    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 404.0k Views 172 Watching
    • ChisainaC Offline
      Chisaina
      TIG,thank you for the work, but in the 15 SU 64 prоblem with leaves, they are going one on one in one place. Although before generatsiey crosses marked as before, around the trunk.
      Change please as possible this bug. Thank U. And Prastio of language, the use of the machine.
        Thanks for the bug-report. 😕
        It was an easy to find typo, although I can't see how it ever happened !
        The latest version is available here http://sketchucation.com/pluginstore?pln=SketchupIvy I have checked it and it seems to work OK again...
        • ChisainaC Offline
          Chisaina
          TIG, Thanks for the speed
          • cottyC Offline
            cotty
            For me, only the toolbar and not the draw menu entry is working.
            my SketchUp gallery
              Another great bug-report...
              Well spotted !
              It's now fixed.
              Here's the update http://sketchucation.com/pluginstore?pln=SketchupIvy
                maxosmedia
                Bug. As before.
                SHIFT+Click: Created only one branch. No leaves
                Mac OS X 10.9.5, SU 2015
                  @maxosmedia said:
                  Bug. As before.
                  Is this with the very latest version from yesterday ?
                  Have you tried it with the Ruby Console open ?
                  Does it show the magenta branches [Click] ?
                  Does it show the green X markers for the leaves [when Alt+Click MAC] ?
                  On Shift+Click what happens ?
                  Any error messages ?
                  • OxerO Offline
                    Oxer
                    On OS X 10.10.2 & SU2015 if you have Shift locked the plugin doesn't work, see if you have Shift unlocked because for me the plugin works fine.
                      Good tip Oxer. ☀
                      If you have Shift locked you can't hold it + click to complete the Ivy ?
                      Works for other MAC users, so please try Oxer's suggestion...
                        maxosmedia
                        —Y
                        —Y
                        —Y
                        —Y
                        — Created only one branch. No leaves
                        —N
                        • cottyC Offline
                          cotty
                          Well spotted !
                          It's now fixed.
                          Fix confirmed. Thank you!
                          my SketchUp gallery
                            —Y
                            —Y
                            —Y
                            —Y
                            -N
                            Have you followed Oxer's advice about [un]locking-shift_key ?
                            You can also mess up some key-pressing if some aspects of the MAC's keyboard are mis-set !
                            Many other MAC users [including me !] have no issues... so it must be solvable... 😒
                              maxosmedia
                              SU 2014 Sketchup Ivy works fine, SU 2015 — bugs. On the same machine, on the same system, at the same time. keyboard and the keys are not modified
                                This is very weird. 😕
                                There is no discernible difference between v2014 and v2015 Ruby, and the code is just the same on both !
                                  maxosmedia
                                  Ruby console:
                                  Error: #<TypeError: wrong argument type nil (expected Array)> /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:340:inadd_face'
                                  /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:340:in block in birth_stem' /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:323:in each'
                                  /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:323:in birth_stem' /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:312:in birth'
                                  /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:180:in onLButtonUp'
                                  • olisheaO Offline
                                    olishea
                                    Do you have different plugins between 2014 and 2015? A conflict?
                                    oli
                                      Right now we are getting somewhere !
                                      If you set the 'Branch Radius' to 0.0 you will get that error, because you can't have a zero width stem !
                                      These screen shots show the default parameters/settings...
                                      Try resetting back to those...
                                      There are helpful tooltips if you hover over each item...
                                        maxosmedia
                                        TIG, thanks for you advice! All fine!
                                        Perhaps you should make the default setting not "0"?
                                          I'm looking at it right now !
                                            This updated version [0.6.8x] is "fool-proofed" !
                                            It prevents you entering zero values etc as settings which could break the code [it usually defaults to 0.1 if < 0.1 etc ]
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 34 / 37
