    How do i make race bucket seat SketchUp
    11 Posts 4 Posters 2.2k Views 4 Watching
      Look at the SketchUp Artisan plugin as a way of making organic shapes like seats.
      http://sketchucation.com/forums/viewtopic.php?t=42938
      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=17097
      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=33298
      There are lots of threads if you Search SCF...
        You have a letter more on your adress link! html"4" πŸ˜‰
        • E Offline
          ESSA
          thankyou i have now corrected the link
          • E Offline
            ESSA
            from understanding all that plugins does smooth the the model, im looking on how to actually create the bucket seat.
              You make a 'proxy' from a simple boxy shape.
              Drawing some rectangles, pushpulling, scaling etc quickly gets you the general proxy form...
              That is pretty simple SketchUp 3d modeling, needed to make a seat that is approximately the right size form.
              If you can't manage that read up on simple SketchUp modeling.
              Learn to walk before you run...
              If you get the proxy, you use plugins like Artisan to smooth that form to be more seat-like [aka 'organic'].
              There are many examples in the threads.
              Search...
                but i cant seem to get the right measurements and dimension correct.
                With subdivision modeling that is the little problem as you must imagine an approximately primitive simplified right size form and this form will be subdivised so transformed! πŸ˜„
                but...here some tricks for avoid that! πŸ˜‰
                  Go with making simple shape as it'll make things easier to tweak
                  [sw:12euar9r]FWoISqGePrw9Z48[/sw:12euar9r]
                  You can thickness using JPP by Fredo or Thomthom Shell
                  [sw:12euar9r]cJp5fybclP9G7gD[/sw:12euar9r]
                  • E Offline
                    ESSA
                    [sw:20nffmps]FWoISqGePrw9Z48[/sw:20nffmps]
                    [sw:20nffmps]cJp5fybclP9G7gD[/sw:20nffmps]
                    thanks Brian was that made in Sketchup program itself and did you make that ?
                      That is all SketchUp.
                      With a Plugin at the end to 'subdivide' > smooth, and another to give 'thickness'.
                      There are several 'tutorials' on making organic forms.
                      You should stop thinking of it as a 'seat' - it's just an organic 3d shape.
                      There are several car-making tutorials [look on YouTube] which demonstrate how to make a faceted shape for body-parts with the SketchUp native drawing tools - they are no different from a seat...
                      Here's perhaps the most extensive one...
                      https://www.youtube.com/watch?v=tv8gECOxLxY
                      Or this is part 1 of 6...
                      https://www.youtube.com/watch?v=tzjA0GPdQrw
                        It's all SU and yes I did make it using the techniques mentioned by TIG.
