    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
    • jujuJ Offline
      juju
      Would all of these contributions be collected and added to the SketchUp Ivy install (download) or would one have to do it yourself? It would be really neat if it could be incorporated.
        driven
        @chedda said:
        For me it grows and works fine in new files. If i try and open a previous project file i can't get the dialog window to open. It seems to stall.
        working on both new and old models here, Yosemite with v15 SU
        • N Offline
          nalibo007
          please i need help..mine is not appearing under plugins and i have pasted it exactly in the plugins folder. iam currently using sketch up pro 2013.....a help wii be appreciated.
          • massimoM Offline
            massimo Moderator
            I don't have this plugin, but in the first post you can see that it should work fine in SU 8-2015 versions. Please don't past anything. Download the .rbz from the first post of this thread (the big button) instead and install it within SU by going to window-->preferences-->extensions-->install extension.
              You have v2013 of SketchUp...
              You do NOT 'paste' anything into the Plugins folder.
              Use Preferences > Extensions > Install.... button to extract the contents of the RBZ file into the correct Plugins folder - all done automatically.
              Since v8 this is the correct way to install RBZ archived plugins...
              Most plugins come in that format - there is no need to ever open you Plugins folder !
              Manually extracting and pasting files is a sure way of ruining your day...
              ALSO, please be aware that not all plugins appear in the Plugins menu [aka Extensions menu in v2015]
              In this case, the 'LiveIvy' tool appears under the Draw menu, and there is also a Toolbar of the same name too...
                rhott311
                Thanks! Great Work! Can confirm the plugin is working in OSX Yosemite in sketchup 8.
                  There's an update...
                  http://sketchucation.com/pluginstore?pln=SketchupIvy
                  It only affects a few users with older versions of SketchUp etc.
                  It should now be glitch free in all versions from v8 to v2015...
                  • KrisidiousK Offline
                    Krisidious
                    Thanks TIG...
                    By: Kristoff Rand
                    • ChisainaC Offline
                      Chisaina
                      TIG,thank you for the work, but in the 15 SU 64 prоblem with leaves, they are going one on one in one place. Although before generatsiey crosses marked as before, around the trunk.
                      Change please as possible this bug. Thank U. And Prastio of language, the use of the machine.
                        Thanks for the bug-report. 😕
                        It was an easy to find typo, although I can't see how it ever happened !
                        The latest version is available here http://sketchucation.com/pluginstore?pln=SketchupIvy I have checked it and it seems to work OK again...
                        • ChisainaC Offline
                          Chisaina
                          TIG, Thanks for the speed
                          • cottyC Offline
                            cotty
                            For me, only the toolbar and not the draw menu entry is working.
                            my SketchUp gallery
                              Another great bug-report...
                              Well spotted !
                              It's now fixed.
                              Here's the update http://sketchucation.com/pluginstore?pln=SketchupIvy
                                maxosmedia
                                Bug. As before.
                                SHIFT+Click: Created only one branch. No leaves
                                Mac OS X 10.9.5, SU 2015
                                  @maxosmedia said:
                                  Bug. As before.
                                  Is this with the very latest version from yesterday ?
                                  Have you tried it with the Ruby Console open ?
                                  Does it show the magenta branches [Click] ?
                                  Does it show the green X markers for the leaves [when Alt+Click MAC] ?
                                  On Shift+Click what happens ?
                                  Any error messages ?
                                  • OxerO Offline
                                    Oxer
                                    On OS X 10.10.2 & SU2015 if you have Shift locked the plugin doesn't work, see if you have Shift unlocked because for me the plugin works fine.
                                      Good tip Oxer. ☀
                                      If you have Shift locked you can't hold it + click to complete the Ivy ?
                                      Works for other MAC users, so please try Oxer's suggestion...
                                        maxosmedia
                                        —Y
                                        —Y
                                        —Y
                                        —Y
                                        — Created only one branch. No leaves
                                        —N
                                        • cottyC Offline
                                          cotty
                                          Well spotted !
                                          It's now fixed.
                                          Fix confirmed. Thank you!
                                          my SketchUp gallery
                                            —Y
                                            —Y
                                            —Y
                                            —Y
                                            -N
                                            Have you followed Oxer's advice about [un]locking-shift_key ?
                                            You can also mess up some key-pressing if some aspects of the MAC's keyboard are mis-set !
                                            Many other MAC users [including me !] have no issues... so it must be solvable... 😒
                                            • 36
                                            • 37
                                            • 6 / 37
