    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 295.8k Views 135 Watching
    • jeff hammondJ Offline
      @box said:
      It's Ctrl on windows.
      oops.. thought it was ctrl for cmmd & alt for option
      thanks
      • BoxB Offline
        Don't you mean D'oh instead of oops!!?
          I am reassured! πŸ˜„
            πŸ˜† d'oh!
            you're right.
            • emerald15E Offline
              emerald15
              Not so much 'Doh' but 'Eureka'! for me. I've been trying to draw a circle directly to the vertical plane for a least two years! 😳 I only knew it was possible from watching other video clips. At last I've found this thread! πŸ˜„
              http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=53592%26amp;p=486418%26amp;hilit=vertical+plane+circle#p486306
              • pbacotP Offline
                @cotty said:
                I didn't know that you can get non-perpendicular axes 😲
                This seems less like a "Duh!" than "WTF!" What could one (mortal) do with such a thing?
                • Bob JamesB Offline
                  Bob James
                  @jql said:
                  Apologies accepted if you post it on the Duh thread!
                  So here goes my duh:
                  @bob james said:
                  This seems so simple that it must already exist, but I could not find it.
                  For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
                  I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
                  I apologize if this already exists
                  @jql said:
                  LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
                  Or you can make your life painless if you draw a 4 sided polygon without exploding it.
                  Those two are native tools. Do you forget sketchup also has native tools?
                  @bob james said:
                  Duh 😳
                  (But still think it would be a useful one-click native tool) πŸ˜†
                  • JQLJ Offline
                    JQL
                    πŸ‘Ώ All that ::DUH:: belong to us! πŸ‘Ώ
                    www.casca.pt
                    Visit us on facebook!
                    • S ShepherdS Offline
                      S Shepherd
                      I just today noticed with solid tools, if you subtract a transparent solid from another shape it leaves behind transparent faces. I suppose I mostly paint after these operations are complete.
                      Shep
                        roland joseph
                        Didn't have a clue till today that while you push pull you can add a face by hitting "ctrl" on a pc or "option" on a Mac
                        • cottyC Offline
                          cotty
                          A little one...
                          I've had problems with drag&drop of images from the web browser to SU. No I've found the reason: I've changed the startup rights for SU to "always start as administrator". After changing this for the browser too (or both without these rights), drag&drop is back again...
                          my SketchUp gallery
                          • piratebrianP Offline
                            piratebrian
                            When taking one surface and copy pasting it into an unrelated group, if you click on the destination surface before you do the control-v paste you newly placed surface will auto align. Found this one by accident, it is probably page 2 of the instructions, But bahhh instructions.
                              Thx to JQL πŸ˜„
                              Move Copy a group
                              if you double-click it, you edit it, andeven if you do nothing on it, it is made into a different definition, therefor "unique".
                              Not sure that was on the manual ? πŸ˜„
                              • AureusA Offline
                                Aureus
                                I forgot what this tread is about but no doubt - it's a record breaking thread: probably the longest living thread here.
                                Like a submarine. Just when you think it's down it goes up to the surface. Over and over again. πŸ˜„
                                • JQLJ Offline
                                  JQL
                                  @pilou said:
                                  Thx to JQL πŸ˜„
                                  It's the second time I make one of you hotshots have a duh moment! First it was Bob!
                                  www.casca.pt
                                  • cottyC Offline
                                    cotty
                                    Followme: path and shape in different context
                                    I've always copied a path into a group to do a followme, but you can enter that group after you have selected the path with the followme tool...
                                    my SketchUp gallery
                                    • BoxB Offline
                                      But be aware Cotty,that doing it with the path in a group will give you strange results.
                                      • JQLJ Offline
                                        JQL
                                        Box, those strange results are only due to geometry. Your two circles are not orthogonal to each other so the start and ending are not coherent with the rest of the path. That's what that message means and it's not related to the path's/profile context.
                                        www.casca.pt
                                        • BoxB Offline
                                          I beg to differ. The circles are set to make a sphere.
                                          • cottyC Offline
                                            cotty
                                            I think the reason is the different axis for the group (you can see both in BOXs gif). the follow me uses the path circle, but with the global axis.
                                            my SketchUp gallery
                                            • 34
                                            • 35
                                            • 2 / 35
