    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 454.4k Views 172 Watching
    • KrisidiousK Offline
      Krisidious
      Thanks a lot for squaring this thing up Tig. It's nice to have it back in the stable.
      By: Kristoff Rand
      • cheddaC Offline
        chedda
        Yes thanks for your work on this. I can launch the dialog window in new simple files. But for some reason i cannot launch this in existing model files. skp 2014 mac osx 10.9.5 Perhaps it is conflicting with the maxwell plugin ?
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
          maxosmedia
          Does not work properly with SU 2015 (Mac OS X 10.9.5) — makes only one branch, no leaves. With SU 2014 everything is ok
          • OxerO Offline
            Oxer
            For me it works fine on SU2014/15 & OSX 10.9.5, remember the keys on Mac:
            Start grow ivy -->Click
            To make grow ivy to the mouse position-->CMD +Click
            Make leafs -->ALT+Click
            Finish the ivy --> SHIFT+Click
            Reset the ivy--> i key
              maxosmedia
              • cheddaC Offline
                chedda
                For me it grows and works fine in new files. If i try and open a previous project file i can't get the dialog window to open. It seems to stall.
                  MalyJacek
                  I see response to my request to add the ability to choose the leaves.
                  In the summer I started doing sets of components for the various plants.
                  They are in varying degrees of completion. https://dl.dropboxusercontent.com/u/32445396/ivyleaf_pasthenocissus.zip
                  Here is a package for "wild vine" (Parthenocissus) is not 100% like I wanted but one of the curiosities that I wanted to enter. Namely, they are leaves added on two layers of autumn (jesień) and summer (lato) allowing you to quickly change the color by switching layer.
                  In the future, if you have enough creative inspiration and I will try to finish the remaining sets I am working on and share them.
                  Sorry for the grammatical errors have not practiced my English for a long long time
                    MalyJacek
                    Great that you were able to add choices of leaves which I asked about.
                    I made a set of leaves for "wild vine" (I do not know the name in English in quotes I gave direct translation of common name in Polish ) in Latin it is Parthenocissus. Characterized by the fact that in the summer the leaves are green but autumn color change to dark red and do not fall for a long time because of that I wanted to add it to the model and more or less succeeded. Leaf models are double on two separate layers thanks to which switching between one and the other can changed season. 😄
                    In the future, if I have enough creative inspiration to finish the remaining sets for other plants I will also share them.
                    Sorry for language mistakes I have not practiced writing in English for a long time
                      Krisidious
                      Your English is just fine MalyJacek... Really nice contribution.
                      By: Kristoff Rand
                      • jujuJ Offline
                        juju
                        Would all of these contributions be collected and added to the SketchUp Ivy install (download) or would one have to do it yourself? It would be really neat if it could be incorporated.
                          driven
                          working on both new and old models here, Yosemite with v15 SU
                          • N Offline
                            nalibo007
                            please i need help..mine is not appearing under plugins and i have pasted it exactly in the plugins folder. iam currently using sketch up pro 2013.....a help wii be appreciated.
                            • massimoM Offline
                              massimo Moderator
                              I don't have this plugin, but in the first post you can see that it should work fine in SU 8-2015 versions. Please don't past anything. Download the .rbz from the first post of this thread (the big button) instead and install it within SU by going to window-->preferences-->extensions-->install extension.
                                You have v2013 of SketchUp...
                                You do NOT 'paste' anything into the Plugins folder.
                                Use Preferences > Extensions > Install.... button to extract the contents of the RBZ file into the correct Plugins folder - all done automatically.
                                Since v8 this is the correct way to install RBZ archived plugins...
                                Most plugins come in that format - there is no need to ever open you Plugins folder !
                                Manually extracting and pasting files is a sure way of ruining your day...
                                ALSO, please be aware that not all plugins appear in the Plugins menu [aka Extensions menu in v2015]
                                In this case, the 'LiveIvy' tool appears under the Draw menu, and there is also a Toolbar of the same name too...
                                  rhott311
                                  Thanks! Great Work! Can confirm the plugin is working in OSX Yosemite in sketchup 8.
                                    There's an update...
                                    http://sketchucation.com/pluginstore?pln=SketchupIvy
                                    It only affects a few users with older versions of SketchUp etc.
                                    It should now be glitch free in all versions from v8 to v2015...
                                      Krisidious
                                      Thanks TIG...
                                      By: Kristoff Rand
                                      • ChisainaC Offline
                                        Chisaina
                                        TIG,thank you for the work, but in the 15 SU 64 prоblem with leaves, they are going one on one in one place. Although before generatsiey crosses marked as before, around the trunk.
                                        Change please as possible this bug. Thank U. And Prastio of language, the use of the machine.
                                          Thanks for the bug-report. 😕
                                          It was an easy to find typo, although I can't see how it ever happened !
                                          The latest version is available here http://sketchucation.com/pluginstore?pln=SketchupIvy I have checked it and it seems to work OK again...
                                          • ChisainaC Offline
                                            Chisaina
                                            TIG, Thanks for the speed
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 33 / 37
