    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 97.7k Views 32 Watching
    • W Offline
      wahoowetzel
      That makes sense, I don't have the same need for control here. I just want everyone to have the same starting point, it can evolve beyond that later. This doesn't help me with a solution if someone already has a profile, ie. "log out". Can you offer any suggestions there? Would re-installing sketchup work or no? I'm hesitant to do a test run and re-install anyone's sketchup before knowing what my options are and what may or may not even have an impact.
        My memory is a woolly on the corporate/team version.
        I do remember that the master users dictates the bundle to be used and anyone else logging in can only use that bundle.
        I'd need to chat with Gabor about it.
        But reinstalling SU is not needed.
        • jujuJ Offline
          juju
          there seems to be a glitch in the matrix, I'm still getting these banners for verson 2.5?...
          red pill or blue ill neo?
            looks like you need to reboot your matrix with CTRL+F5...
            • jujuJ Offline
              juju
              haha, might be, except the machine I'm on I bought in January 2015 (brand new, virgin), post 1 of this thread was done Sept. 2014.
              I need to add that this does not happen all the time, only from time to time that I see the banner ad for 2.5
                It's got nothing to do with when you bought machine. More so i only changed the ad artwork last week.
                So your browser is serving you an older file...
                • jujuJ Offline
                  juju
                  Yep, but the browser can only serve me with what it is being directed to. If the machine had no access to this website / webpage / forum before the update, it cannot serve me with that information as it will have none of that in cache, not so? Or am I missing something?
                  The machine was brand new, not second hand. This has been showing up every now and again, not only now or over the last week or month.
                    Yes, and if your browser or our site settings are set to stored cached files then you will get those files until your browser settings are refreshed.
                    So what you are getting are cached images to improve page load times.
                    Even though the images have changed since your browser has not been told to update yet.
                    CTRL+F5 is a Hard refresh that forces the change in your browser.
                    • jujuJ Offline
                      juju
                      I'll do the CTRL+F5, and report back the next time I notice the banner loaded.
                      The point I'm trying to make is that the (my user) browser was not around (since my machine was in some warehouse possibly, in storage, all nicely wrapped up) when the newer version was released, so it could not have loaded the erroneous file (-s) into cache.
                        my point is that the older 2.5 ad image you see was only changed last week
                        • jujuJ Offline
                          juju
                          aaah, I was thinking that that could be one possibility.
                            shinjiniacharya
                            Hi! I was facing some problems while installing sketchUcation tools. I followed the instructions in the video but I can't find any "install extension" button in the preferences tab. Please help. I am using Sketchup Pro 8.
                              @shinjiniacharya said:
                              ...but I can't find any "install extension" button in the preferences tab. Please help. I am using Sketchup Pro 8.
                              That would indicate you never installed updates to SU8 when they were released and you're still running the first release. I think at this point you would need to upgrade at least to SU2014 Pro.Assuming you are running a legitimate copy of SU8 Pro, you might try contacting the SketchUp customer support folks.
                              You could rename the .rbz file you downloaded to .zip and then, being very careful to maintain the file structure, manually install the extension the old fashioned way.
                              • john2J Offline
                                john2
                                I recently updated to Windows 10 Pro. I am running sketchup 2015 64 bit. Whenever I click the red butotn of this plugin I get a blank white screen. I tried 4-5 times, removed this extension, reinstalled it but still getting a blank white screen. What should I do? My drivers are up to date.
                                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                  Try clearing the IE caches/temporary internet files.
                                  • john2J Offline
                                    john2
                                    Tried it. I cleaned using CCleaner. I am still getting that screen.
                                      @John2
                                      Works fine for me in Win10, so something is adrift your end...
                                      Clear the cache from within Internet Explorer itself...
                                      Also look at Control Panels > Internet Options
                                      Ensure Javascript is enabled.
                                      Ensure the security settings are not too severe...
                                      I'll also PM you a beta v2.6.2 to see it that helps...
                                        bsfranza
                                        hey guys - there was a video of sketchucation tools 3.0 πŸ˜ƒ so when to expect something?
                                        a humble question, i know
                                          When it is ready.
                                          Sent from my iPhone using Tapatalk
                                          • jujuJ Offline
                                            juju
                                            @rich o brien said:
                                            When it is ready
                                            humble question, not so humble answer...
                                            • 6 / 7
