    [Plugin] UCS Manager
    34 Posts 10 Posters 12.9k Views 10 Watching
    • Didier BurD Offline
      Didier Bur
      Hi Georges,
      When you register (save) an UCS, the only operation you have to do is to click at the origin of that UCS, no need to click on the 3 axes. As you can see, the cursor still have the correct orientation of XYZ axes. You'll only have to click the axes orientations when you restore a previously saved UCS.
      This is explained in the PDF doc included in the resources folder of the plugin. I've attached it here.
      Regards,
      UCS Manager.pdf
      DB
      • PixeroP Offline
        Pixero
        Thanks. Will be useful. 👍
          glro
          @didier bur said:
          Hi Georges,
          Regards,
          i understand now; thank you
          maybe it would be useful to register automatically the UCS that comes by default with the sketchup model; otherwise you have to do it manually each time you create a new one
          the limit for the plugin seems to come from sketchup itself; for example, moving components with J FOLTZ's plugin mover2.rb, is according the original UCS, no matter which new UCS has been created and is active
            Didier Bur
            @Giro:
            No, there's no need to do so, to reset the default axes, just right-click on an axis of your current UCS and select "Reset".
            Regards,
            DB
              glro
              @didier bur said:
              @Giro:
              Regards,
              oh... i didn't know that
              thank you
              i add this information in my copy of your documentation
              • EdsonE Offline
                Edson
                hi didier,
                as simple to operatte as this plugin may seem to be, I am having trouble with it.
                I have no problem saving the first custom axes position. but after the first it will not save any other. I am stuck with just one custom axes system.
                I am probably doing something wrong. but what?
                I use mac os x.
                regards.
                http://www.mahfuz.arq.br
                  Didier Bur
                  Hi Edson,
                  I suppose each time you register a new UCS you give it a unique name, right ?
                  Can you do this test: register 2 or 3 different UCS, then call the attributes manager to see if these UCS have been correctly stored as attribute dictionaries.
                  See attached image: in this example, I have registered 3 UCS named 11,12, and 13, so I have 3 attribute dictionaries named UCS_11, UCS_12, and UCS_13.
                  If that's no the case on your side, I'll have to further investigate what's wrong with the script on Mac.
                  Regards,
                  DB
                  • EdsonE Offline
                    Edson
                    didier,
                    I created three UCSs: 01, 02 and 03. then I clicked on List UCS and it shows only the first one (see below).
                    please. forgive my thickness but I do not know where is the Attributes Manager you mentioned. is there such a thing on mac?
                      Didier Bur
                      The attributes manager is an old thing by Google released in 2007. I have attached it here.
                      But the 'list UCS' command of my plugin retrieves the attribute dictionaries of your UCS and just displays them in another way. I see that your UCS aren't registered the way they should be 😞
                      Anyone on Mac encountered the same problem ?
                      I've tested the plugin on a Mac and it works OK.
                      Edson, can you send me a SKP with several registered UCS ?
                      DB
                      • EdsonE Offline
                        Edson
                        here you have a skp file with 5 UCSs registered, from 01 to 05. if you still want me to run the attributes thing, let me know.
                        you forgot to attach it.
                        UCS_Manager_test.skp
                          Didier Bur
                          @Edson:
                          I'm puzzled: there's only one UCS registered in you file. I've added 2 new UCS named 02 and 03 with no problem. I send you the file back, please check if they can be listed once back on your Mac.
                          P.S.: forget the attribute manager, the listing UCS command does the same job.
                          Regards,
                          DB
                          • EdsonE Offline
                            Edson
                            I am puzzled too. the UCSs you created are listed on my mac. however, I created UCS 04 and it did not register again.
                              gbu
                              Hi Didier, will be very useful but have exactly the same problem on my mac- did you resolve? or is there an update for mac? Thanks
                                I have updated this tool for Didier, now to be compatible from SketchUp v8 up to v2015.
                                It will also now load from any suitably set up Plugins folder [in $:], rather than just the default Plugins folder...
                                The latest version [1.0.0x] is in the PluginStore http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0
                                  tommy.jhd
                                  Hello,
                                  TIG's update brought the following error:
                                  Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb
                                  uninitialized constant DBUR_Ucs::TRError Loading File DBUR_UcsManager.rb
                                  ...which I think is a similar error message to what happens when you try and load UCS manager from an alternate plugin folder.
                                  The standard v1.0.0 loads fine (from standard plugin folder)
                                  Is the solution obvious?
                                  I've been fiddling with Didier's ArcCircle+ rb, trying and failing to get it to work from an alternate pligin location. If UCS can be fixed, I'll attempt the equivalent on ArcCircle+ - and perhaps save you the bother.
                                  T
                                    @tommy.jhd said:
                                    Hello,
                                    T
                                    I'll check it out...
                                    Many of Didier's scripts do mess up if a non-standard Plugins folder is used...
                                    I thought I found all the culprits... maybe not.
                                      Here is an updated version.
                                      Please ensure that you have no other versions loading from other Plugins folder locations...
                                        tommy.jhd
                                        Hi TIG,
                                        no sorry still exact same error message. UCS is the only plugin in the standard folder
                                        (haven't tried running it from an alternate location yet) Tested on two separate desktops.
                                        Is it working for you though?
                                          It works fine for me ???
                                          Please check you only have the one copy installed.
                                          An earlier version loading from another Plugins folder would mess you up, as it'll overwrite the standard folder's version.
                                          Can you also post the path to your standard folder - obtained from this in the Ruby Console.
                                          Sketchup.find_support_file('Plugins')
                                          Also I get this:
                                          DBUR_Ucs::TR
                                          {"UCS Manager"=>"UCS Manager", "Save and restore User Coordinates Systems"=>"Save and restore User Coordinates Systems", "Save a User Coordinates System"=>"Save a User Coordinates System", "Restore a User Coordinates System"=>"Restore a User Coordinates System", "Delete a User Coordinates System"=>"Delete a User Coordinates System", "Save UCS"=>"Save UCS", "Restore UCS"=>"Restore UCS", "Delete UCS"=>"Delete UCS", "List UCS"=>"List UCS", "List User Coordinates Systems"=>"List User Coordinates Systems", "UCS main dialog"=>"UCS main dialog", "Pick UCS origin"=>"Pick UCS origin", "New UCS name: "=>"New UCS name: ", "Unnamed"=>"Unnamed", "Existing UCS: "=>"Existing UCS: ", "Select UCS"=>"Select UCS", "No UCS in this model."=>"No UCS in this model.", "Select existing UCS"=>"Select existing UCS", "Name: "=>"Name: ", "Origin: "=>"Origin: ", "X Axis: "=>"X Axis: ", "Y Axis: "=>"Y Axis: ", "Z Axis: "=>"Z Axis: "}
                                          I'll make a slightly different version which sets up ' TR' differently, but I can't see why it fails for you !
                                            Here's an update http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0 It have recast some of the code making the Translation hash - it's no longer set up inside the RBS, it's now done in the subfolder's RB before loading the RBS at all.
                                            At least that way we might get different error messages 😕
                                            Please retry and report back...
