    [Plugin] SketchUcation Tools 2.6.1
    127 Posts 32 Posters 99.2k Views 32 Watching
      A 'frozen' Bundle relates to an existing Computer-name or SUp version, and it has three buttons:
      • AutoInstall the Bundle's list
      • Duplicate [i.e. Copy] the Bundle
      • Expand the list so you can see what's in it...
        A 'copied' Bundle has those buttons too, but it also has one extra button [it's a circle with an X]
      • Used to Remove the [copied] Bundle [i.e. delete it ! ]
      • Bob JamesB Offline
        Bob James
        I used to have only the plugins that do not run in other than the primary plugins in the primary folder (C:\Users\jamesb\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins).
        The rest I had in a Dropbox folder and used !AdditionalPluginFolders.rb.
        At the moment I have all of my plugins in the primary folder as the first step in cleaning up my plugins.
        I would like to go back to the original scheme, but using SketchUcloud in place of Dropbox.
        Also, my bundles are a Hodge-podge mess. How can I delete ALL of my bundles and start over again?
        • pbacotP Offline
          There are a plugins manager and an extensions manager--both in Sketchucation tools. A plugin can be disabled in either and would not show disabled in the other. Or a plugin disabled in one might not even be listed in the other. What is the method to use these and avoid confusion?
            A Disabled Plugin will not load when SketchUp restarts [right-column/red].
            A Loaded/Enabled Plugin will always load when SketchUp starts [left-column/green].
            A Plugin that is already Disabled can be Temporarily Loaded for that session only [right-column/orange], when SketchUp restarts it will be Disabled, and so it will not load.
            In the latest versions of the toolset, if a Plugin is loaded but its related Extension is disabled its entry in the dialog is highlighted in gray.
            Some Plugins are made as 'Extensions'. They are all still 'Plugins'...
            Disabled Extensions will not load when SketchUp restarts [right-column/red].
            A Loaded/Enabled Extensions will always load when SketchUp starts [left-column/green].
            An Extensions that is already Disabled can be Temporarily Loaded for that session only [right-column/orange], when SketchUp restarts it will be Disabled, and so it will not load.
            In the latest versions of the toolset, if an Extensions is loaded, but its related Plugin is disabled its entry in the dialog is highlighted in gray.
            So... if a Plugin is Disabled it never gets a chance to create its related Extension [if any]...
            If you have Extensions you use quite often, but you do not want them loaded every session Disable them and then Load or Temporarily-Load them as needed.
            If you have Plugins you use quite often, but you do not want them loaded every session Disable them and then Load or Temporarily-Load them as needed.
            Another point is that in the SketchUcation Uninstaller submenu dialog any Plugin entries that have duplicate entries - in any custom-plugins-folders - are highlighted in pink, and so you can choose the folder from the drop-down and Uninstall the duplicate version you do not want loading, which of course would slow SketchUp's startup, and could even cause issues/errors if both of the scripts' versions were different !
            • pbacotP Offline
              Thank you for the reply, TIG. I suppose I'll tread cautiously as there are so many options and I have never figured out plugins vs. extensions and why the old Plugin menu is now Extensions. I can probably get most of the function I need by leaving the extensions manager alone.
              For now I'll leave off creating loaded or unloaded bundles that may or may not have disabled or enabled plugins or extensions in separate custom plugin folders and may or may not be on Dropbox or Sketchucloud or some other server somewhere.
                Trimble's decision to rename the Plugins folder 'Extensions' was inane. πŸ˜’
                All Plugins can make new menu entries wherever they like.
                The 'Plugins' menu was just a default menu location.
                Now, many use plugins use Tools, Draw or the Context-menu - or just Toolbars !
                Some Plugins are also created by their authors as 'Extensions'.
                These can be switched on/off in the Preferences > Extensions dialog.
                They are no different from a basic Plugin [they can 'appear anywhere'] except for the fact that they have a special 'Extension' property which allows this switching on/off when SketchUp is restarted...
                With the advent of the SketchUcation Toolset you can manage your Extensions on/off state from the 'Extensions Manager' - in a similar way to the 'Preferences' options... although it allows you to temporarily load an extension for that session only, which would be convoluted using the native tool...
                Managing extensions can be a little clearer since the Extensions name might be more obvious that it's .RB file name !
                The SketchUcation Toolset also allows you to use the 'Plugins Manager' - this lets you disable/enable/temporarily-load Plugins using just their file-name [i.e. even the hundreds that are not setup to be an Extension!]... Although that file-name is not necessarily as obvious as an Extension's name, if the RB has an entry at SketchUcation then there will be a useful description for the selected item...
                Also the few other 'helpers' etc that might not be directly available from the SketchUcation PluginStore are usually listed/explained too...
                If they are not you got that RB from somewhere else, and so at least you know where to look for updates/help πŸ˜’
                  Bob James
                  Whatever happened to version 2.6.2?
                  I had it running for a while, but it got deleted in one of my attempts to "clean house"
                  • BoxB Offline
                    It's not in this thread Bob, the most recent in the forum is over here.
                    http://sketchucation.com/forums/viewtopic.php?f=372%26amp;t=59539#p549217
                      Bob James
                      Thank you, Box
                      • dereiD Offline
                        derei
                        How can I delete the bundles? From what I read, only copied one can be deleted at this moment.
                        I have 2 more bundles that are useless and I want to get rid of them.
                          Locked Bundles relate to other computers or SUpVersions.
                          You can only delete copies.
                          PM GΓ‘bor and ask for your database entries to be tidied up [specify what you no longer want to keep!]...
                          I think he should adjust the code to allow simple deletion of 'copied bundles' and a deletion of 'fixed bundles', with an intervening 'are you really sure you want to delete this bundle?', so you don't do it by accident.
                          • dereiD Offline
                            derei
                            I agree... eventually a secure deletion backed up with password (to ask for account password on deletion). Because once logged in, everyone who has access to SU can delete them. And second, introducing a password is nothing like "accidentally hit delete".
                            For now I'm fine... is only two that I need purged and they don't bother me that much. If there will be more, then I will either ask for cleaning, or hopefully a new version of the app will be available and I will be able to do it myself.
                              Jim
                              If you are to allow html in the Extensions manager, maybe open the links in the default browser.
                                flagged...thanks
                                  bsfranza
                                  hi there,
                                  whats the status on the plugin manager ?! there any chance we see a update anytime soon?
                                    @bsfranza said:
                                    hi there,
                                    What do you think needs updating ?
                                      bsfranza
                                      hey ho,
                                      wasnt there a video once showing how one could save settings, shortcuts, and so on with plugin store?
                                      that would be cool=)
                                      besides that a more complex bundle management would be cool...
                                      .so to see which one is active on at the moment
                                      .the ability to delete unneeded old bundles
                                      .and save under a new name?!
                                      so πŸ˜ƒ
                                      thanks for consideration
                                        caecarvalho
                                        Hi, I'm having a similar problem that the one reported by leminilab, but I get a different response on ruby console:
                                        Error: #<RuntimeError: can't modify frozen String>
                                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:517:in gsub!' c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:517:in chooseplugins'
                                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:473:in autoinstall_dlg' c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:405:in set_autoinstall_choice'
                                        c:/users/caetano/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs:73:in block in new' SketchUp:1:in call'
                                        What happens is that the 'autoinstall' button don't work at all, and the installer inside the SFC menu won't work as well. When I go to the installed plugins, there's no list...
                                        I found a workaround that is installing it in an aditional plugin folder using fredo's plugin. Now that's working, but would be nice to try to understand this problem! I'd appreciate if someone could help with that!
                                        I'm using SU Pro 2015 64-Win 7
                                        Thanks,
                                        Caetano
                                          Thanks,
                                          Caetano
                                          This is a very rare error. πŸ˜•
                                          in fact, so rare that I can say I have never seen it before !
                                          Can you give the result of:
                                          $LOAD_PATH
                                          Also the result of:
                                          SCF_Dialog.custom_plugins()
                                          The 'string' that the .gsub! is applied to is NOT 'frozen', so I can't see what's the issue !
                                            caecarvalho
                                            $LOAD_PATH
                                            Also the result of:
                                            Hi TIG,
                                            Thanks for your fast answer!
                                            $LOAD_PATH
                                            ["C:/Users/CAETANO/Documents/SU Custom Plugin Folder", "C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib", "C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/platform_specific", "C:/Program Files/SketchUp/SketchUp 2015/Tools", "C:/Users/CAETANO/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:\ProgramData/ASGVIS", "C:\ProgramData/ASGVIS/VfS", "C:\ProgramData/ASGVIS/VfS/Ruby", "C:\ProgramData/ASGVIS/VfS/Ruby/images"]
                                            ["C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins", "C:/Users/CAETANO/Documents/SU Custom Plugin Folder"]
                                            After I installed Sketchucation Tools in the custom pluguin folder that I created with Fredo's plugin (Before I've deleted the files, including the ones appdata/local/SFC and appdata/local/temp/SFC), it's working but it won't save in the default location (appdata/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins).It's saying that there's no permitions to install on this folder, instead it's installing on (ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins). So I don't get that first error anymore in the ruby console. And I still don't get the list with the installed plugins.
                                            This problem happened after I restored the default icon for the plugins folder, cause I was having problems with another plugin installation, so I tryied those steps in this link:
                                            http://sketchucation.com/resources/tutorials/811-setting-security-permissions-in-sketchup
                                            The weird think is that the default plugin folder(appdata/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins) seems to have all the permissions...
                                            I have even restored the SU installation, with no success...
                                            I'm really intrigued by this problem! Thanks for taking your time to help!
                                            Best,
                                            Caetano
                                            • 4 / 7
