    Plugins/Extensions don't show up in Extensions Menu
    5 Posts 3 Posters 312 Views 3 Watching
      Lodewijk
      Hi alltogether,
      plugins and extensions after installation sometimes don't show up in the extensionstab (SU Make 2015). For instance Section Cut Face and TwiLight (Hobby). With TwiLight I also get a list of Load Errors. And after installing Skalp, SU did not work properly anymore. So I deleted Skalp and SU was fine again.
      Who has an idea what to do about this?
        It sounds like a combination of problems.
        For instance, Section Cut Face doesn't show in the Extension menu. It shows in the Context menu. This is clearly spelled out in the in the usage notes.
        How did you install these plugins you tried to use? What error messages? Did you get? Just telling us you got load errors doesn't give enough information. Copy and paste the errors here. It'll be much easier to help you.
          Lodewijk
          OK thanks, I installed SectionCutFace again, but what means that it is shown in the Context menu? I did not find it under Window or Tools. So where should I look?
            It appears in the menu when you right click on a selected section cut.
              Lodewijk
              Yes, thanks!!!
