    Help understanding Victorian floor plan.
    31 Posts 8 Posters 7.2k Views 8 Watching
    • E
      EPD Gaffney
      @calstock said:
      I did Google the Architect the other day to look for other plans and I think he used the circular feature elsewhere. This may be a line of research for you - look for other plans by the Architect because they tend to repeat favoured features in other projects. The hope being the features are better detailed elsewhere.
      Thanks, Calstock. What did you find? I've not found much besides what's already in that book. He uses it again I think in the one I have attached here, in the scullery.
        The round detail in the corner of the scullery in your latest image would be a copper. There's a fireplace to its left. The round one to the left of that might again be access to a well or cistern or it might be where kitchen waste gets dumped so it can be removed by the gardener from outside without being hauled through the house.
        As for the "hooks" in your original question, I would be extremely surprised if a detail like a hook on a wall would be shown in a plan like that. More likely is that it is some artifact from the drawing.
          driven
          Re: item 4
          I've worked in many large houses of the period, in the area [filming], and the only item I can imagine being in that position, worthy of highlighting, would be 'servant bells' or an 'intercom'...
          If such a device was installed or upgraded later than build date, then it may explain it being 'penciled' in.
          Some of these contraptions are quite substantial, but 'could' be represented by a pair of speaker horns...
          this is wild speculation, countered by the knowledge of there importance for the smooth running of any large household of the era...
          • C
            Calstock
            EPD, sorry, I can't find the drawing I thought I'd spotted. DaveR has a good read on the plans. As an aside, isn't it surprising just how little of this large house is allocated to what we would call the living space, (dining room, drawing room, morning room, etc)..... Not that I have such rooms, (apart from dining and definitely not a boudoir !).
              Gary, your remark about how much of the space in a house from this period is not "living" space is interesting. If you think about all the things that had to be done in the house that we would take for granted, you can see that you'd actually need more space for those things to occur. If you haven't seen it, Victorian Farm is an interesting watch to get a taste for the things that had to be done. There's also an older series called The Victorian Kitchen which start Ruth Mott. It takes place in a house similar to the house in question. If you can find it on YouTube, I expect you could glean a lot of details.
              • C
                Calstock
                I remember watching the Ruth Mott Kitchen series when it was first run - great programme Dave.
                  It was, wasn't it. I liked Ruth a great deal. I also enjoyed the various farm videos even though they went through everything pretty quickly. Still some interesting info.
                  • E
                    EPD Gaffney
                    Thanks very much, everyone. It's fantastic that ye feel so inclined to help. I hope to return the favour to some other novices on this forum one day.
                    So, I've gone through the whole book and put together all the plans where I personally noticed this yoke we're discussing or something that could potentially be the same. I may have missed a couple but this is about as good as it'll get I imagine. (And I've apparently neglected to include the plan for Bignell House.) Am I correct in seeing doors going into whatever this thing is? If so, why is no-thing indicated on the outside for picking up the waste without entering the house as Dave R has suggested? That seemed the most likely suggestion to me but this bit is puzzling.
                    1. and 9. seem to be exactly the same as Bignell House, a rounded shape totally outsdide of any buildings but connected to one, usually a scullery.
                    2. is rounded but within square walls and it comes out of the scullery. I thought it was indoors in a different building but the fuel shed is where it goes and is really outdoors.
                    1., 4., 7., and 8. are irregularly shaped but I believe the same device is implied. 4. seems the only one of these that protrudes totally out of the building. Interestngly, in 1. and 7. the device in question is in the wash-house and not the scullery. Could it be a different device in that case?
                    1. and 6. are rather more oblong, and 5. rather curiosuly seems to be indoors and not adjacent to an external wall, whereas in line with the rest of them, 6. is at the outer wall and could be outside.
                    2. and 11. are different but near the end of this I wondered are they fulfilling the same function. I'm talking about the rectangular items against the outer walls. The first image has this as well in the scullery.
                    driven: I think it looks interesting and mysterious on the map so I'll keep it and do something with it. It's for a computer game, a horror one no less, so a bit of mystery is good.
                    Calstock: In a way it is surprising, but at the same time the rooms are quite big, and in addition to what Dave has said, the space required to do all these tasks is indicative of the number of people that needed to do them, hence the high number of bedrooms (some of which are for guests as well). And considering that these are generally homes and countryhouses for the wealthy, this was by no means standard for the majority. Many families had a single room for living, cooking, sleeping and any thing else that you'd like to do indoors.
                    Dave: never seen either programme but I'd love to. I should save the names for when I have time to watch something. I've read Margaret Powell's books on domestic service, and they were positively fascinating. Her accounts start from the 1920s but she often draws comparisons to Victorian living, and mentions what had improved, or occassionally grown worse.
                    • C
                      Calstock
                      I know what you mean EPD. My wife grew up in a 1650's farmhouse, (ex-inn we believe)and our previous property, (where we lived for 17 years) was a 1760's Cotswold stone cottage. Obviously modern amenities had all been added at some point, but it did give you a sense of the room sizes, ceiling heights, wall thicknesses, garden sizes, (the one thing that was considerably bigger), and other details apparent in an older property. We brought our current house when it was 18 months old - a complete change you can imagine !
                      • E
                        EPD Gaffney
                        Indeed, Calstock. That can certainly be some change. I'm doing a lot of research on this type of thing lately as I'm writing a novel about an 1870s Donegal farm girl that goes into service in a big mansion, as well as working on the computer game that this floor plan will be for. So, I'm finding out a lot and it's interesting. It's the sort of thing I never used to think about that much. I always liked it but hadn't really given much thought to the complexity of it.
                        • KrisidiousK
                          Krisidious
                          I highly doubt that most American homes built today will be standing 400 years from now...
                          By: Kristoff Rand
                            slbaumgartner
                            Nor, for that matter, most of those being built anywhere else today.
                            • E
                              EPD Gaffney
                              Isn't that the truth. A fair few shoddy buildings being put up these days. As technology improves, cheaper ways of doing things come about, and a good half the time, cheaper won't last.
                              • C
                                Calstock
                                I know we're drifting off topic here, (and off Sketchup), but it is an interesting discussion.
                                Having lived in a 1760's Costwold stone cottage,it was certainly sturdy. We had some really bad gales one day when I lived there and on the way home there were roof tiles off all the buildings, trees blown down, vehicles tipped over, etc. I was dreading what I'd find when I got home, only to find it didn't suffer one jot !
                                Here's the thing though - we shouldn't have too much of a rose tinted view of these properties because although they are long-lasting, they're constantly damp, (despite all the usual modern day remedies), they end up twisted and leaning all over the place, (on account of no foundations and the crucial element of lime mortar, (which allows movement without cracking). What I'm saying is if a modern building had these defects, we'd probably call it a fail. I know that's not a fair comparison but then comparing modern and old properties isn't fair on some levels either.
                                We do tend to forget, (or take for granted), that new houses come with double glazing, central heating, fitted kitchens AND inside lavatories !! as standard, (to name a few).
                                • E
                                  EPD Gaffney
                                  It certainly is interesting. I hope anyone that indeed has insight into what I've said in my last Sketchup post, will tell me, as I need it, but I don't mind an interesting discussion in the meantime.
                                  So, I agree with most of what you've said there, and I take your word on the rest.
                                  In my book, as was common practise, the protagonist and her family sleep with several animals inside the cottage, as this aids in heating the place. It was that and a fire. The fire didn't really cost you on a farm, but you certainly worked for it. I can't imagine the ordeal of keeping a fire in all them fireplaces you sees in a mansion.
                                  On the topic of toilets now, would anyone care to explain to me what apparatus was common when? My understanding is that indoor plumbing wasn't uncommon by the 1880s, at least in Britain and Ireland (probably not in the rural parts, though). By what process did they achieve hot water and when did our modern process come about of relieving ourselves indoors and flushing? How about what's called a bathroom or washroom in these floor plans? What was in there?
                                  • E
                                    EPD Gaffney
                                    Look at this!
                                    http://0.tqn.com/d/architecture/1/S/r/i/1/scullery-3069961-crop.jpg
                                    Any chance that round thing I was talking about is an oven?
                                    • sfto1S
                                      sfto1
                                      I believe item 4 as noted in original post is a servants staircase to the first floor from the ground floor. Very steep with treacherous winders at the top and bottom of the run. If you look at the first floor plan the top of the stair is in the linen area on that area of the plan. There is a separate steep stair from the first floor to the second floor for servants from the linen area to the closet area above.
                                      • E
                                        EPD Gaffney
                                        I'm sorry, stfo1, but I'm not sure I follow. Are you saying the hook-like symbols mark the top of the stair? I'm not trained to read floor plans but I would intuit that rather than vertical they'd be horizontal. If that's what they are, altough I could think of a few better symbols than those if it were my choice.
                                          driven
                                          I still think no.4 may be Butler bells...
                                          • sfto1S
                                            sfto1
                                            I am certain that what is delineated is a stair. In a residence such as you are studying, it was rather common that servants used a separate set of stairs to perform their chores. Using the main stair was largely unacceptable. The drawings use conventional drafting to depict a winding stair. For a stair of this nature "pie" shaped treads are at both the top and bottom. See attached photo for the bottom of such a staircase.
                                            As to bells and hooks, it is uncommon to show such details on a plan as you are studying. Typically plans like this shown room arrangements, major structural elements, fenestration, doors and stairs.
