    [Plugin] PipeAlongPath
    122 Posts 58 Posters 168.0k Views 57 Watching
    • massimoM
      massimo Moderator
      At the bottom of the very first post of this thread.
      • B
        bwantedstar
        OH, I found it! Thank you very mush!!
        [attachment=0:3tt49ous]<!-- ia0 -->Cattura.JPG<!-- ia0 -->[/attachment:3tt49ous]
          Version v2.1 is now available in the PluginStore http://sketchucation.com/pluginstore?pln=PipeAlongPath It fixes some rare issues when edges in paths have a very slight skew in Z, it still warns if <~0.3 degrees etc which might Bugsplat, but traps for such slight differences which have previously caused a failure, but which would not have caused a Bugsplat...
          Please test and feedback...
            Version v2.2 is now available in the PluginStore http://sketchucation.com/pluginstore?pln=PipeAlongPath It addresses a glitch with the misplacement of node-cpoints [if that option was set], if the path was found to be slightly skewed, and the user chose 'No' in the additional dialog to process things anyway...
            Now the node-cpoints are correctly placed in every case...
            • GarethG
              Gareth
              thanks again Tig
              great work as always, and most genuinely appreciated
              • B
                bonk
                I am very green;experience and envy ! Thanks to Tig and others who have gone before. Trying to create a square tube spiral to specs. Steep learning curve. Thanks
                  mist3ry30
                  Great plugin, thanks! Is there perhaps a way to extrude a specific profile (instead of just a circle as with the pipe extrusion here) along, say, multiple different curves? I have a louvre profile which I wish to extrude along many different curves. Ideally I'd like to select all of the curves, select the profile, and then hit 'extrude'.
                    look at
                    http://sketchucation.com/pluginstore?pln=DM_ProfileBuilderFree_v.1.1.0
                    That's the older free-version, there's a newer/better version available for a few $...
                    http://sketchucation.com/forums/viewtopic.php?p=560134#p560134
                    • L
                      leo1234
                      hey TIG, just want to thank you for your pipe along path plug in! Fantastic !!! On a v tight deadline here and your plugin has saved me untold grief. Cheers, Paul
                        amis
                        Thanks to author for great plugin! But I encountered the situation when I tried to make a pipe it caused my SU 2013 hang. I suppose the reason of that some problem with my edges or connections, even though TT's Edge tools inspections were done. Can anyone say what was wrong with edges? Sorry for my English
                        Pipework.skp
                          There are 8 edges connected in that SKP.
                          Selecting them all and running PipeAlongPath I get no issues.
                          The pipe forms perfectly and quickly.
                          I can also draw a circle centered on the vertical line's end and then successfully use FollowMe on the selected path.
                          Can you do that ?
                          Do you perhaps have another plugin loading that has an Observer ill-advisedly messing with group creation etc ?
                          Have you installed something new recently ??
                          Try disabling most of the plugins, except PipeAlongPath, then retry and see what happens.
                          It it no longer fails you know that one of the disabled plugins is messing you up... πŸ˜•
                            amis
                            Thanks you for quick response
                            @tig said:
                            I can also draw a circle centered on the vertical line's end and then successfully use FollowMe on the selected path. Can you do that ?
                            Yes, I performed that and everything's well
                            @tig said:
                            Do you perhaps have another plugin loading that has an Observer ill-advisedly messing with group creation etc?
                            Never heard about such things. I always try to load not too many plugins
                            Just updated some of plugins.
                            @tig said:
                            Try disabling most of the plugins, except PipeAlongPath, then retry and see what happens. It it no longer fails you know that one of the disabled plugins is messing you up... πŸ˜•
                            That's not the shortest way actually) Anyway thanks a lot. I will try.
                              You can probably reduce the list of possible culprits by looking at the recent updates or those with do complicated processes - they are more likely to have observers etc...
                              Can you post a simple list of your installed plugins ?
                                amis
                                2DTools
                                Fredo6_Curvizard
                                Fredo6_FredoScale
                                Fredo6_FredoTools
                                Fredo6_JointPushPull
                                FrontFace
                                Layer Manager
                                sketchup-stl
                                tt_cleanup
                                tt_edgetools
                                TT_Lib2
                                tt_selection_toys
                                tt_solid_inspector
                                CenterPointAll.rb
                                dropGC.rb
                                ExtrudeAlongPath.rb
                                ExtrudeTools.rb
                                extrude_lines2.rb
                                HoleInTheWall.rb
                                ithil_facefinder.rb
                                ithil_reverseface.rb
                                LibTraductor.rb
                                makefaces.rb
                                mesh_additions.rb
                                Mirror.rb
                                move_to_origin.rb
                                ocean_extension.rb
                                PipeAlongPath.rb
                                PurgeAll.rb
                                pushpull_tool.rb
                                recurve.rb
                                s4u_makeface.rb
                                SectionCutFace.rb
                                SimplifyContours.rb
                                sketchup-stl.rb
                                SketchyFFD.rb
                                SliceModeler.rb
                                TIG-Split_to_plane.rb
                                tt_cleanup.rb
                                tt_edgetools.rb
                                TT_Lib2.rb
                                tt_selection_toys.rb
                                tt_solid_inspector.rb
                                Zorro2.rb
                                There are no quite new plugins here. Every of them I used for long time.
                                  Ignoring those I am 99% sure are OK... πŸ˜•
                                  Try disabling these and re-test:
                                  FrontFace
                                  dropGC.rb
                                  HoleInTheWall.rb
                                  ithil_facefinder.rb
                                  recurve.rb
                                  s4u_makeface.rb
                                  SliceModeler.rb
                                  You also have some 'old' ones that I think might not belong in there - there might be newer su_ versions available ?
                                  ... e.g.
                                  ocean_extension.rb
                                  SimplifyContours.rb
                                    amis
                                    You're right. Many of plugins in my set are a bit old.
                                    OK. I deleted those you've mentioned, relaunch my SU, select the whole chain (of edges), run PipeAlongPath and stil got SU hang. Looks like my Plugins folder needs total revision...
                                      amis
                                      I've tried another way. I redrew the same chain (of edges) near existing one and had no problem with making pipe. But still got the hang with existing chain.
                                      Finally after revision, deleting some of and reinstall/updating all of existing plugins I have no problem. Unfortunally I missed at which step it happened. Thanks TIG
                                      Pipework.skp
                                        johnwmcc
                                        I find this plugin very useful to draw scaffolding poles when designing amateur theatre sets using scaffolding as part of the structure. I've reset (in the code) the default sizes, and options, to suit my use.
                                        I'd also very much like to have the plugin create a component, rather than a group, and to orient the component axis along the direction of the first line segment in the path. Would that be difficult?
                                        I don't think my own SU Ruby skills are quite up to this, though I may well have a go - I might to able to code for component creation, but have no idea how to set the component axes in Ruby.
                                          You can do it several ways.
                                          Without recasting this as a Sketchup Tool etc I think your best bet is to make the group as it is.
                                          Then later you can turn that into a component instance...
                                          At that stage the origin of the group, and now the component definition ,is at the bounds.min of the container.
                                          To relocate the axes you need to do theses steps...
                                          Get the vector from the point you want the axes to be back to the container's origin.
                                          Then transform all of the definition's entities by that vector.
                                          Then move the instance by the inverse transformation, so it doesn't visibly move BUT its origin is now at the desired point.
                                          I assume you'd probably want that to be the center of the start of the extrusion @new_pts[0] aka pt1 ?
                                          You always want the axes to align in the red along the pipe ?
                                          Insert something like this order around line#490 [untested]...
                                          inst=group.to_component
                                          defn=inst.definition
                                          defn.name="some_name_you_like"
                                          ents=defn.entities
                                          vec.reverse!
                                          xaxis=inst.transformation.xaxis
                                          vert=vec.cross(xaxis)
                                          trans=Geom;;Transformation.new()
                                          unless vert.length==0
                                          	ang=vec.angle_between(xaxis)
                                          	unless ang==0
                                          		trans=Geom;;Transformation.rotation(pt1, vert, ang)
                                          		ents.transform_entities(trans, ents.to_a)
                                          		inst.transform!(trans.inverse)
                                          vector=pt1.vector_to(ORIGIN)
                                          unless vector.length==0
                                          	trans=Geom;;Transformation.translation(vector)
                                          	trans=Geom;;Transformation.translation(vector.reverse.transform(inst.transformation))
                                          	inst.transform!(trans)
                                          defn.invalidate_bounds
                                          	model.commit_operation
                                          ??? It IS convoluted ???
                                          • EdsonE
                                            Edson
                                            hi TIG,
                                            I am having repeated crashes while using PipeAlongPath to create a handrail. the model is small and should not be a problem. I wonder if there is a conflict with some other extension. list of extensions attached.
                                            any ideas?
                                            escada-emergencia_Leste.skp
                                            http://www.mahfuz.arq.br
                                            • 4 / 7
