    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 519.0k Views 114 Watching
    • ashscottA
      ashscott
      there are a few exploded view type plugins... I forget the names.
      Yeah I have used them, my problem is that layout doesn't seem to recognize their geometry positions unless I save a scene for every single position (like tweens from Keyframe Animation) which is super slow and confusing.
      I just wondered if anyone had a more efficient hack for this
      Just some stuff I do with Sketchup.
      • KrisidiousK
        Krisidious
        None of them make the scene for you? I thought they did. made the blown up version and done version.
        By: Kristoff Rand
        • ashscottA
          ashscott
          Oh perhaps they do. I just haven't seen one that translates those positions to layout - layout seems to only be able to read on position of the geometry for each sketchup file.
          Can you remember which plugins you had seen?
          • KrisidiousK
            Krisidious
            A have a few ...
            File Not Found
            (www.smustard.com)
            404 Not Found
            (sketchucation.com)
            Dave has a tut on it.
            http://www.finewoodworking.com/item/40810/making-exploded-views
            By: Kristoff Rand
            • ashscottA
              ashscott
              Both great tools, but layout doesn't recognize the geometry positions
              • KrisidiousK
                Krisidious
                what? it doesn't? you're saying you have a scene with the geometry blown up with the plugin and ;layout won't show it as blown up? share the model?
                By: Kristoff Rand
                • bmikeB
                  bmike
                  no plugins, but I use my model and then either pull it apart and save scenes, or if i need multiple views use scenes and layers, to keep the camera in the same location. the problem i had with the plugin(s?) i tried was that i always needed to tweak the 'explode' distance depending on the view and the part... if i had to manually adjust them anyways it made sense just to do it by hand.
                  but that could be tedious if you have lots of products to illustrate.
                  • ashscottA
                    ashscott
                    I think we might be missing each other's points. If I have geometry in unexploded position and create scene 1, it will register the geometry in the position. If I then explode that geometry and create scene 2 the geometry will now be registered in the exploded position. If I go back to scene 1 my geometry can switch back (if I've used the right plugins). But when I send that file to layout the geometry is in the same position for both scenes.
                    Yeah, I was hoping to avoid this πŸ˜•
                      sonder
                      In case anyone is interested, Trimble came to my office and did an in depth series that will be highlighted in much more detail in the upcoming book I'm co-authoring with Matt Donley.
                      http://www.youtube.com/playlist?list=PL-bndkJaV8A6tVUVIlqFHMAcodO8aATrh
                      • ashscottA
                        ashscott
                        This is great work Nick. Thanks very much.
                        I've been working my way through a set of mechanical engineering working drawings and have been surprised how few plugins I really need once I get a good process organized.
                        I recently heard someone referring to the programming language PHP as "messy" and someone replied that PHP isn't messy but is accessible which means that learners can use it fast and as a result can make a mess but once you know how to use it properly you can do amazing things with it (Facebook runs on PHP).
                        I feel that Sketchup falls into this category - there is a lot of messy stuff done with SU because it is so accessible (which is great because the barrier to entry is so low) but once you really know how to use it you can create attractive, tidy, practical work.
                        Nick, you have demonstrated this last point to me many times - thanks.
                        EDIT: Added the first video for to get people started.
                        • jujuJ
                          juju
                          excellent! Thanks for the video link...
                          now stop wasting time on the internet and finish the book already, take my money dammit!
                          • JasonWDJ
                            JasonWD
                            I would be super interested to know if you find a solution to this...
                            I have always been in a position that I need to get drawings out so fast that I just do it the manual way!
                            Normally my furniture drawings have a Furniture_exploded.skp file next to them that I pull all the elements of the model out (for instance) 500mm to get the right look.
                            Explode example
                            Also this kind of thing (can't find the layout file it is attached to). Odd that it has notes in SU for me!
                            SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                              driven
                              404 Not Found
                              (sketchucation.com)
                              hi jason, have you tried this one...
                              • JasonWDJ
                                JasonWD
                                @driven said:
                                404 Not Found
                                (sketchucation.com)
                                I havn't for a while, but yes!
                                I think the problem is I like to show exploded stuff in Perspective and that creates challenges for seeing everything nicely in the explosion.
                                The most annoying thing is that it interrupts my workflow because it makes you have another copy of the SU geometry in a separate file just for the explosion
                                  sonder
                                  @jasonwd said:
                                  @driven said:
                                  404 Not Found
                                  (sketchucation.com)
                                  Rather than creating a separate file, why not just copy and create a separate group for the expoded view and set that on its own layer; then create the "exploded scene". That way, if each element is a component, you only have to modify once, in a single file.
                                  • JasonWDJ
                                    JasonWD
                                    I think this came about because there were so many LayOut critical scenes in the SU file that if I created a new layer I would have to Update all the scenes with that new layer off. That's my excuse anyway!
                                    • pbacotP
                                      Yeah that's tough, but now you can use the addlayer plugin for those situations.
                                        AirWindSolar
                                        This. Not sure why they won't give an option to have new layers default to off in all scenes, since 99 times out of 100, I'm creating the layer specifically so I can have something show in only one scene. Would be a lot easier to turn it on in that scene than go through all the others turning it off.
                                        And while we're on dumb behaviors, who had the drug addled idea that "save draft" should be the leftmost and most visible button?
                                        • JasonWDJ
                                          JasonWD
                                          When I'm working away in solitude I assume I'm being an idiot and there is a good reason for things being the way they are so just go with the flow and bodge it.
                                          It's nice to know others have the same problems πŸ˜„
                                            malo8x
                                            Hi All
                                            Sorry if this question has been asked
                                            I am using LO for construction drawings, I have some strip Windows which are at higher level than the doors. Hence the section plane can't cut through those windows and I can't see them on the plan. Does anyone have any tip or any way to solve Thi issue. Thanks
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 21 / 23
