    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 79.9k Views 20 Watching
      driven
      @Tig
      sorry, just trying to help out, thought you were at pub...
      it's failing with only two models to import...
      removing the puts helps sometimes,
      pre-saving the model helps sometimes,
      adding the UI.messagebox helps sometimes...
      but if I try a larger folder it bugsplats again...
        OK, I'll check it out - not a bug reports for years, then three come at once...
        Maybe it needs updating...
          I just revisited this Plugins code.
          As it was, it still worked fine for me on multiple SKP imports, but I have made some adjustments because the SKP import could now be more 'streamlined' > SUp v8...
          Here's the updated v1.4 RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=import_from_folder
          Please try it and feedback.
          PS: Rich - you can email me the 126 SKPs in a ZIP if you like ?
            driven
            bug splat on mac...
            there are some weird names, but I import them as a test folder for my icon maker plugin, and they were importing then failing last night...
            full folder content
            .DS_Store
            .png
            ¨„¶®™_·_Ë‚„‡¢†´Æ¨.skp
            ¨„¶®™_·_™†°•´•¨.skp
            ¨„¶®™_·_™†≠®·‚‡Æ©.skp
            ¨„¶®™_·_™‡†·™Æ©.skp
            ¨„¶®™_·Æ_·‚•‚Á®™Æ¨_£•©£•‡†.skp
            ¨„¶®™_®_™‡Î·†.skp
            ¨„¶®™_≠†_´•·‚≠®Ê•.skp
            ¨„¶®™_߆_·‚ƴƨ.skp
            ¨„¶®™®_·_°ÆÁ™†¨®.skp
            ¨„¶®™®_¢_™Æ´Æ§Ê•.skp
            £Æ´Î©_¨„¶®™.skp
            file_names from folder.scpt
            filenames.txt
            Ø®‡Æ‚•Â≠®™.skp
            ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_1.skp
            ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_2.skp
            ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_3.skp
            ØÆ¶†‡≠Ω_·_‚ÆØÆ‡Æ¨.skp
            ØÆ¶†‡≠Ω_·_Æ£≠•‚„Ë®‚•´•¨.skp
            ØÆ¶†‡≠Ω_≠†_Ë•·‚•.skp
            ØÆ¶†‡≠Ω_1.skp
            ØÆ¶†‡≠Ω_2.skp
            ØÆ¶†‡≠Ω_3.skp
            ØÆ¶†‡≠Ω_3~.skp
            ru_aviator.skp
            ru_blueSanta.skp
            ru_garbageCollect.skp
            ru_glassman.skp
            ru_jackHammer_male.skp
            ru_jackHammer.skp
            ru_leafBlower.skp
            ru_plumBob.skp
            ru_surveyor.skp
            ru_welder.skp
            ru_wheelBarrow.skp
            welder.skp
              They are weird SKP names !
              What happens with a simpler set of 'sensible' names ??
              Maybe I need to try and force the file path's encoding to UTF-8 if >=v2014 ?
              Are they all real SKPs ?
              Is their version <= SUp version you are using ?
              If it's > then you will get an 'empty-skp' message for each one...
                Here's v1.5, it forces the file names to UTF-8 in >v2014 to see if that addresses file-type errors
                  I'll email files later.
                  But no weird characters except _
                    driven
                    @tig
                    no joy, it's failing on even a simple 2 skp, good filenames folder...
                    the other folder names are deliberately obnoxious to represent a 'user' folder, but the names all show in message bar as they are found...
                      So this begs the question, "why does it work OK for me ?"
                        You on Win8.1?
                          driven
                          :roll:
                          have you run it on your mac?
                            Win7 64bit, v2015 64bit... also works in v8 32bit etc...
                              I won't get near laptop until 9pm.
                              But I will test then.
                                No rush... I'm asleep right now 😉
                                  • Y
                                    YoungOSG
                                    @tig said:
                                    @Young
                                    You code is overly complicated.
                                    It also has some odd working practices... 😕
                                    I am sure I have answered this same query elsewhere...
                                    See the @yuyuwhy posts...
                                    Is it you, but with a different user-name ??
                                    http://sketchucation.com/forums/viewtopic.php?p=554042#p554042
                                    This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong !
                                    Do that BEFORE importing anything.
                                    It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn.
                                    If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all.
                                    Recast your code thus...
                                    Make the host SKP empty.
                                    Process the list of DAE files in turn.
                                    Use a model.start_operation(...) block around each iterate step.
                                    Remember to use the model.abort_operation to undo the import etc, but leave the export intact.
                                    You should end up with an empty SKP and all of the DAE files processed.
                                    Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
                                    Thanks!! I tried and it works!
                                    And I want to import *.dae file with 2000 jpg.However Sketchup stop at 10%. It do not warn me anything.
                                    could you help me ?
                                      Here's v1.6 http://sketchucation.com/pluginstore?pln=import_from_folder It is overhauled to ensure that SKP file imports do not BugSplat - which was an unpredictable issue with multiple SKP files, especially those including un-purged dross.
                                      Rather than use 'import' for SKP files, it now uses 'load' on them, which adds their definitions to the model and depending on the user's choice, it either leaves them as unused Component-Browser definitions, or it also places an instance of each of them at [0,0,0]...
                                        McSquizzy
                                        This tool is exactly what I am looking for but having problems with it. I am having some issues with collada (.dae) files. The tool seems to operate properly until it completes. Once it has stepped through all of the collada files, it says it has completed but does not render any of the data. I am left with an empty SketchUp model. I am using it with v2014. I have tried this plugin with .skp files and worked perfectly.
                                          appgeo
                                          I installed successfully to Sketchup Make Version 16, 32 bit on Windows PC running Windows 7.
                                          Imported 4 small .DAE files and report says successful. However, nothing shows up on screen.
                                          These files load fine when using the "File, Import" dialog in Sketchup, one at a time.
                                          In "File, Import" dialog you have to place imported DAE file manually. Plug in does not ask. I always insert at origin of the model, so that would be fine. What am I doing wrong?
                                          Thanks! Fred
                                          • H
                                            harnstein
                                            Hi @TIG,
                                            I'm working on modeling a bunch of objects from photo reference. Therefore I used your plugin to mass import image files.
                                            They come in nicely arranged next to each other - unfortunately they're all in random order..??
                                            Their original filename is DSC_XXX, I tried batch renaming it to incremental numbers but that didnt solve it.
                                            Any idea how to solve this?
                                            Many thanks as usual 😄 Niko
                                            still sketchin'
                                            • 3 / 4
