    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 64.1k Views 24 Watching
    • SkalpS
      Skalp
      @jql said:
      Will become a standard... Thanks!
      If you like these materials, you can easily make them yourself with the Skalp Pattern Designer. You get the Skalp Pattern Designerfor free with Skalp for SketchUp.
      The video show how you can make this kind of tileable patterns:
      Skalp
      http://www.skalp4sketchup.com
      • JQLJ
        JQL
        For a while that I want to try Skalp. Though with current projects I don't want to break my current workflow, I will try it on my next project for sure.
        One question:
        If I use this set of materials on my current projects withouth skalp installed, will they export as dwg hatches after skalp is installed?
        That would make a lot of difference and I would anticipate Skalp trial, so I'm looking forward to your reply.
        www.casca.pt
        Visit us on facebook!
        • SkalpS
          Skalp
          One question:
          The short answer is NO. You can't use these patterns manually the way Skalp uses these Skalp materials.
          But maybe if you explain your workflow today and show me an example I can give you a more correct answer.
          Guy
          Skalp
          • JQLJ
            JQL
            I will send you a PM
            www.casca.pt
            • B
              bsfranza
              well..
              feature request=)
              -automatically generate some special lines for geometry that is invisible because above the cut plane and also something for the geometry that is hidden...
              other then that its awesome as is...
              • SkalpS
                Skalp
                @bsfranza said:
                well..
                feature request=)
                πŸ˜„ have a little patience
                Skalp
                • B
                  bsfranza
                  hi there,
                  got one more ... maybe its already said somewhere but:
                  custom cut planes/elevations would be awesome - so we could have cuts at different heights/depths at once...
                  greetings
                  • SkalpS
                    Skalp
                    We just released a new Skalp for SketchUp 1.0 maintenance release.
                    This maintenance release has a lot of improvements on DXF export:
                    • handle model units instead of inches
                    • patterns are scaled correctly in dxf
                    • drawing order fill, hatch and outline is corrected
                    • batch export to dxf of all scenes at once
                    • skalp styles can be uses to control the layers in dxf
                    • skalp style option to export sections in dxf to the same layer of the sectioned object
                    • the exported dxf is now zoomed out correctly when opening
                    The pattern designer now has the option to export all skalp materials for 2D use in Layout.
                    There are also a lot of other small fixes which you can read about in the release notes
                    You can download this latest version from the 'SketchUcation Plugin Store' or from our download page. You can also read the full release notes at the download page.
                    Skalp
                    • SkalpS
                      Skalp
                      Upcoming new feature... Skalp material 'Align with Object'
                      Skalp materials will have the option to automatically align to the longest edge of the assigned SketchUp object. This is very useful for materials like insulation and plywood...
                      More nice features to come in the next months...
                      Buy Skalp for SketchUp 1.0 NOW and you get all this new features for FREE
                      BUY NOW
                      Skalp
                        seasdes
                        Does my computer need to be connected to the internet for Skalp to work? Some plugins require this.
                        Using Sketchup Pro 2019
                        • SkalpS
                          Skalp
                          You only need an internet connection the first to time to activate Skalp.
                          The Skalp Team
                          Skalp
                          • SkalpS
                            Skalp
                            With the Skalp for SketchUp new feature 'Align by Object' you can do automatically timber or insulation hatching!
                            You can even export this hatches to dxf!
                            'Align by Object' will be part of Skalp for SketchUp 1.1 which will be released in a couple of days and will be a FREE update for all our users.
                            The Skalp Team
                            Skalp
                            • jujuJ
                              juju
                              πŸ‘
                              β˜€
                              • TommyKT
                                TommyK
                                @juju said:
                                :ecstatic:
                                πŸ‘
                                β˜€
                                +1
                                πŸ˜„ β˜€
                                • TommyKT
                                  TommyK
                                  I am loving the "Align to object" feature. Makes my sections look prettier.
                                  Skalp is now firmly in my workflow. To make it even smoother, may I suggest a small additional feature. When one has the Pattern Designer window open, I would like it to display the material that the eyedropper tool selects. It would make adjustments to how things look a little quicker. It shouldn't be too difficult from a technical point of view, as you can use the ToolsObserver in the Ruby API.
                                  Just something to add to that list!
                                  • SkalpS
                                    Skalp
                                    For our users from the Netherlands we made a component with the NEN hatchings for use in Skalp for SketchUp.
                                    Place this component in your model or your template and you have access to all the 'NEN hatchings' inside Skalp.
                                    You can edit this hatchings with the Skalp Pattern Designer.
                                    NEN arceringen.skp
                                    Skalp
                                    • jujuJ
                                      juju
                                      At SKALP:
                                      How often do you update the extension warehouse with your latest version / revision? It seems they are still with a much earlier version than what is available from your website.
                                      • SkalpS
                                        Skalp
                                        juju,
                                        The problem is that every new version / update is checked by the SketchUp team before it is published. At this moment we are fixing some issues with undo on demand of the SketchUp team. The problem is we need to do some workaround because SketchUp doesn't have an undo on scene operation.
                                        Normally it shouldn't be a problem that the version on the extension warehouse is an old one. You get automatically an update from our website when you restart Skalp.
                                        Kind regards,
                                        The Skalp Team
                                        Skalp
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          I feel you, that's a big issue πŸ˜•
                                          • SkalpS
                                            Skalp
                                            Drawing insulation, bat insulation and timberpatterns is always been hard to do with CAD.
                                            Skalp for SketchUp has introduced the **'Align by Pattern'**option. Now it's easy to get correct hatched insulation, bat insulation and timber.
                                            Skalp
                                            • 6 / 9
