    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • pbacotP
      Thanks for asking the question. I don't think I've tried that way to flatten before. This tool (and others like Curviloft and Artisan) just about need a whole "for Dummies" book on their own. Imagine the book we'll need to use the bezier surface tool when it comes...
        Don't be shy to ask about workflow questions. Gives me insight to what can be improved and what would use useful improvements to the documentation, FAQ and/or video examples.
        Certainly bezier surface is much more complex... and creating documentation for it is something I dread... πŸ˜•
        • xiombargX
          xiombarg
          @box said:
          Krism, do you have Artisan, another wonderful tool.
          It has a make planer tool that you can specify, Best, XY, YZ or XZ.
          But the scaling in Vertex Tools works in conjunction with the axis tool so that you can specify any angle or plane in your model and have it flatten to that angle. Artisan's Make Planar only works with the default x,y,z planes and ignores the axis tool, even if you change the world axis outside of any local groupings it still references the original default x,y,z planes. I also generally prefer lasso selection tools vs brush selection tools, especially when aligning single rows of vertices to build clean geometry or frameworks for lofting with plugins such as Curviloft.
          If you consider that Artisan video with the lightcycle, think how much more quick and efficient it would have been to also use Vertex Tools to properly move, align, merge etc. some of those problematic areas in the geometry where he kept having to rework.
          • xiombargX
            xiombarg
            I hope that didn't sound like I was trying to put down Artisan. Artisan is great for subdividing, and the knife tool is indispensable for certain tasks, but I just wanted to make it clear what it's limitations are when flattening or aligning vertices.
            • xiombargX
              xiombarg
              As long as I'm stacking posts and tooting on about VT... I also have to express how HUGE the Gizmo is and it's right click custom settings when combined with using VT's edge extrusion function. By choosing to "release orientation" and "align to custom" combined with VTs edge extrusion, this is by far the fastest way to whip out most non-linear and organic model forms, at least in the early stages. I'm working on a curvey looking spaceship that normally I would never use Sketchup to create, but with VT (along with Artisan for the subdividing), Sketchup is now a capable option. I'll try and post it up when it gets closer to being done.
                Got some work in progress screenshots? I'd love to see what you're working on.
                • xiombargX
                  xiombarg
                  Give me a few days on it and I'll post something up. I won't have time to work on it this weekend, and what I have so far isn't substantial enough to give and accurate idea of what the end result will be.
                    πŸ‘ πŸ‘ πŸŽ‰
                    • sicksickisckS
                      sicksickisck
                      will it be nice to see something like this [attachment] in V2 πŸ˜„ . and some shortcuts!! to make work faster with this tool..
                      quick planar move
                        Yea - 2D Move and Scale for the Gizmo is planned. πŸ˜„
                        • panixiaP
                          panixia
                          can't wait πŸ˜„
                          • pbacotP
                            Powerful and excellent tool! Fun too! My main problem with vertex tools, you can't pick a point and use inferences with the Gizmo. I often default to the simple point move tool to do that. Am I missing something?
                            • pbacotP
                              Early progress shots especially.
                                How would you expect inference to work with the Gizmo?
                                Are you manipulating single or multiple vertices with the Gizmo?
                                • pbacotP
                                  I mean I when I move it, after picking the direction, I want to be able to pick a point (most likely at the center of the selection) then move it relative to (inference) another point on the model, sort of a target point. Often it's not for exact lineup but for some frame of reference for the move. (Sometimes I do move single points with it. Maybe there's no point using it for that?)
                                  • panixiaP
                                    panixia
                                    maybe you are missing that if you activate the move tool with soft selection turned on, it does exactly what you are asking for πŸ‘
                                    or pheraps i did'nt 100% understand your point..
                                    • sicksickisckS
                                      sicksickisck
                                      my works with vertex tool [and tgi3d and fredo monster tools 🀣 πŸ‘Š ]
                                      https://www.artstation.com/artwork/staff-001-modules-concept-artof-ancient-space
                                      some progress..
                                      https://www.artstation.com/artwork/infiltrator_art2
                                      vertex tool is very very useful tool,, so far, for me πŸŽ‰
                                        some progress..
                                        That looks amazing! Loving the Infiltrator!
                                        • panixiaP
                                          panixia
                                          impressive.
                                          • B
                                            bsfranza
                                            hi there,
                                            just wantet to state a feature request for vertex tools πŸ˜ƒ
                                            how about the option to merge vertices to a designated spot/selected vertice? that would really help!
                                            thanks
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
