    Sync Plugins & toolbars between multiple computers?
    12 Posts 4 Posters 1.1k Views 4 Watching
      You can use the Sketchucation Plugin Store to create and manage bundles of plugins so you can have identical plugin installations between machines. There isn't any way to export toolbar locations from one SU install to another but once you set them up, you shouldn't have to change them. When I need to set up another machine with my toolbar locations, I make a screen shot of the first and import that as an image into the other SU installation so I have it as a reference while setting up the toolbars.
      • maxhouserocksM
        maxhouserocks
        oh great. i was not aware of that functionality. do you recommend that over the dropbox method?
        yeah, i have used a screen shot too. sure wish there was a ui file to save and load. oh well. thanks for the quick response!
        bob
        Robert A. Christman
        http://rachristman.blogspot.com/
          Yes. the SCF Plugin Store tool is a much better way to manage your plugins. Besides, it gives you direct access to hundreds of plugins/extensions and auto installs them. Dropbox won't do that for you.
          • maxhouserocksM
            maxhouserocks
            i have been using it for installs...brilliant!
            looking at managing capabilities now.
            Robert A. Christman
            • BoxB
              One small thing to note, Plugins from other sources won't be included in Bundles. It can only recognise ones you have downloaded through the Sketchcation tool.
              You'll find a handy tutorial for bundles here.
              http://sketchucation.com/resources/tutorials/beginner/1147-use-pluginstore-bundles-to-sync-your-extensions-in-sketchup
                Yet.... πŸ˜‰
                • BoxB
                  I ummed and arred about saying yet.
                  • maxhouserocksM
                    maxhouserocks
                    ah, i see. thanks again for all of the info.
                    Robert A. Christman
                    • maxhouserocksM
                      maxhouserocks
                      there are several threads on this issue now and i just realized i never posted my solution to using dropbox as a source for plugins to enable synchronization between multiple machines.
                      i have it listed in detail here:
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58948%26amp;p=569678#p569678
                      Robert A. Christman
                        Or you can create a plugin bundle using the SCF Plugin Store tool and use that to synchronize plugins between computers and automatically install the plugins as needed. AND you can use it to check for updated plugins, create customized load sets and more.
                        • maxhouserocksM
                          maxhouserocks
                          Dave, is there still an issue with that not working with plugins from other sources?
                          Robert A. Christman
