    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 545.1k Views 172 Watching
      @maxosmedia said:
      Is this with the very latest version from yesterday ?
      —Y
      Have you tried it with the Ruby Console open ?
      —Y
      Does it show the magenta branches [Click] ?
      —Y
      Does it show the green X markers for the leaves [when Alt+Click MAC] ?
      —Y
      On Shift+Click what happens ?
      — Created only one branch. No leaves
      Any error messages ?
      -N
      Have you followed Oxer's advice about [un]locking-shift_key ?
      You can also mess up some key-pressing if some aspects of the MAC's keyboard are mis-set !
      Many other MAC users [including me !] have no issues... so it must be solvable... 😒
        maxosmedia
        SU 2014 Sketchup Ivy works fine, SU 2015 — bugs. On the same machine, on the same system, at the same time. keyboard and the keys are not modified
          This is very weird. 😕
          There is no discernible difference between v2014 and v2015 Ruby, and the code is just the same on both !
            maxosmedia
            Ruby console:
            Error: #<TypeError: wrong argument type nil (expected Array)> /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:340:inadd_face'
            /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:340:in block in birth_stem' /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:323:in each'
            /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:323:in birth_stem' /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:312:in birth'
            /Users/myusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:180:in onLButtonUp'
            • olisheaO
              olishea
              Do you have different plugins between 2014 and 2015? A conflict?
              oli
                Right now we are getting somewhere !
                If you set the 'Branch Radius' to 0.0 you will get that error, because you can't have a zero width stem !
                These screen shots show the default parameters/settings...
                Try resetting back to those...
                There are helpful tooltips if you hover over each item...
                  maxosmedia
                  TIG, thanks for you advice! All fine!
                  Perhaps you should make the default setting not "0"?
                    I'm looking at it right now !
                      This updated version [0.6.8x] is "fool-proofed" !
                      It prevents you entering zero values etc as settings which could break the code [it usually defaults to 0.1 if < 0.1 etc ]
                      http://sketchucation.com/pluginstore?pln=SketchupIvy
                        maxosmedia
                        Thanks, TIG! Works fine! 😄
                        • KrisidiousK
                          Krisidious
                          You meant Full-Proofed right? 🤣
                          By: Kristoff Rand
                            Jesgargo
                            Hi!
                            Thanks for that amazing plugintool.
                            I have skp2015x64, i install de .rbz file with custom>extension..but when i open skp the subfolder menu doesn´t appear, only the Liveivy icon, but don´t work, don´t do anything. Does it works in skp2015?
                            Thanks a lot!
                            Jesus.
                              @jesgargo said:
                              Hi!
                              Thanks a lot!
                              Jesus.
                              Have you installed it properly from the RBZ using SketchUp's Window > Preferences > Extensions > Install... button ?
                              Was the installation reported as successful ?
                              Have you restarted SketchUp since then ?
                              Note that it is NOT an Extension - it's just a Plugin - so it is NOT in the Preferences > Extensions list.
                              It appears in 'Toolbars' list as 'LiveIvy' - activate it if necessary - launch the tool by clicking the one button on its toolbar.
                              It also appears under the 'Draw' menu as 'Live Ivy Tool', that item also launches the tool...
                              Follow the instructions in its dialog.
                              It has different tabs which allow you to choose different Parameters, Ivy Settings, Leaf Types, and its last two tabs are the 'Help' section - guidance on Usage and the Key presses to modify the results.
                              Although the latest version is now trapped to prevent you completely breaking it - for the avoidance of doubt, the original default settings screen-shots are reprised in this post: http://sketchucation.com/forums/viewtopic.php?p=556406#p556406
                              • B
                                blackdogsketch
                                Wow. This is awesome. Thanks so much.
                                Two questions:
                                1. Maxing "Adhesion" still leaves a significant amount of branches moving away from a wall surface. Is there any way to make the branches stay in contact more? Or to have a may zone that the branches may occupy (say, 6" thick, like real ivy)
                                2. Is it possible to add user-defined jpegs for leaves and bark textures?
                                  Two questions:
                                    I only made 'compatibility' revisions to the OP's code...
                                    If you a look at the code in the various files, then you can try adjust a few things and see what happens...
                                    You can add your own leaf component cutouts - based on your own image textures...
                                    Save them as SKP files in the subfolder ..Plugins//LiveIvy/Textures...
                                    They are available when the tool is first used.
                                    The 'stem.jpg' is used for the stalks' textures, so if you replace that with another it changes in your future ivies...
                                  • B
                                    blackdogsketch
                                    Thanks TIG
                                    Sounds like there's no clear method of getting more ivy to "stick" to the wall.
                                    Hey-While I'm here...thank you for all your incredible work for the SU community!
                                    You make my workflow and professional results better.
                                    • N
                                      namelessone
                                      Perhaps I missed the option, but is it possible to make branches less angular/zip-zappy? The Quality slider adds only more parallel faces, not perpendicular segments 😞 I'd like to make ivy looking better at close ups.
                                      EDIT: If there's no option for that, I guess I could try smoothing/subdividing tools.
                                      • itcamposI
                                        itcampos
                                        Dude, that plugin is trully amazing! Congratulations! 😃
                                        Sadly, I wasn't able to use it within SU2015. The following is the Ruby error log:
                                        Error: #<Encoding::UndefinedConversionError: "\x8D" to UTF-8 in conversion from Windows-1252 to UTF-8>
                                        C:/Users/ÍtallodeAndrade/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:10:in exist?' C:/Users/ÍtallodeAndrade/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:10:in tidyup'
                                        C:/Users/ÍtallodeAndrade/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:18:in <module:LiveIvy>' C:/Users/ÍtallodeAndrade/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:5:in <top (required)>'
                                        D:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' D:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                        C:/Users/ÍtallodeAndrade/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LiveIvy.rb:6:in `<top (required)>'
                                        I really hope it helps.
                                        • C
                                          cfeldman
                                          Thank you !, for this plugins.
                                          Nice work.
                                          ( i had too these idea a lot of time in the mind,--years--
                                          but i know nothing about Programing-actions).
                                          Best regards,
                                          Claudio
                                          • K
                                            Kjammer
                                            Using Sketchup 2015 and the plugin forms the branches but will not form the leaves at all. When I CTRL + Click no leaves are generated, there are no placemarkers for them either..... 😮
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 34 / 37
