    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 103.8k Views 32 Watching
    • Bob JamesB Offline
      Bob James
      Thank you, Box
      • dereiD Offline
        derei
        How can I delete the bundles? From what I read, only copied one can be deleted at this moment.
        I have 2 more bundles that are useless and I want to get rid of them.
        DESIGNER AND ARTIST DEREI.UK
          Locked Bundles relate to other computers or SUpVersions.
          You can only delete copies.
          PM GΓ‘bor and ask for your database entries to be tidied up [specify what you no longer want to keep!]...
          I think he should adjust the code to allow simple deletion of 'copied bundles' and a deletion of 'fixed bundles', with an intervening 'are you really sure you want to delete this bundle?', so you don't do it by accident.
          • dereiD Offline
            derei
            I agree... eventually a secure deletion backed up with password (to ask for account password on deletion). Because once logged in, everyone who has access to SU can delete them. And second, introducing a password is nothing like "accidentally hit delete".
            For now I'm fine... is only two that I need purged and they don't bother me that much. If there will be more, then I will either ask for cleaning, or hopefully a new version of the app will be available and I will be able to do it myself.
              Jim
              If you are to allow html in the Extensions manager, maybe open the links in the default browser.
                flagged...thanks
                  bsfranza
                  hi there,
                  whats the status on the plugin manager ?! there any chance we see a update anytime soon?
                    @bsfranza said:
                    hi there,
                    What do you think needs updating ?
                      bsfranza
                      hey ho,
                      wasnt there a video once showing how one could save settings, shortcuts, and so on with plugin store?
                      that would be cool=)
                      besides that a more complex bundle management would be cool...
                      .so to see which one is active on at the moment
                      .the ability to delete unneeded old bundles
                      .and save under a new name?!
                      so πŸ˜ƒ
                      thanks for consideration
                        caecarvalho
                        Hi, I'm having a similar problem that the one reported by leminilab, but I get a different response on ruby console:
                        Error: #<RuntimeError: can't modify frozen String>
                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:517:in gsub!' c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:517:in chooseplugins'
                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:473:in autoinstall_dlg' c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:405:in set_autoinstall_choice'
                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:73:in block in new' SketchUp:1:in call'
                        What happens is that the 'autoinstall' button don't work at all, and the installer inside the SFC menu won't work as well. When I go to the installed plugins, there's no list...
                        I found a workaround that is installing it in an aditional plugin folder using fredo's plugin. Now that's working, but would be nice to try to understand this problem! I'd appreciate if someone could help with that!
                        I'm using SU Pro 2015 64-Win 7
                        Thanks,
                        Caetano
                          Thanks,
                          Caetano
                          This is a very rare error. πŸ˜•
                          in fact, so rare that I can say I have never seen it before !
                          Can you give the result of:
                          $LOAD_PATH
                          Also the result of:
                          SCF_Dialog.custom_plugins()
                          The 'string' that the .gsub! is applied to is NOT 'frozen', so I can't see what's the issue !
                            caecarvalho
                            $LOAD_PATH
                            Also the result of:
                            Hi TIG,
                            Thanks for your fast answer!
                            $LOAD_PATH
                            ["C:/Users/CAETANO/Documents/SU Custom Plugin Folder", "C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib", "C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific", "C:/Program Files/SketchUp/SketchUp 2015/Tools", "C:/Users/CAETANO/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:\ProgramData/ASGVIS", "C:\ProgramData/ASGVIS/VfS", "C:\ProgramData/ASGVIS/VfS/Ruby", "C:\ProgramData/ASGVIS/VfS/Ruby/images"]
                            ["C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:/Users/CAETANO/Documents/SU Custom Plugin Folder"]
                            After I installed Sketchucation Tools in the custom pluguin folder that I created with Fredo's plugin (Before I've deleted the files, including the ones appdata/local/SFC and appdata/local/temp/SFC), it's working but it won't save in the default location (appdata/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins).It's saying that there's no permitions to install on this folder, instead it's installing on (ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins). So I don't get that first error anymore in the ruby console. And I still don't get the list with the installed plugins.
                            This problem happened after I restored the default icon for the plugins folder, cause I was having problems with another plugin installation, so I tryied those steps in this link:
                            http://sketchucation.com/resources/tutorials/811-setting-security-permissions-in-sketchup
                            The weird think is that the default plugin folder(appdata/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins) seems to have all the permissions...
                            I have even restored the SU installation, with no success...
                            I'm really intrigued by this problem! Thanks for taking your time to help!
                            Best,
                            Caetano
                              Thanks.
                              Looks like there is nothing odd about your $: πŸ˜•
                              Looks like a permissions issue to me...
                              Find C:\Users\CAETANO\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp
                              then with Admin powers, step up one level and select its folder-icon,
                              ensure it has FULL permissions set for ALL those listed under:
                              Right-click > Context-menu > Properties > Security > Edit OK/Apply
                              Repeat the ' FULL' set up for the folders contents - there should be three subfolders Plugins, Classifications, Tools.
                              Ensure that the contents of the ' Plugins' folder are all also set ' FULL'.
                              The permission changes should automatically apply to a folder's contents, but just double-check...
                              If the ' Plugins' folder is missing try making it ??
                              try to delete the folder's "cookiejar.xml" file too - it might be corrupted.
                              Restart SketchUp and test...
                              If this fails...
                              I see you have a Vray installation.
                              Can you disable that plugin, restart SketchUp and retry - to see if it is somehow conflicting ?
                                c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:517:in `gsub!'
                                TIG - what is the source of the string you call gsub! on?
                                  def self.chooseplugins(p=nil)
                                    p = nil if p == ''
                                    if p
                                      p.gsub!(/["]/, "'") ### line 517
                                      @choi = p
                                    else
                                      @choi=nil
                                    RBZtool.set_choi(@choi, @url, @cloud)
                                  Is the method
                                  chooseplugins receives the chosen plugins folder's path-name.
                                  The chosen path is from a list assembled from folder-paths in $: which is filtered to remove folders like Tools, Ruby folders etc...
                                  I think that gsub is unlikely ever to include a ", but since it's via a callback, js might mess up ?
                                  It only runs if 'p' is not nil.
                                  The 'p' passed should always be a 'string' [folder-path].
                                  I'm wondering if a non-standard Vray path containing a '' rather than a '/' is causing an issue...
                                  It'd be easily trappable in the $: filtering, but it's not at the moment...
                                  πŸ˜•
                                  Disabling Vray from loading might show this up ?
                                  What does your dialog offering custom-plugins folder choices look like ??
                                    driven
                                    @tig said:
                                    ... path containing a '' rather than a '/' is causing an issue...
                                    I recently had a problem with 'mixed separator' paths [on a PC test], oddly File.join was returning it, but using either worked...
                                    or can you test for .frozen?
                                      Can you please substitute the two RBS files in the attached ZIP [you need to extract them and move them manually], with the same named files in the ../Plugins/SketchUcation subfolder...
                                      And restart SketchUp and retest.
                                      This version traps for '' in $: folder-paths and makes them all '/' - so rogue paths [like Vray's] in $: don't mess us up...
                                      If it works we know it's the culprit...
                                      If not == Plan-B πŸ˜•
                                      PutIntoSketchUcationSubfolder.zip
                                        That method appear to modify the input arguments. I wonder if you are passing around a reference from the system which might have been locked to protect it. The trivial way around that would be to not use the bang version of gsub ensuring that you create a copy when you modify the string.
                                          driven
                                          @tig said:
                                          If not == Plan-B :?
                                          isn't the primary error attempting to gsub the frozen string [probably VRay]
                                          in which case would .dup.gsub be the safer route?
                                            The attached files redo the method, hopefully avoiding the gsub completely.
                                            The recode also replaces the '' with '/' in the folder-paths just in case.
                                            I am unclear how a 'string' passed into the $: could be frozen when pushed into there ?
                                            The gsub! manipulation occurred in a 'clone' of the $: anyway !
                                            Let's see what the OP finds...
                                            • 4 / 7
