the names.
                            By: Kristoff Rand
                            • ashscottA Offline
                              ashscott
                              Yeah I have used them, my problem is that layout doesn't seem to recognize their geometry positions unless I save a scene for every single position (like tweens from Keyframe Animation) which is super slow and confusing.
                              I just wondered if anyone had a more efficient hack for this
                                Krisidious
                                None of them make the scene for you? I thought they did. made the blown up version and done version.
                                By: Kristoff Rand
                                • ashscottA Offline
                                  ashscott
                                  Oh perhaps they do. I just haven't seen one that translates those positions to layout - layout seems to only be able to read on position of the geometry for each sketchup file.
                                  Can you remember which plugins you had seen?
                                    Krisidious
                                    A have a few ...
                                    File Not Found
                                    (www.smustard.com)
                                    404 Not Found
                                    (sketchucation.com)
                                    Dave has a tut on it.
                                    http://www.finewoodworking.com/item/40810/making-exploded-views
                                    By: Kristoff Rand
                                    • ashscottA Offline
                                      ashscott
                                      Both great tools, but layout doesn't recognize the geometry positions
                                        Krisidious
                                        what? it doesn't? you're saying you have a scene with the geometry blown up with the plugin and ;layout won't show it as blown up? share the model?
                                        By: Kristoff Rand
                                        • bmikeB Offline
                                          bmike
                                          no plugins, but I use my model and then either pull it apart and save scenes, or if i need multiple views use scenes and layers, to keep the camera in the same location. the problem i had with the plugin(s?) i tried was that i always needed to tweak the 'explode' distance depending on the view and the part... if i had to manually adjust them anyways it made sense just to do it by hand.
                                          but that could be tedious if you have lots of products to illustrate.
                                          • ashscottA Offline
                                            ashscott
                                            I think we might be missing each other's points. If I have geometry in unexploded position and create scene 1, it will register the geometry in the position. If I then explode that geometry and create scene 2 the geometry will now be registered in the exploded position. If I go back to scene 1 my geometry can switch back (if I've used the right plugins). But when I send that file to layout the geometry is in the same position for both scenes.
                                            Yeah, I was hoping to avoid this 😕
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
