    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Gormon
      Terribly enrages! I don't see the button or the link to downloading of very useful plug-in. Marasmus!
        Really? It's very clearly spelled out in the first post of the thread. 😒
          Almost all Plugins are now hosted on the SketchUcation PluginStore page.
          The page in question links to that directly...
          http://sketchucation.com/pluginstore?pln=RoundCorner
          Or you can browse the many entries yourself - by search, by author, by recent etc...
          Also please note that most of Fredo's tools also require his LibFredo installed.
          That is also available from the PluginStore - again it's linked...
          http://sketchucation.com/pluginstore?pln=LibFredo6
          I trust you know how the install RBZ files ?
          http://sketchucation.com/resources/tutorials/beginner/108-installing-sketchup-plugins
            gokhan0322
            thnx bro 👍
              Stepanov
              good afternoon!
              I can not download the plugin
              I do not see download button
                GĂĄbor
                Do you have AdBlock on? Do you see the advertisements on the site?
                As the site is maintained partly based on the support from advertisers, only those are allowed to download plugins who do not block ads.
                  pvidal
                  Hi there!
                  I have a serveral issue to round a complex edge
                  http://www.becam.com.uy/SU/roundCorner_issues_0002.jpg
                  when I check whith the solid Inspector plugin, the result is fine
                  http://www.becam.com.uy/SU/roundCorner_issues_0001.jpg
                  I set the round Corner Plugin and run
                  http://www.becam.com.uy/SU/roundCorner_issues_0003.jpg
                  and the result is full of surfaces borders and internal faces edges.
                  http://www.becam.com.uy/SU/roundCorner_issues_0004.jpg
                  can you tellme why?
                  Thanks a lot!
                    Too small. Try scaling the model up by a factor of 100 or more before running Round Corners.
                      pvidal
                      Thanks Dave
                      But, when I scaling up the model, it is not necessary also scale the offset factor too?
                      in this case the problem is not still happening?
                      thanks
                        Yes. You have to scale the offset by the same factor.
                          pvidal
                          When I do, the errors in geometry are the same, like if I had not scaled...
                            Then maybe x1000 ?
                              pvidal
                              I just do that!, and still happens.
                              I go upload a .skp file and a picture of the element what I need model.
                              Is a Sheet of steel, what simulate a tile roof.
                              http://www.becam.com.uy/SU/stellShet_TileRoof.jpg
                              a thousand of thanks!!
                              PD: the escale in the skp file is 1000/1
                              SU version: Sketchup Pro 2014
                              • gillesG Offline
                                gilles
                                Don't know how you did this but your model is full of bad geometries, a basic profile push-pull should provide good geometries.
                                Round corner will go crazy trying to round this.
                                Redraw from scratch.
                                  pvidal
                                  Thanks Gilles!
                                  I did the model from two extruded shapes and intersect them, after I generate the shape of the phase shift, like the components in the file I upload before, then I explode all components. (basicly)
                                    roland joseph
                                    This place is pretty strange some times....
                                    [quote][/Really? It's very clearly spelled out in the first post of the thread.[quote]
                                    Sure ...clear as mud....They are asking for a "download" button....not a colored product dissertation on one page. The fact is the layout of those pages is a font/color/sizing/css mess.
                                    • F Offline
                                      forrest
                                      I've installed with SketchUcation Plugin Store 2.6.1 in SketchUp 2015, and I have installed LibFredo 6.7c, but it tells me every time I start SketchUp that I need LibFredo 6.3 or greater. Is something missing? RoundCorner never starts.
                                        Have you tried installing the newest copy of Round Corner / Lib via the SCF Plugin Store?
                                        • Z Offline
                                          zanthus
                                          Thanks Fredo6
                                            tmophoto
                                            why is it so hard to install and get these plugins to work? why dont you have them available in the extensions warehouse?
                                            are there any other options for rounding corners in sketchup? I have just wasted half a day trying to get this to work
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 72 / 74
