    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • PixeroP
      Pixero
      I have the same problem on my Macbook Pro with Bootcamp and Windows 8.1.
      A way of setting the size to fit a certain resolution would be great.
        mrjumpmanv2
        Hey,
        I'm trying to download Roundcorner for sketchup 2015 on windows
        I've tried downloading it on sketchucation's plugin downloader
        and everytime i try and find it it doesn't show up anywhere. I've
        checked the toolbars menu and the extensions tab under preferences
        and it's not there. Every time I start up sketchup it gives me this error.
        Is this plugin supposed to work with sketchup 2015? Let me know if there's
        any more information i can add to help you help me.
        Regards,
        Christian S.
        %(#000040)["Anyone who has never made a mistake has never tried anything new."
        Albert Einstein]
          All of Fredo's tools should work with v2015, but you need to install the latest versions from the PluginStore.
          AND you must have the latest version of LibFredo installed also available there...
          http://sketchucation.com/pluginstore?pln=LibFredo6
          The invalid byte UTF-8 suggests an older file version.
          It also sometimes occurs with file-paths including weird accented characters etc [although your user-path looks innocuous enough !]
          Another issue might be if you have copied over lots of files from an earlier SketchUp version's Plugins folder - you might have copied some old files across which are incompatible/unwanted - wherever possible you should always install fresh/latest copies when setting up your new SketchUp version...
          If getting the LibFredo etc doesn't fix things, then please provide screenshot[s] of your Plugins folder's contents, so we can see if you have any old/wrong files that need removing... 🤓
          • N
            NicholasElliott
            How do you download the file in the first place!?
            I need the link to the file in order to install… there used to be a clear button that said ‘DOWNLOAD’!
            Where has that gone!?
              From the first post in this thread:
              It seems pretty clear to me. Do you need more help than that?
                Almost every Plugin's RBZ in the SketchUcation PluginStore has a red 'Download' button.
                This downloads the RBZ onto your compuyter so you can install it...
                In the SketchUcation PluginStore Toolset dialog that is red 'AutoInstall' button, this skips the download step and simple installs it for you...
                There are clear links in that post to the PluginStore's pages with the Download button...
                For both the Plugin itself and the Lib helper that it needs...
                How easier could we make it ? 😕
                  aounallah anis
                  hi
                  • G
                    Gormon
                    Terribly enrages! I don't see the button or the link to downloading of very useful plug-in. Marasmus!
                      Really? It's very clearly spelled out in the first post of the thread. 😒
                        Almost all Plugins are now hosted on the SketchUcation PluginStore page.
                        The page in question links to that directly...
                        http://sketchucation.com/pluginstore?pln=RoundCorner
                        Or you can browse the many entries yourself - by search, by author, by recent etc...
                        Also please note that most of Fredo's tools also require his LibFredo installed.
                        That is also available from the PluginStore - again it's linked...
                        I trust you know how the install RBZ files ?
                        http://sketchucation.com/resources/tutorials/beginner/108-installing-sketchup-plugins
                        • G
                          gokhan0322
                          thnx bro 👍
                            Stepanov
                            good afternoon!
                            I can not download the plugin
                            I do not see download button
                            • G
                              GĂĄbor
                              Do you have AdBlock on? Do you see the advertisements on the site?
                              As the site is maintained partly based on the support from advertisers, only those are allowed to download plugins who do not block ads.
                              • P
                                pvidal
                                Hi there!
                                I have a serveral issue to round a complex edge
                                http://www.becam.com.uy/SU/roundCorner_issues_0002.jpg
                                when I check whith the solid Inspector plugin, the result is fine
                                http://www.becam.com.uy/SU/roundCorner_issues_0001.jpg
                                I set the round Corner Plugin and run
                                http://www.becam.com.uy/SU/roundCorner_issues_0003.jpg
                                and the result is full of surfaces borders and internal faces edges.
                                http://www.becam.com.uy/SU/roundCorner_issues_0004.jpg
                                can you tellme why?
                                Thanks a lot!
                                  Too small. Try scaling the model up by a factor of 100 or more before running Round Corners.
                                  • P
                                    pvidal
                                    Thanks Dave
                                    But, when I scaling up the model, it is not necessary also scale the offset factor too?
                                    in this case the problem is not still happening?
                                    thanks
                                      Yes. You have to scale the offset by the same factor.
                                      • P
                                        pvidal
                                        When I do, the errors in geometry are the same, like if I had not scaled...
                                          Then maybe x1000 ?
                                          • P
                                            pvidal
                                            I just do that!, and still happens.
                                            I go upload a .skp file and a picture of the element what I need model.
                                            Is a Sheet of steel, what simulate a tile roof.
                                            http://www.becam.com.uy/SU/stellShet_TileRoof.jpg
                                            a thousand of thanks!!
                                            PD: the escale in the skp file is 1000/1
                                            SU version: Sketchup Pro 2014
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 74
                                            • 75
                                            • 51 / 75
