    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 473.8k Views 114 Watching
      caronte01
      Hey all.
      I've been watching this thread for a while, trying to develop my su/layout workflow based on what' i've seen here and elsewhere. I've produced 1 full set of cd and 2.5 set of permit drawings using su/lo so far. Getting better all the time. I have a scrapbook based on my drawing standards.
      I write to tell others about the latest plugin I've found.
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072 rich sections
      Some may be familiar with it, but for thoses who are not, please try it. It makes the process of creating section faces almost automatic, and hatch materials are based on layer or material. Please give it a look. The setup process may seem a bit cumbersome, but it is not, it's just a matter of creating some additional materials. It has improved my workflow immensely.
      Btw, I'm not being payed by pgarmyn 😆 it is just that good!
      Santiago
        rhciv
        Hello SU Pros! I'm all new here and stuff!!
        I have found so much great info on this forum. After reviewing this thread there seems to have been a dry-spell where everybody all but gave up on the LO idea. I attempted to build construction docs in LO back with version 6 and found the wall at some point on every project. I have seen the work displayed lately and am feeling enthusiastic that SU may have overcome the barriers that broke the process for me.
        I think one of the biggest issues was pixelated lines when printing. This seems to be fixed with rendering the layer before taking to print. Has anyone else had success CD'ing homes to working drawings using only SU & LO? I am using the PRO Trial to see if I can upgrade.
        • TommyKT Offline
          TommyK
          If the scene that you are trying to render is relatively simple, you can use the "Vector" rendering option on a per scene basis. Vector rendering mode, I believe, outputs vector PDF drawings, so should eliminate any pixelations. This is perfect for construction drawings, where textures are not required. The exported PDF also has the benefit of being smaller in file size. If you need to use complex styles or transparent materials, you should also have decent success with the "Hybrid" mode.
          Having said all that, I don't tend to get any issues in "Raster" (the standard) mode, if I output the PDF in "High" resolution setting.
          I am planning to go completely SU and LO for my next extension project with my CDs. I am planning to use Skalp for detailed sections. Although it's not even out yet, I am completely won over by their videos!
            bulbangs
            Hi everyone, i'm new to using layout to make CDs. Forgive me if this has been asked.
            I'm having trouble when inserting sketchup models into layout. I find that corners are rounded rather than sharp.
            I can draw a box within layout with sharp corners, but i can't seem to find any way to make the corners of inserted models not rounded.
            see image below:
            http://i.imgur.com/WQ0wmIq.png
            thanks in advance
            • zx10r_GazZ Offline
              zx10r_Gaz
              I have tried to replicate this and found if I changed the output to Raster it seems to have done the trick. Unfortunately the lineweight has been lost, but I'm not sure if this is the correct way to go about it as I have been off SU for a long long while now.
              Gaz...
              https://onedrive.live.com/redir?resid=CDDA6035F78C1761!2047&authkey=!AIo4el-_oBPTjwY&v=3&ithint=photo%2C.jpg
                bulbangs
                see image below:
                thanks in advance
                changing from raster to vector or hybrid sharpens the line quality but does nothing though to achieve what i want: namely, sharp, 90degree corners that aren't rounded.. =(
                anyone have any other tips?
                • KrisidiousK Offline
                  Krisidious
                  make sure that all objects have the correct or desired shape style settings.
                  By: Kristoff Rand
                    Charlie__V
                    I had not noticed this before(unfortunately I do not have an answer).......you appear to be very close up in the attached image........are you creating documents at that scale?
                    Obviously the smaller the scale the less likely one will notice the rounded corners.
                    Also...It appears (at leat to me)it is related to the pen settings.
                    IOW.....in an exported .pdf.......if I turn the display pen settings off...the lines are crisp 90°........I know......Still does not help you.
                    C
                    • pbacotP Offline
                      It doesn't look like the shape dialog will help with ports. (this deserves a LO thread-not related to this topic). The SU references all appear to have round endcaps. I think the mention of raster is because raster pixelates the lines so they look squarish.
                      The only way to square it would be to explode the port so the elements become LO linework which defeats the SU-LO link.
                      • TandemT Offline
                        Tandem
                        So where is the documentation when you need it?
                        I think bulbangs' question does very much belong to this thread as controlling lines in LayOut is at the core of creating construction drawings.
                        What is the correct workflow? I tried to search the SU Knowledge Base and have to yet find anything there that covers this topic.
                        A detailed Reference Manual for SU and LO (preferably in PDF) would be very helpful and save everyone a lot of time. I am getting very tired of scouring the web for tidbits of information that should be properly documented by Sketchup.
                        </rant>
                        • bmikeB Offline
                          bmike
                          yeah, but buried in here, 14 pages deep, few people, including the SU team, will ever see it.
                          this should be asked in a new thread, and maybe reported as a bug.
                          • TandemT Offline
                            Tandem
                            You are right, plus the goal of the OP was to see/show examples of drawings. Sorry, the title throw me off. 😳
                            • ashscottA Offline
                              ashscott
                              I'm currently working on a project for a kitset company doing some assembly instructions. They have previously just used jpegs from SU to show the parts of the kitset apart so that the user can understand how they fit together but this seems like a frustratingly slow way of doing things. Has anyone managed to do this kind of thing in layout showing parts in different positions based on SU scenes etc?
                              I tried this a long time ago with proper animation but layout couldn't recognize the animated part positions.
                              Any clever ideas are much appreciated
                              Just some stuff I do with Sketchup.
                                Krisidious
                                there are a few exploded view type plugins... I forget the names.
                                By: Kristoff Rand
                                • ashscottA Offline
                                  ashscott
                                  Yeah I have used them, my problem is that layout doesn't seem to recognize their geometry positions unless I save a scene for every single position (like tweens from Keyframe Animation) which is super slow and confusing.
                                  I just wondered if anyone had a more efficient hack for this
                                    Krisidious
                                    None of them make the scene for you? I thought they did. made the blown up version and done version.
                                    By: Kristoff Rand
                                    • ashscottA Offline
                                      ashscott
                                      Oh perhaps they do. I just haven't seen one that translates those positions to layout - layout seems to only be able to read on position of the geometry for each sketchup file.
                                      Can you remember which plugins you had seen?
                                        Krisidious
                                        A have a few ...
                                        File Not Found
                                        (www.smustard.com)
                                        404 Not Found
                                        (sketchucation.com)
                                        Dave has a tut on it.
                                        http://www.finewoodworking.com/item/40810/making-exploded-views
                                        By: Kristoff Rand
                                        • ashscottA Offline
                                          ashscott
                                          Both great tools, but layout doesn't recognize the geometry positions
                                            Krisidious
                                            what? it doesn't? you're saying you have a scene with the geometry blown up with the plugin and ;layout won't show it as blown up? share the model?
                                            By: Kristoff Rand
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
