    How do I precisely place a material on a tube?
    14 Posts 7 Posters 1.0k Views 7 Watching
    • oceanembersO
      oceanembers
      Search on the plugin store for the term "UV".
      There are a number of plugins, most of which will help you to do this, to do with UV layout and texture projection - sketchup's own capabilities in this regard are unfortunately lacking, to say the least.
      • FrederikF
        Frederik
        @oceanembers said:
        ...sketchup's own capabilities in this regard are unfortunately lacking, to say the least.
        Although I agree that SU lack better UV tools, you can easily do this by projecting textures, without the need of any extra plugins to learn... πŸ˜‰
        I've attached the 'skippy' to take some learnings from...
        Turn the layers on and off to see how the textures are made and how you place them precisely as you're asking to do...
        Hope this will help you further!
        Projected-texture-test.skp
        Cheers
        Kim Frederik
        • genma saotomeG
          genma saotome
          Kim, I downloaded your model and took a look and yes, the results are what I'm looking for... but I cannot yet replicate what you did. I see you used the UV plugin... when I try that the results are never right... either the texture gets angled down as it runs along the long axis or is all broken up by the faces of the tube.
          Is there something I'm missing (besides my unfamiliarity with the UV tool)?
          Oh, one more thing: Your use of the word projection... I do know the word of course but as used in your sentence I was not sure if you meant it to refer to a specific SU or Plug-In function or not..
            This was done like Frederick described without plugins.
            When I need to do this sort of thing, I put the texture on a flat surface aligned with where I want the texture and then sample it and apply it on the curved surface. Projection is a setting for the texture. Not a plugin.
              ThruPaint by Fredo6 don't help in any of this ?
              • FrederikF
                Frederik
                No... As Dave R already wrote, I haven't used any plugins...!
                This was done straight in SU, where I projected the textures...
                It's in the sub-menu if you right-click on a texture and select "Texture"... πŸ˜„
                I've attached a screen capture, which should explain this better...
                I've attached a pdf-document with a small tutorial, which explain things...
                Hopefully this will make it more clear...!?
                Projected-texture-tutorial.pdf
                Cheers
                Kim Frederik
                • FrederikF
                  Frederik
                  Small tutorial uploaded in the above post...
                  Cheers
                  Kim Frederik
                  • oceanembersO
                    oceanembers
                    Projection will cause distortion at the extremities of the cylinder, so it maybe isn't the best idea for any graphics/decals that aren't decently central, unless you want to start sectioning off areas for different projections. Other than that, yeah projection will work in OP's instance, it was probably overkill for me to suggest UV tools.
                    • ntxdaveN
                      ntxdave
                      Here is an excellent (IMHO) tutorial on projecting a texture onto a curved surface: https://www.youtube.com/watch?v=HHsRRLCAOm8
                      Press F1...thank me later
                      • FrederikF
                        Frederik
                        Working with one of the UV plugins would indeed be the best and most accurate approach - no doubt...
                        However, although the OP have set his SU experience to advanced, he seem to have limited knowledge about UV and how it works - as far as I can tell - hence I suggested the projection approach before jumping into more complex plugins and ways to apply textures on cylinder shapes...
                        You need to learn how to crawl before you know how to walk... πŸ˜‰
                        Cheers
                        Kim Frederik
