    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 73.2k Views 20 Watching
      @john
      hahahaha
      even that didn't help...
      I'm trying to import 126 faceme .skp then run components to grid.
      I ain't getting past the import all part as yet.
      SU2015 64bit Pro in case that helps?
        driven
        seriously now...
        I just tested it and had a splat as well, sent it to trimble...
        I'll have a look a the report
          na na nana na
            driven
            @rich line 101 delete puts re-save, restart...
            worked for me
              nope! splat
                driven
                keep the puts deleted, but on line 106 add an new line UI.messagebox(name)
                try on a small number of skps first
                just to see if slowing it down helps...
                  That means you need to press OK 126 times !
                  Rich, why not ZIP and email me those 126 SKPs, explain [clearly] what you want to do...
                    driven
                    @Tig
                    sorry, just trying to help out, thought you were at pub...
                    it's failing with only two models to import...
                    removing the puts helps sometimes,
                    pre-saving the model helps sometimes,
                    adding the UI.messagebox helps sometimes...
                    but if I try a larger folder it bugsplats again...
                      OK, I'll check it out - not a bug reports for years, then three come at once...
                      Maybe it needs updating...
                        I just revisited this Plugins code.
                        As it was, it still worked fine for me on multiple SKP imports, but I have made some adjustments because the SKP import could now be more 'streamlined' > SUp v8...
                        Here's the updated v1.4 RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=import_from_folder
                        Please try it and feedback.
                        PS: Rich - you can email me the 126 SKPs in a ZIP if you like ?
                          driven
                          bug splat on mac...
                          there are some weird names, but I import them as a test folder for my icon maker plugin, and they were importing then failing last night...
                          full folder content
                          .DS_Store
                          .png
                          ¨„¶®™_·_Ë‚„‡¢†´Æ¨.skp
                          ¨„¶®™_·_™†°•´•¨.skp
                          ¨„¶®™_·_™†≠®·‚‡Æ©.skp
                          ¨„¶®™_·_™‡†·™Æ©.skp
                          ¨„¶®™_·Æ_·‚•‚Á®™Æ¨_£•©£•‡†.skp
                          ¨„¶®™_®_™‡Î·†.skp
                          ¨„¶®™_≠†_´•·‚≠®Ê•.skp
                          ¨„¶®™_߆_·‚ƴƨ.skp
                          ¨„¶®™®_·_°ÆÁ™†¨®.skp
                          ¨„¶®™®_¢_™Æ´Æ§Ê•.skp
                          £Æ´Î©_¨„¶®™.skp
                          file_names from folder.scpt
                          filenames.txt
                          Ø®‡Æ‚•Â≠®™.skp
                          ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_1.skp
                          ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_2.skp
                          ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_3.skp
                          ØÆ¶†‡≠Ω_·_‚ÆØÆ‡Æ¨.skp
                          ØÆ¶†‡≠Ω_·_Æ£≠•‚„Ë®‚•´•¨.skp
                          ØÆ¶†‡≠Ω_≠†_Ë•·‚•.skp
                          ØÆ¶†‡≠Ω_1.skp
                          ØÆ¶†‡≠Ω_2.skp
                          ØÆ¶†‡≠Ω_3.skp
                          ØÆ¶†‡≠Ω_3~.skp
                          ru_aviator.skp
                          ru_blueSanta.skp
                          ru_garbageCollect.skp
                          ru_glassman.skp
                          ru_jackHammer_male.skp
                          ru_jackHammer.skp
                          ru_leafBlower.skp
                          ru_plumBob.skp
                          ru_surveyor.skp
                          ru_welder.skp
                          ru_wheelBarrow.skp
                          welder.skp
                            They are weird SKP names !
                            What happens with a simpler set of 'sensible' names ??
                            Maybe I need to try and force the file path's encoding to UTF-8 if >=v2014 ?
                            Are they all real SKPs ?
                            Is their version <= SUp version you are using ?
                            If it's > then you will get an 'empty-skp' message for each one...
                              Here's v1.5, it forces the file names to UTF-8 in >v2014 to see if that addresses file-type errors
                                I'll email files later.
                                But no weird characters except _
                                  driven
                                  @tig
                                  no joy, it's failing on even a simple 2 skp, good filenames folder...
                                  the other folder names are deliberately obnoxious to represent a 'user' folder, but the names all show in message bar as they are found...
                                    So this begs the question, "why does it work OK for me ?"
                                      You on Win8.1?
                                        driven
                                        :roll:
                                        have you run it on your mac?
                                          Win7 64bit, v2015 64bit... also works in v8 32bit etc...
                                            I won't get near laptop until 9pm.
                                            But I will test then.
                                            • 3 / 4
