    [Plugin] K2WS_Tools a joint tool set for SU
    36 Posts 12 Posters 16.9k Views 12 Watching
    • E
      eneu3
      Thanks for the feedback, TIG.
      The first two times I attempted to install K2WS I used the method of changing the .zip extension to .rbz. I got the file error. Tonight, I manually un-zipped the file and put the folder K2WS_Tools and the loadK2WS_Tools.rb file directly into my Plug-Ins folder.
      I verified all files and folders retained the same order as in the .zip file, just as you indicated. Attached is a jpg file showing the content and structure of my Plug-In folder.
      I still get the same load error.
      I'm running a Mac with OSX 10.7.5. Permissions for Plug-In folder and all contained files and folders is write & read.
      Plug-In file structure and content
        I have finally [re]seen the issue 💭
        The error says the initial loader rb can't find:
        K2WS_Tools\K2_ToolsLoader.rb
        Because you are on a MAC that's not a valid file path.
        It must be K2WS_Tools/K2_ToolsLoader.rb to suit MAC AND PCs.
        The back-slash \ will scrape through on most PCs, but fail on MACs.
        Whereas the forward-slash / will work OK on PCs and MACs.
        To fix this open the file loadK2WS_Tools.rb with TextWrangler or a similar plain-text editor...
        See here... http://sketchucation.com/forums/viewtopic.php?p=352600#p352600
        As reported \ in the require path needs to be a / for MAC compatibility...
        require 'K2WS_Tools\K2_ToolsLoader.rb'
        becomes
        require 'K2WS_Tools/K2_ToolsLoader.rb'
        BUT oddly if you get the latest ZIP off the forum and extract the files loadK2WS_Tools.rb is correctly formed with the /
        Presumably these and a few other issues were reworked by the author after the initial reports/testing in 2011!!
        So the question arises where did you get the older incorrect version from ?
        Get the latest ZIP from the first post - that is already correctly configured.
        Extract its contents and convince yourself about the lack of a \ in the 'require'...
        Make sure ALL of the files and subfolder equivalents in the extracted set are manually removed from your users Plugins folder [also check the other Plugins folder in the HD path is similarly emptied too !]
        Rename the ZIP with .rbz at the end and use the AutoInstall feature under Preferences > Extensions...
        To double check, open the loadK2WS_Tools.rb and ensure the required path is still with / not \
        If it still fails look for other Plugins folders that might be loading an older incorrectly written version ???
        For the avoidance of doubt here's a latest working RBZ version too !
        You can install that directly...
        K2WS_Tools.rbz
        • E
          eneu3
          Thanks for all your help, TIG.
          I now see that if I had read prior posts more carefully I would have found the solution to my problem.
          I began the repair by editing each file by hand. When I realized ALL the supporting files required the same change from \ to /, I took your advice and used the Sketucation archive loader.
          Everything works great now!
          • K
            ktkoh
            I have posted an updated K2WS_Tools version 2.0. See first entry in this subject for some info and the new rbz file. I have sent this to some other users directly so as I hear from them and from this forum I will then add it to the SU Plugin Store.
            Keith
            • T
              trekker
              hi,
              I'm having trouble creating screw holes with your plugin (K2WS_Tools v2.1.0). when creating screw holes on a rounded corner rectangle I got this Error
              Error: #<NoMethodError: undefined method x' for nil:NilClass> C:/Users/ronnie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/K2WS_Tools/K2_ToolsScrewHoles.rb:458:in onLButtonDown'
              but creating screw holes on a rectangle without rounded corner it works.
              What should I do?
              • T
                trekker
                hi,
                What should I do?
                Attached rounded corner.skp
                rounded corner.skp
                  samlion
                  Hi !
                  I'm running Sketchup 2015 and I have problem with the "Loose -tenon joint" and the "Mortise tenon joint". All other option of the tools box seems to run properly. If I use one of those two tools, the program ask me the data for the construction of the tenon and mortise except for the last input screen which ask "Select tool option ? and as I have seen in a tutorial we are supposed to answer a complete tenon and mortise or a complete tenon or a complete mortise. Also, it send to the screen an error message "Problem reading data! ReEnter Data" if I ask to use the existing data.
                  Do you have an idea of the source of the problem ? Thanks in advance for your help.
                  PS.: I have used the tool before and it was running properly for the tenon and mortise. I have not use sketchup since 2 months and I can't identify what change I could have made to my configuration !
                  Add note: I have tried to uninstall sketchup and re-install the software with a fresh copy of the K2WS_Tools. I have the same problem; the tool run, ask for the info and stop without produce the tenon/mortise (return to the drawing as nothing was done).
                  Thanks in advance
                  Richard G.
                  • K
                    ktkoh
                    Sorry to hear you are having trouble with my Tools Plugin. It would help to trouble shoot if you could open the Windows/Ruby Console and report the error message it displays when this happens. I do use my program with make2015 so the problem is not with the 2015 version. I think it could be with the data file that the program makes to store the data for use to reduce the data entry on similar joints. I would also suggest you use the Window Explorer to find the file K2_ToolsLooseTenon.txt and delete this file then try the program again.
                    Keith
                    • K
                      ktkoh
                      Trouble with holes in rounded corner part. This program expects the 2 selected edges to determine the face for holes to intersect @ 90 deg In other words only works on rectangle. in the case of your rounded corner part the program needs a square corner. I would edit the component and add a temp rectangle corner and use that get the program to accept data and it will work if you use user data and enter dim required. Ignore the program reports negative numbers in the user data form. I don't know how you made the part originally but made as a rectangle and add holes before rounding the corners would be how the tool program would expect. I don't know where you want the holes but you should only need to alter 1 corner to get holes down each side and across both ends by using large offset dim from the edge to the CL of holes. Hope this helps.
                      Keith
                      rounded corner.skp
                        samlion
                        Hi Keith,
                        You are a genius! As you suggested to me, I erased files and everything works normally.
                        Once again thank you for your intervention!
                        Richard G.
                        • 2 / 2
