    Is there pluging for expanding/making face along line/edges?
    41 Posts 12 Posters 4.5k Views 12 Watching
    • N Offline
      namelessone
      Or call it an offset tool on steroids πŸ˜‰ Too bad, with such variety of plugins, I thought some of them would provide something close to feature I'm looking for. Maybe some plugin gods could listen to it? πŸ˜„
      • CadFatherC Offline
        CadFather
        TIG's extrude edges has an offset function that can take a line and widen it by a chosen amount.
        http://sketchucation.com/plugin/1103-extrudetools
        here's a few others might be worth looking at:
        %(#0000FF)[http://sketchucation.com/pluginstore?pln=multi_face_offset
        404 Not Found
        (sketchucation.com)
        404 Not Found
        (sketchucation.com)
        lattice maker
        http://sketchucation.com/pluginstore?pln=latticeMaker]
        • JQLJ Offline
          JQL
          I think keeping the original edge through CTRL would also be a nice option. Regular Command would offset and erase, with CTRL it would keep. I would use it to bevel a union on two materials like polished stone slabs
          www.casca.pt
          Visit us on facebook!
          • pbacotP Offline
            an edge is one thing. An arc is another matter. The tool would need to know what to do with it (trim and complete arc to edge of face). The various offset issues that SU faces come into play.
            • sdmitchS Offline
              sdmitch
              @namelessone said:
              I've made quick visual example of what I'm looking for. Doing lot of robotic elements, it's kinda slow to make additional lines manually. I'm imagining plugin could allow to select lines/edges, then drag/put width number, expand it and delete old line/edges, just like fredo6's jointpushpull plugin does, except it's 2D lines/edges.
              The closest thing I have found is ThomThom's CityGen-StreetGen
              http://forums.sketchucation.com/viewtopic.php?f=180%26amp;t=19492
              and
              http://forums.sketchucation.com/viewtopic.php?f=180%26amp;t=19493
              http://sdmitch.blogspot.com/
                Why not change the setup slightly and use TIG's Smart Offset?
                • JQLJ Offline
                  JQL
                  Tig's offset its almost there Dave, but it can't work on an edge alone...
                  www.casca.pt
                    But it can get the requested job done.
                    My apologies for suggesting it. πŸ˜’
                    • JQLJ Offline
                      JQL
                      LOL! Shame on you!
                      www.casca.pt
                        Multiple face scale Offset by by Aerilius?
                        http://www.3dsaloon.fr/phpbb3/download/file.php?id=4421&t=1
                        http://www.3dsaloon.fr/phpbb3/download/file.php?id=4417
                        http://www.3dsaloon.fr/phpbb3/download/file.php?id=4418&mode=view/rokbox.jpg
                        http://www.3dsaloon.fr/phpbb3/download/file.php?id=4419&t=1
                        • PixeroP Offline
                          Pixero
                          Not exactly the same but Thomthoms edgetools has a tool called: "Split faces into multiple pieces".
                          With it you can select an edge and drag to the side and it will adopt to fit the length.
                          (Maybe a bad explanation.) You better try it.
                            If you want to offset edges which have no associated faces, then how do 'we' know the plane onto which the offset new-edge is to be positioned ?
                            I know it could be on the 'ground-plane' but that is not that useful...
                            At least my tool offsets onto the related face.
                            If the edges which are to be offset are coplanar why not create a face and use that for the offset edges, you can always delete the faces afterwards...
                            πŸ˜•
                            • pbacotP Offline
                              I think the use is edges in a face. In particular, edges with two coplanar faces.
                              • JQLJ Offline
                                JQL
                                πŸ˜•
                                You mean it should work on an edge alone if it is associated with a face? I should doublecheck it!
                                I use edgetools split edges most of the time for this sort of stuff (and other) as Pixero suggested. Is your offset capable of expanding edges to the end of the associated face too?
                                How can I've missed those features!?
                                I should triplecheck it!
                                www.casca.pt
                                • N Offline
                                  namelessone
                                  Wow, thanks for suggestions! I've tested them and unfortunately haven't found one that makes the desired result in simple, elegant manner πŸ˜„The best what I've found of all suggestions, was TIG's smart offset, but it had 2 problems. 1. Doesn't erase old edges. If you're creating a complex pattern of 'ribs', selecting edges may feel cumbersome. I guess plugins dedicated for selecting edges could help there, but it that would be a little overkill. 2. If you draw circles (for axis hinge, example), the old edge interferences with offseted circle, so you have to erase/smooth/weld to achieve correct result after pushpulling pattern 3. You have to put offset length number manually, requires experimenting/measuring to get right proportions, which sometimes isn't easy if scales of pattern isn't obvious (tldr, I'd love to see visual adjustment like in fredo6' joinpushpull plugin).
                                  Nonetheless, smart offset is super handy for robotic modelling, I've had a lot of cases where I had to offset weird shapes and I had to clean/correct the result of sketchup's default offset tool πŸ˜„ Not anymore!
                                  About how 'new' plugin could work there, I've prepared graphic how I imagine the plugin progress
                                  PS Does anyone know how this kind of structure is called? The flat metal surface strengthened by outer edges and 'ribs' inside? Check the image I've attached, you can see these structures in upper part of model
                                    Can you put an image of this ?
                                    • JQLJ Offline
                                      JQL
                                      Edgetools split face...
                                      www.casca.pt
                                        This sort of things ?
                                        • JQLJ Offline
                                          JQL
                                          That sort of things. Thanks Pilou, my gif making abilities were ruined with this 4k monitor.
                                          www.casca.pt
                                          • pbacotP Offline
                                            Edge tools split face is great but what OP is asking for is double offsets and removal of the original edges, also for working on curves which split face can't help with much. The second part--removal of original edge--is not too slow manually.
                                            This action seems so common. In making facades, doors, windows cabinets, paneling etc. where all is needed is a "reveal" or joint or, in this case a ridge. So easy to lay out the defining edges, next step is to give those edges "width" for 3d use.
                                            I'd leave out the perimeter action as that seems a different action.
                                            The last example can be achieved by smart offset. I think it is more difficult to just do the interior edges.
                                            So for now smart offset for multiple edges and split faces for single edges...
                                            • 1 / 3
