    [Plugin] PipeAlongPath
    122 Posts 58 Posters 168.0k Views 57 Watching
    • V
      vojo
      So Tig, ever thought about extending your plugin to basically spoof thick lines?
      • one more menu item: Pipe vs duct
      • inner and outer diameters ==> width and height
      • In your "getting to real work" section, use the menu item to determine
        if creating a circular face or a rectangle
      • etc
      It would be a great way to make thick lines and not suffer from the aliasing issue on curves in the other plugin that seems focused on this kind of thing.
      on top of spoofing thick lines, I guess, it could be a great way to make a serpentine wall easily (draw the line freehand or whatever, call your plugin and set width height, execute)
      For thick line width = say 5mm Height = say 0.1mm
      For wall width say 100mm height say 1000mm
      • T
        tashaco
        TIG - it's late at night and I have about a hundred little pipes to draw - each at a slightly different angle - before tomorrow morning, and have just stumbled across your plugin. I could cry I am so pathetically grateful, I thought I was going to be up all night doing it. Thanks so much!
        • kingsiK
          kingsi
          Great plugin. Many thanks
          Noobtastic
            Version v1.9 now available in the PluginStore.
            http://sketchucation.com/pluginstore?pln=PipeAlongPath
            It has a trap for the occasional lockup if the path has a very slight skew and changes of direction, which SketchUp's FollowMe can't handle.
            It now allows any units to be used in ne input [defaults to Model Units display]
            It remembers the last used options across sessions and globally for all models.
              Version v2.0 now available in the PluginStore.
              The lockup/skew trap is now improve and far less likely to appear.
              The v2014 graphics glitch with some pipes not appearing smooth unless they were subsequently edited is resolved.
              The name now better reflects if the pipe's internal diameter == 0.
              • B
                Bethidralas
                Hello there.
                Is there any RAR file available for this plugin? I really don't know how to install sketchUcationTools.rbz
                • massimoM
                  massimo Moderator
                  I see that you have SU8. If you have the latest version of SU8 you must be able to install .rbz by clicking on window-->preferences-->extensions-->install extension.
                  If you want to install the plugin manually, just rename the .rbz as .zip and unzip it.
                  • B
                    bwantedstar
                    why can't I find the download button?
                    where is it?
                    • massimoM
                      massimo Moderator
                      At the bottom of the very first post of this thread.
                      • B
                        bwantedstar
                        OH, I found it! Thank you very mush!!
                        [attachment=0:3tt49ous]<!-- ia0 -->Cattura.JPG<!-- ia0 -->[/attachment:3tt49ous]
                          Version v2.1 is now available in the PluginStore http://sketchucation.com/pluginstore?pln=PipeAlongPath It fixes some rare issues when edges in paths have a very slight skew in Z, it still warns if <~0.3 degrees etc which might Bugsplat, but traps for such slight differences which have previously caused a failure, but which would not have caused a Bugsplat...
                          Please test and feedback...
                            Version v2.2 is now available in the PluginStore http://sketchucation.com/pluginstore?pln=PipeAlongPath It addresses a glitch with the misplacement of node-cpoints [if that option was set], if the path was found to be slightly skewed, and the user chose 'No' in the additional dialog to process things anyway...
                            Now the node-cpoints are correctly placed in every case...
                            • GarethG
                              Gareth
                              thanks again Tig
                              great work as always, and most genuinely appreciated
                              • B
                                bonk
                                I am very green;experience and envy ! Thanks to Tig and others who have gone before. Trying to create a square tube spiral to specs. Steep learning curve. Thanks
                                  mist3ry30
                                  Great plugin, thanks! Is there perhaps a way to extrude a specific profile (instead of just a circle as with the pipe extrusion here) along, say, multiple different curves? I have a louvre profile which I wish to extrude along many different curves. Ideally I'd like to select all of the curves, select the profile, and then hit 'extrude'.
                                    look at
                                    http://sketchucation.com/pluginstore?pln=DM_ProfileBuilderFree_v.1.1.0
                                    That's the older free-version, there's a newer/better version available for a few $...
                                    http://sketchucation.com/forums/viewtopic.php?p=560134#p560134
                                    • L
                                      leo1234
                                      hey TIG, just want to thank you for your pipe along path plug in! Fantastic !!! On a v tight deadline here and your plugin has saved me untold grief. Cheers, Paul
                                        amis
                                        Thanks to author for great plugin! But I encountered the situation when I tried to make a pipe it caused my SU 2013 hang. I suppose the reason of that some problem with my edges or connections, even though TT's Edge tools inspections were done. Can anyone say what was wrong with edges? Sorry for my English
                                        Pipework.skp
                                          There are 8 edges connected in that SKP.
                                          Selecting them all and running PipeAlongPath I get no issues.
                                          The pipe forms perfectly and quickly.
                                          I can also draw a circle centered on the vertical line's end and then successfully use FollowMe on the selected path.
                                          Can you do that ?
                                          Do you perhaps have another plugin loading that has an Observer ill-advisedly messing with group creation etc ?
                                          Have you installed something new recently ??
                                          Try disabling most of the plugins, except PipeAlongPath, then retry and see what happens.
                                          It it no longer fails you know that one of the disabled plugins is messing you up... πŸ˜•
                                            amis
                                            Thanks you for quick response
                                            @tig said:
                                            I can also draw a circle centered on the vertical line's end and then successfully use FollowMe on the selected path. Can you do that ?
                                            Yes, I performed that and everything's well
                                            @tig said:
                                            Do you perhaps have another plugin loading that has an Observer ill-advisedly messing with group creation etc?
                                            Never heard about such things. I always try to load not too many plugins
                                            Just updated some of plugins.
                                            @tig said:
                                            Try disabling most of the plugins, except PipeAlongPath, then retry and see what happens. It it no longer fails you know that one of the disabled plugins is messing you up... πŸ˜•
                                            That's not the shortest way actually) Anyway thanks a lot. I will try.
                                            • 4 / 7
