    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 64.1k Views 24 Watching
    • O
      otb designworks
      I've trying to integrate Skalp into my normal workflow, but the experience has been less than satisfying. I sent the following report to their support team 5 days ago and, other than three automated responses saying they got my report, there has been no response at all. I figured it couldn't hurt to post it here, too, in the interest of jumpstarting a dialogue. And, I was wondering if anyone else was experiencing these weirdnesses.
      Hi! I have been using Skalp (or trying to) since a few beta tests ago and am now trying thee first release version. I thought you would be interested in hearing my experiences.
      I am finding Skalp inconstant and frustrating enough to stop using it as part of my regular workflow.
      I am running OS10.9.5 and SU 2015.
      Some of my frustrations include:
      1. I am experiencing lots of peculiarity with respect to consistent scene display.  I have my scenes set with skalp sections and everything is perfect for a while, but then, with no warning, a particular scene won’t display a section correctly.   Sometimes it won’t show the section, or it will only cut part of the geometry, or it will display nothing.
      2.	I had a file with Skalp sections.  As an experiment, I unloaded the skalp plugin and erased all of the skalp layers.  Before I did that, I copied all of the sections.  Once everything Skalp related was deleted I pasted the sections back into the model.  These sections acted very oddly and I ended up having to delete them.  It’s hard to explain, but sometimes the active section wouldn’t update in the scene, or a scene without an active section would inherit the active section from another scene without me updating the scene.  In the end, the entire file had to be deleted to get sections and scenes behaving properly.  It was if Skalp left vestiges of itself in the file, from before Skalp had been deleted from Sketchup that negatively impacted the model.
      3.	Once I had all my Skalp layers and sections arranged per the user guide, I went into layout and started setting up viewports.  I had unending issues with the viewports not correctly displaying Skalp scenes!  The viewport would go completely blank sometimes (editing the viewport and zoom extents did NOT bring anything back; the viewport would remain completely empty, regardless of scene chosen).  Once it displayed empty, I had to delete the viewport and set up another one to get my scene displaying again.  Some viewports were showing lines in the section that did not appear in the sketchup scene; very weird.  The issues were so unending that it was completely unusable.  And yes, I was updating the Skalp sections for Layout, per the user guide.
      4.	Skalp will inconsistently  fill in section faces.  I noticed this particularly when I had faces inside solids, which I needed for the section to show the line between joist and flooring, for example.  I had a cladding layer that was an extruded rectangle with inside faces to show the border between 1/2” sheathing and 3/4” siding and Skalp would never close off both the 1/2” and the 3/4” portion; it always left the 1/2” portion un filled.  I obviously can’t use Skalp if it can’t predictably close all the faces.  And if Skalp doesn’t display the face, then what can be done to coax it to display a face?  I assume nothing, so, if it doesn’t show a face, then I am out of luck?
      So, all in all, a pretty disappointing experience. especially since I had such high hopes for what could be a fantastic extension to sketchup. I want this plugin to work beautifully as it is very impressive when it works correctly and predictably and I would always use it if I could produce drawings to my satisfaction. At least on my system, I would not call this a release-ready version. It is a start in the right direction, but not, in my opinion, ready for prime time.
      Thank you for taking the time to read this. I haven’t seen anyone else complaining on the sketchucation site, so perhaps I am having isolated issues and, hopefully, I am missing something basic in the instructions, but I am pretty confident I am following the protocols laid out in the user guide.
      Cheers, Chuck
      OTB Designworks is on Youtube
      • SkalpS
        Skalp
        Hello Chuck,
        We would very much like to look at these things together with you to see what exactly is going on, why, and what actions can be done to improve your experiences. Most likely we can both learn and benefit from exchanging our mutual knowledge on using SketchUp with Skalp. We will contact you via mail and take your call from there.
        Note to SketchUcation readers: We consider feedback very valuable and will always try to listen and be open in our communication. Please understand that we do prefer to handle support directly and personally. Please feel free to contact us at support@skalp4sketchup.com for your questions on Skalp.
        Kind Regards,
        the Skalp team
        Skalp
        http://www.skalp4sketchup.com
        • TommyKT
          TommyK
          This sometimes happens to me too. Sometimes, there is a delay before the section appears, at other times, it is showing an older version of the section, and sometimes it doesn't update/show at all. In all cases, I do the following:
          1. select the scene tab again
          2. if that doesn't work, click on another scene, then click back into the original scene.
          The above workarounds have worked for me quite consistently.
          As for your other issues, I haven't had them. I might try the following:
          for 3:
          • are you sure that the scene saves all information about a scene (ie, camera position, shadow settings, fog settings, styles, etc). Check on the Scenes window, and expand it to show the deeper scene settings. Bit of a "duh" suggestion, but I've done it before.
          • KrisidiousK
            Krisidious
            I've pretty much been experiencing everything Chuck has... It's made me gun shy to use it on my next project because of all the work it took to get the scenes done and then to have them all gone when I get to layout. The tool seems a little over complicated at this stage.
            By: Kristoff Rand
            • B
              bsfranza
              hi there,
              what features do you plan to integrate into 1.xxx is there somekind of roadmap you can grand us access to=)
              • SkalpS
                Skalp
                @bsfranza said:
                hi there,
                Of course we have some kind of a roadmap, but we don't make it public to keep the pressure away.
                One thing I can tell you... You'll love the new features 😄
                You are welcome to send us your wishlist.
                The Skalp Team
                Skalp
                • SkalpS
                  Skalp
                  120 free Skalp materials...
                  All materials can be edited with the Skalp Pattern Designer. You can change the size, the line and background color, and the line weight.
                  When exporting your Skalp section to dxf the patterns will be replaced by autocad pattern definitions.
                  Download the materials from the SketchUp 3D warehouse:
                  https://3dwarehouse.sketchup.com/model.html?id=uf2fc60f5-87e8-4abb-9e16-e5597e711fb4
                  Skalp
                  • JQLJ
                    JQL
                    Will become a standard... Thanks!
                    www.casca.pt
                    Visit us on facebook!
                    • SkalpS
                      Skalp
                      If you like these materials, you can easily make them yourself with the Skalp Pattern Designer. You get the Skalp Pattern Designerfor free with Skalp for SketchUp.
                      The video show how you can make this kind of tileable patterns:
                      Skalp
                      • JQLJ
                        JQL
                        For a while that I want to try Skalp. Though with current projects I don't want to break my current workflow, I will try it on my next project for sure.
                        One question:
                        If I use this set of materials on my current projects withouth skalp installed, will they export as dwg hatches after skalp is installed?
                        That would make a lot of difference and I would anticipate Skalp trial, so I'm looking forward to your reply.
                        www.casca.pt
                        • SkalpS
                          Skalp
                          One question:
                          The short answer is NO. You can't use these patterns manually the way Skalp uses these Skalp materials.
                          But maybe if you explain your workflow today and show me an example I can give you a more correct answer.
                          Guy
                          Skalp
                          • JQLJ
                            JQL
                            I will send you a PM
                            www.casca.pt
                            • B
                              bsfranza
                              well..
                              feature request=)
                              -automatically generate some special lines for geometry that is invisible because above the cut plane and also something for the geometry that is hidden...
                              other then that its awesome as is...
                              • SkalpS
                                Skalp
                                @bsfranza said:
                                well..
                                feature request=)
                                😄 have a little patience
                                Skalp
                                • B
                                  bsfranza
                                  hi there,
                                  got one more ... maybe its already said somewhere but:
                                  custom cut planes/elevations would be awesome - so we could have cuts at different heights/depths at once...
                                  greetings
                                  • SkalpS
                                    Skalp
                                    We just released a new Skalp for SketchUp 1.0 maintenance release.
                                    This maintenance release has a lot of improvements on DXF export:
                                    • handle model units instead of inches
                                    • patterns are scaled correctly in dxf
                                    • drawing order fill, hatch and outline is corrected
                                    • batch export to dxf of all scenes at once
                                    • skalp styles can be uses to control the layers in dxf
                                    • skalp style option to export sections in dxf to the same layer of the sectioned object
                                    • the exported dxf is now zoomed out correctly when opening
                                    The pattern designer now has the option to export all skalp materials for 2D use in Layout.
                                    There are also a lot of other small fixes which you can read about in the release notes
                                    You can download this latest version from the 'SketchUcation Plugin Store' or from our download page. You can also read the full release notes at the download page.
                                    Skalp
                                    • SkalpS
                                      Skalp
                                      Upcoming new feature... Skalp material 'Align with Object'
                                      Skalp materials will have the option to automatically align to the longest edge of the assigned SketchUp object. This is very useful for materials like insulation and plywood...
                                      More nice features to come in the next months...
                                      Buy Skalp for SketchUp 1.0 NOW and you get all this new features for FREE
                                      BUY NOW
                                      Skalp
                                        seasdes
                                        Does my computer need to be connected to the internet for Skalp to work? Some plugins require this.
                                        Using Sketchup Pro 2019
                                        • SkalpS
                                          Skalp
                                          You only need an internet connection the first to time to activate Skalp.
                                          The Skalp Team
                                          Skalp
                                          • SkalpS
                                            Skalp
                                            With the Skalp for SketchUp new feature 'Align by Object' you can do automatically timber or insulation hatching!
                                            You can even export this hatches to dxf!
                                            'Align by Object' will be part of Skalp for SketchUp 1.1 which will be released in a couple of days and will be a FREE update for all our users.
                                            The Skalp Team
                                            Skalp
                                            • 5 / 9
