    [Plugin] Skalp for SketchUp v2.0 (live section plugin)
    172 Posts 24 Posters 49.8k Views 24 Watching
    • SkalpS Offline
      Skalp
      @seasdes said:
      Does my computer need to be connected to the internet for Skalp to work? Some plugins require this.
      You only need an internet connection the first to time to activate Skalp.
      The Skalp Team
      Skalp
      http://www.skalp4sketchup.com
      • SkalpS Offline
        Skalp
        With the Skalp for SketchUp new feature 'Align by Object' you can do automatically timber or insulation hatching!
        You can even export this hatches to dxf!
        'Align by Object' will be part of Skalp for SketchUp 1.1 which will be released in a couple of days and will be a FREE update for all our users.
        The Skalp Team
        Skalp
        • jujuJ Offline
          juju
          πŸ‘
          β˜€
          • TommyKT Offline
            TommyK
            @juju said:
            :ecstatic:
            πŸ‘
            β˜€
            +1
            πŸ˜„ β˜€
            • TommyKT Offline
              TommyK
              I am loving the "Align to object" feature. Makes my sections look prettier.
              Skalp is now firmly in my workflow. To make it even smoother, may I suggest a small additional feature. When one has the Pattern Designer window open, I would like it to display the material that the eyedropper tool selects. It would make adjustments to how things look a little quicker. It shouldn't be too difficult from a technical point of view, as you can use the ToolsObserver in the Ruby API.
              Just something to add to that list!
              • SkalpS Offline
                Skalp
                For our users from the Netherlands we made a component with the NEN hatchings for use in Skalp for SketchUp.
                Place this component in your model or your template and you have access to all the 'NEN hatchings' inside Skalp.
                You can edit this hatchings with the Skalp Pattern Designer.
                NEN arceringen.skp
                Skalp for SketchUp
                Skalp (www.skalp4sketchup.com)
                Skalp
                • jujuJ Offline
                  juju
                  At SKALP:
                  How often do you update the extension warehouse with your latest version / revision? It seems they are still with a much earlier version than what is available from your website.
                  • SkalpS Offline
                    Skalp
                    juju,
                    The problem is that every new version / update is checked by the SketchUp team before it is published. At this moment we are fixing some issues with undo on demand of the SketchUp team. The problem is we need to do some workaround because SketchUp doesn't have an undo on scene operation.
                    Normally it shouldn't be a problem that the version on the extension warehouse is an old one. You get automatically an update from our website when you restart Skalp.
                    Kind regards,
                    The Skalp Team
                    Skalp
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      I feel you, that's a big issue πŸ˜•
                      • SkalpS Offline
                        Skalp
                        Drawing insulation, bat insulation and timberpatterns is always been hard to do with CAD.
                        Skalp for SketchUp has introduced the **'Align by Pattern'**option. Now it's easy to get correct hatched insulation, bat insulation and timber.
                        Skalp
                        • JQLJ Offline
                          JQL
                          Nice feature. I suppose that doesn't work with a section cutting the roof 90 degrees from that one nor with multiple thickness insulations? Or have you found a way to do it too?
                          www.casca.pt
                          Visit us on facebook!
                          • SkalpS Offline
                            Skalp
                            At this moment you need to create different materials for different thickness.
                            Can you explain what you meant by 'section cutting the roof 90 degrees'?
                            The Skalp Team
                            Skalp
                            • SkalpS Offline
                              Skalp
                              If you want to start with Skalp for SketchUp, you should definitely watch the getting started video tutorial...
                              Skalp
                              • utilerU Offline
                                utiler
                                Hi Skalp, I have a question about the plugin. I've had it now for some time and have recently made time to get into it and learn property. What I'm wondering is will we be about to convert the raster to linework in Layout oat some stage?
                                The reason for asking is quite simple. Generally, architetural graphics is monochrome [black and white]. Sure we all produce coloured plans, elevations, etc but if I want to create plans and sections that are black and white I can't if my model is coloured as the only way to show Skalp textures is, well by texture.
                                What do you think the solution of this to be?
                                Just Curious...
                                • SkalpS Offline
                                  Skalp
                                  2014 was the year we launched Skalp for SketchUp... and it was a huge success!
                                  2015 will be the year we introduce a lot of new features to keep Skalp the best section tool for SketchUp!
                                  Skalp
                                  • SkalpS Offline
                                    Skalp
                                    Utiler,
                                    We fully understand this question. And we have already two solutions built-in Skalp:
                                    1. Skalp pattern layers.
                                    With Skalp pattern layers we use the special behavior from the 'color by layer' option in combination with the 'hidden line' render mode. The 'hidden line' render mode normally shows the model fully in white,except when you use the 'color by layer' mode and have a texture attached to the layer instead of a color. Then everything is white except the faces which are on the layers with the textures attached. These elements are textured with the attached textures even if they are colored. This option gives you the ability to texture / color your model for you 3D presentation or rendering and make a 'color by layer' setup for your architectural drawings.
                                    You can setup a Skalp style to send the section result to special 'Skalp Pattern Layers' for use with this method. The only problem is that the SketchUp API has a missing feature to attach a texture to a layer. The following video's show how you can setup this way of working. With Skalp you can setup a Skalp Style for every scene. This way you can define scenes for use in SketchUp (full colored) and scenes for generating drawings (black and white).
                                    for windows:
                                    for mac:
                                    2. dxf export
                                    Skalp as the ability to export your sketchUp section to dxf including the vector hatching.
                                    This way it's very easy to create architectural drawings with AutoCAD or other CAD software (draftSight is a free autocad clone). At this moment (version Skalp 1.1) only the section can be exported and you need to export the hidden lines with the 2D dwg/dxf export function of SketchUp and combine the results together in AutoCAD. In our next update Skalp 1.5 (this update is free for all our 1.x users) this hidden lines will be also automatically generated by Skalp.
                                    The Skalp Team
                                    Skalp
                                    • JQLJ Offline
                                      JQL
                                      The Skalp Team
                                      90 degrees from that section means selecting that in the image and rotating it 90 degrees.
                                      I understand that when the section turns out real dimension of the roof you are able to align the size of the hatch. But there are many cases where the dimension of the hatch in the section should stretch to fit the roof section. Will it fit?
                                      There's an example in the image below:
                                      www.casca.pt
                                      • utilerU Offline
                                        utiler
                                        Thanks guys, I should have looked further at your tuts.... β˜€
                                        Your second video showing the ability to export to DXF is great for those who wish to do so but how about if we are just exporting to Layout? I always convert to Hybrid mode in Layout to ensure sharp, clean lines for my drawings and I have noticed tat the images aren't very clear when doing so.
                                        Just Curious...
                                        • SkalpS Offline
                                          Skalp
                                          Skalp materials are optimized to be printed. Layout rasterize everything to 300 dpi (high) or 150dpi (medium) depending on the Document Setup > Paper > Rendering Resolution > Output quality setting. Even if you use vector, the lines will be rasterized by you printer driver before it’s send to the printer. Only a pen plotter plots real vector information.
                                          Skalp materials are made at 300dpi considering the chosen scale. This means if you use a skalp material on the correct scale you get the best result your printer can print. If you zoom in on your screen this texture look jagged and blurry.
                                          The Skalp Team
                                          Skalp
                                          • SkalpS Offline
                                            Skalp
                                            @jql said:
                                            The Skalp Team
                                            [attachment=0:1k1954jb]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:1k1954jb]
                                            No, at this moment the size will not automatically be adjusted. Probably in further releases this will change, but we are still looking for the most general way.
                                            The Skalp Team.
                                            Skalp
                                            • 6 / 9
