    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 78.7k Views 20 Watching
      This is splatting for me?
      No console message. Just splat!
      I try nuke my plugins older to isolate
        driven
        @rich,
        maybe your need to watch the tutorial?
          @john
          hahahaha
          even that didn't help...
          I'm trying to import 126 faceme .skp then run components to grid.
          I ain't getting past the import all part as yet.
          SU2015 64bit Pro in case that helps?
            driven
            seriously now...
            I just tested it and had a splat as well, sent it to trimble...
            I'll have a look a the report
              na na nana na
                driven
                @rich line 101 delete puts re-save, restart...
                worked for me
                  nope! splat
                    driven
                    keep the puts deleted, but on line 106 add an new line UI.messagebox(name)
                    try on a small number of skps first
                    just to see if slowing it down helps...
                      That means you need to press OK 126 times !
                      Rich, why not ZIP and email me those 126 SKPs, explain [clearly] what you want to do...
                        driven
                        @Tig
                        sorry, just trying to help out, thought you were at pub...
                        it's failing with only two models to import...
                        removing the puts helps sometimes,
                        pre-saving the model helps sometimes,
                        adding the UI.messagebox helps sometimes...
                        but if I try a larger folder it bugsplats again...
                          OK, I'll check it out - not a bug reports for years, then three come at once...
                          Maybe it needs updating...
                            I just revisited this Plugins code.
                            As it was, it still worked fine for me on multiple SKP imports, but I have made some adjustments because the SKP import could now be more 'streamlined' > SUp v8...
                            Here's the updated v1.4 RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=import_from_folder
                            Please try it and feedback.
                            PS: Rich - you can email me the 126 SKPs in a ZIP if you like ?
                              driven
                              bug splat on mac...
                              there are some weird names, but I import them as a test folder for my icon maker plugin, and they were importing then failing last night...
                              full folder content
                              .DS_Store
                              .png
                              ¨„¶®™_·_Ë‚„‡¢†´Æ¨.skp
                              ¨„¶®™_·_™†°•´•¨.skp
                              ¨„¶®™_·_™†≠®·‚‡Æ©.skp
                              ¨„¶®™_·_™‡†·™Æ©.skp
                              ¨„¶®™_·Æ_·‚•‚Á®™Æ¨_£•©£•‡†.skp
                              ¨„¶®™_®_™‡Î·†.skp
                              ¨„¶®™_≠†_´•·‚≠®Ê•.skp
                              ¨„¶®™_߆_·‚ƴƨ.skp
                              ¨„¶®™®_·_°ÆÁ™†¨®.skp
                              ¨„¶®™®_¢_™Æ´Æ§Ê•.skp
                              £Æ´Î©_¨„¶®™.skp
                              file_names from folder.scpt
                              filenames.txt
                              Ø®‡Æ‚•Â≠®™.skp
                              ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_1.skp
                              ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_2.skp
                              ØÆ¶†‡≠Ε_·Æ_·‚¢Æ´Æ¨_3.skp
                              ØÆ¶†‡≠Ω_·_‚ÆØÆ‡Æ¨.skp
                              ØÆ¶†‡≠Ω_·_Æ£≠•‚„Ë®‚•´•¨.skp
                              ØÆ¶†‡≠Ω_≠†_Ë•·‚•.skp
                              ØÆ¶†‡≠Ω_1.skp
                              ØÆ¶†‡≠Ω_2.skp
                              ØÆ¶†‡≠Ω_3.skp
                              ØÆ¶†‡≠Ω_3~.skp
                              ru_aviator.skp
                              ru_blueSanta.skp
                              ru_garbageCollect.skp
                              ru_glassman.skp
                              ru_jackHammer_male.skp
                              ru_jackHammer.skp
                              ru_leafBlower.skp
                              ru_plumBob.skp
                              ru_surveyor.skp
                              ru_welder.skp
                              ru_wheelBarrow.skp
                              welder.skp
                                They are weird SKP names !
                                What happens with a simpler set of 'sensible' names ??
                                Maybe I need to try and force the file path's encoding to UTF-8 if >=v2014 ?
                                Are they all real SKPs ?
                                Is their version <= SUp version you are using ?
                                If it's > then you will get an 'empty-skp' message for each one...
                                  Here's v1.5, it forces the file names to UTF-8 in >v2014 to see if that addresses file-type errors
                                    I'll email files later.
                                    But no weird characters except _
                                      driven
                                      @tig
                                      no joy, it's failing on even a simple 2 skp, good filenames folder...
                                      the other folder names are deliberately obnoxious to represent a 'user' folder, but the names all show in message bar as they are found...
                                        So this begs the question, "why does it work OK for me ?"
                                          You on Win8.1?
                                            driven
                                            :roll:
                                            have you run it on your mac?
                                            • 3 / 4
