    [Plugin] UCS Manager
    34 Posts 10 Posters 12.9k Views 10 Watching
    • EdsonE Offline
      Edson
      here you have a skp file with 5 UCSs registered, from 01 to 05. if you still want me to run the attributes thing, let me know.
      you forgot to attach it.
      UCS_Manager_test.skp
      http://www.mahfuz.arq.br
      • Didier BurD Offline
        Didier Bur
        @Edson:
        I'm puzzled: there's only one UCS registered in you file. I've added 2 new UCS named 02 and 03 with no problem. I send you the file back, please check if they can be listed once back on your Mac.
        P.S.: forget the attribute manager, the listing UCS command does the same job.
        Regards,
        DB
        • EdsonE Offline
          Edson
          I am puzzled too. the UCSs you created are listed on my mac. however, I created UCS 04 and it did not register again.
            gbu
            Hi Didier, will be very useful but have exactly the same problem on my mac- did you resolve? or is there an update for mac? Thanks
              I have updated this tool for Didier, now to be compatible from SketchUp v8 up to v2015.
              It will also now load from any suitably set up Plugins folder [in $:], rather than just the default Plugins folder...
              The latest version [1.0.0x] is in the PluginStore http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0
                tommy.jhd
                Hello,
                TIG's update brought the following error:
                Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb
                uninitialized constant DBUR_Ucs::TRError Loading File DBUR_UcsManager.rb
                ...which I think is a similar error message to what happens when you try and load UCS manager from an alternate plugin folder.
                The standard v1.0.0 loads fine (from standard plugin folder)
                Is the solution obvious?
                I've been fiddling with Didier's ArcCircle+ rb, trying and failing to get it to work from an alternate pligin location. If UCS can be fixed, I'll attempt the equivalent on ArcCircle+ - and perhaps save you the bother.
                T
                  @tommy.jhd said:
                  Hello,
                  T
                  I'll check it out...
                  Many of Didier's scripts do mess up if a non-standard Plugins folder is used...
                  I thought I found all the culprits... maybe not.
                    Here is an updated version.
                    Please ensure that you have no other versions loading from other Plugins folder locations...
                      tommy.jhd
                      Hi TIG,
                      no sorry still exact same error message. UCS is the only plugin in the standard folder
                      (haven't tried running it from an alternate location yet) Tested on two separate desktops.
                      Is it working for you though?
                        It works fine for me ???
                        Please check you only have the one copy installed.
                        An earlier version loading from another Plugins folder would mess you up, as it'll overwrite the standard folder's version.
                        Can you also post the path to your standard folder - obtained from this in the Ruby Console.
                        Sketchup.find_support_file('Plugins')
                        Also I get this:
                        DBUR_Ucs::TR
                        {"UCS Manager"=>"UCS Manager", "Save and restore User Coordinates Systems"=>"Save and restore User Coordinates Systems", "Save a User Coordinates System"=>"Save a User Coordinates System", "Restore a User Coordinates System"=>"Restore a User Coordinates System", "Delete a User Coordinates System"=>"Delete a User Coordinates System", "Save UCS"=>"Save UCS", "Restore UCS"=>"Restore UCS", "Delete UCS"=>"Delete UCS", "List UCS"=>"List UCS", "List User Coordinates Systems"=>"List User Coordinates Systems", "UCS main dialog"=>"UCS main dialog", "Pick UCS origin"=>"Pick UCS origin", "New UCS name: "=>"New UCS name: ", "Unnamed"=>"Unnamed", "Existing UCS: "=>"Existing UCS: ", "Select UCS"=>"Select UCS", "No UCS in this model."=>"No UCS in this model.", "Select existing UCS"=>"Select existing UCS", "Name: "=>"Name: ", "Origin: "=>"Origin: ", "X Axis: "=>"X Axis: ", "Y Axis: "=>"Y Axis: ", "Z Axis: "=>"Z Axis: "}
                        I'll make a slightly different version which sets up ' TR' differently, but I can't see why it fails for you !
                          Here's an update http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0 It have recast some of the code making the Translation hash - it's no longer set up inside the RBS, it's now done in the subfolder's RB before loading the RBS at all.
                          At least that way we might get different error messages 😕
                          Please retry and report back...
                            tommy.jhd
                            Hi TIG
                            UCS manager is now loading without error - when located in standard plugins location, and in alternate locations.
                            However the following errors appear on use:
                            Error: #<NoMethodError: undefined method list_all_ucs' for DBUR_Ucs:Module> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:61 Error: #<NameError: uninitialized constant DBUR_Ucs::SaveUCSTool> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:61:in call'
                            Error: #<NameError: uninitialized constant DBUR_Ucs::RestoreUCSTool>
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:47
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40:in call' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:40 Error: #<NoMethodError: undefined method erase_ucs' for DBUR_Ucs:Module>
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:54
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:47:in `call'
                            As requested
                            ..and...
                            DBUR_Ucs::TR
                            {"Existing UCS: "=>"Existing UCS: ", "Save a User Coordinates System"=>"Save a User Coordinates System", "Origin: "=>"Origin: ", "Select UCS"=>"Select UCS", "List User Coordinates Systems"=>"List User Coordinates Systems", "Save UCS"=>"Save UCS", "Restore a User Coordinates System"=>"Restore a User Coordinates System", "Y Axis: "=>"Y Axis: ", "Delete a User Coordinates System"=>"Delete a User Coordinates System", "Unnamed"=>"Unnamed", "Pick UCS origin"=>"Pick UCS origin", "New UCS name: "=>"New UCS name: ", "Z Axis: "=>"Z Axis: ", "Name: "=>"Name: ", "List UCS"=>"List UCS", "UCS Manager"=>"UCS Manager", "X Axis: "=>"X Axis: ", "Restore UCS"=>"Restore UCS", "Save and restore User Coordinates Systems"=>"Save and restore User Coordinates Systems", "Select existing UCS"=>"Select existing UCS", "UCS main dialog"=>"UCS main dialog", "Delete UCS"=>"Delete UCS", "No UCS in this model."=>"No UCS in this model."}
                            Thank you again (sorry for taking a few day to test and get back to you)
                            T
                              This is weird...
                              I'll do some more investigations...
                                Here's an update http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0 Some of its encrypted 'class' methods have been adjusted so they might now [hopefully] work better with earlier versions of SketchUp...
                                  tommy.jhd
                                  Exactly the same error messages, I'm afraid.
                                  Would you like me to PM you them? (rather than saturating the thread with error messages)
                                    Please copy+paste these three lines [one at a time] into the Ruby Console and report the three results...
                                    ` load('DBUR_UcsManager.rb')
                                    load('DBUR_UcsManager/DBUR_UcsManager.rb')
                                    Sketchup.load('DBUR_UcsManager/dbur_ucs.rbs')`
                                    Then, in that same session, retry using the tool...
                                      tommy.jhd
                                      true
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb:29: warning: already initialized constant TR
                                      true
                                      false
                                      Tool replies same error messages as before
                                      Original version replies: true, true, false - with no elaboration or warnings
                                        I'll PM you a possible solution...
                                          lord anubis
                                          And gents, did you solve it?
                                            Djé 0
                                            It would be a great improvement if we could choose the orientation of the three axes and not only the origin point, like the native "placer" tool.
                                            • 2 / 2
