    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 213.3k Views 75 Watching
      sketchitbrk
      Thanks For the new update much appreciated
      • E
        ervau
        Hi!
        Yes - it is a great plugin. But...
        Can you imagine, what kind of error I'm producing with the Roof-Plugin here?
        • On the first shape it worked fine (so you can see...) (Pic 1)
        • When I want to use it on the second shape, all I get is a Bugsplat 😞 (Pic 2)
        Do you need the Buglog of SketchUp? (I can't read the .dmp-file...)
        FYI: I'm using SU 2013 Pro (V 13.0.4124) and Roof 3.7 just new downloaded.
        Thanks a lot!
        Robert
        Screenshot: 1st roof worked fine. 2nd shape produces bugsplat...
        Screenshot: All I get :-(
          Delete the face and recreate it by drawing over the8 edges in a clockwise direction.
          The face will reform try re-roofing...
          Also try reversing the face.
          Or copying it above, group it, delete the original, move the face-group over the original location and explode it, this can fix edge weirdnesses...
          • E
            ervau
            Thanks for the hint.
            Doesn't work either - unfortunately.
            I've deleted the face. By drawing the first edge, it reappeared - grrr.
            So, I've copied it (z more than 0, I've learned above πŸ˜‰ ) and drawn the eddes by reference lines. Deleted the face and the edges and drawn it all clockwise.
            Bugsplat again.
            Ha!!! There it was: Before I used the plugin, I turned the face correctly. Without turning it (the backside above) it works!
            So long
            Robert
              sokeuyhaw
              it's nice plugin and work as well in sketchup pro 2014 thanks TIG
                Mill29
                Very great tool, thanks a lot!
                • G
                  grim
                  πŸ‘Ž hipped does not seem to work in SU2015 is this correct for anyone else????
                    It should work in all versions...
                    I'll double-check...
                    Did you install the latest version from the PluginStore ?
                    http://sketchucation.com/pluginstore?pln=Roof
                      It worked for me in SU2015.
                      • G
                        grim
                        thanks for the input, i have removed it and reloaded it a couple of times it seamed to clash with onion dome which also did not work removing onion dome and reinstalling roof ----------- now works
                        thankyou
                        • H
                          huckrorick
                          I just installed the latest version.
                          I made a simple rectangle. Selected the face.
                          Went to Plugins>Roof>Hip
                          no matter what combination of parameters I use I get a message saying:
                          "Hipped Roof Error.
                          It was not possible to make a single pitch hipped roof from this face."
                          What could be the problem.
                          Using SketchUp 8 Pro, Windows 8.1
                          • KrisidiousK
                            Krisidious
                            @huckrorick said:
                            "Hipped Roof Error.
                            just guessing here... broken edges? are you lines complete and unbroken?
                            By: Kristoff Rand
                              Just Push Pull your surface (even 1 mm), select the top one then call the plug! πŸ˜‰
                                As Pilou says, the roof face's plane must be 'flat', BUT it CANNOT be at z=0.
                                BUT this might not be the issue...
                                It is quite possible to make a face-shape that can't be used to make a properly resolved hipped roof - at least one with all faces at the same angle as needed by 'Roof' - e.g. a cranked star...
                                Try making the roof manually - it's not possible to 'hip-roof' some such forms unless you make some roof-faces slope at different angles...
                                Also sometimes a face's edge-order get 'jumbled' - the solution is then to select the face, group it and then explode it immediately, this often fixes the data-base jumble as the merged face/edges are properly ordered.
                                • L
                                  LarryCarrerra
                                  Hi to all,
                                  First of all, thanks to everyone in the Sketchup community, I'm new to it and I discover really fair people. Now to TIG, thank you for this great plugin, really powerful, a masterpiece ! A free masterpiece !
                                  Unfortunately I'm too young here to send MPs so my request will be public.
                                  Actually I have to teach Sketchup and I would like to put the "roof" plugin into the process. Issue : I'm french and not everyone understand english (especially technical terms), is it possible to get the "unscrambled" version so I can traduce it in french ? If it's possible I would be pleased to upload it here with your agreement.
                                  Thank you in advance.
                                  Larry
                                    It's not a 'scrambled' file πŸ˜•
                                    If you download the RBZ archive from http://sketchucation.com/pluginstore?pln=Roof
                                    and change the file-ending to .zip you can then extract its contents, which is this RBZ is just a single .rb file.
                                    You can then open that file in 'Notepad' on PC ['Notepad++' recommended] or 'TextWrangler' on MAC.
                                    Edit it as you wish.
                                    Translating English strings to French.
                                    If you use 'Notepad++' the text-strings [which occur in between ' ' or " "] they are colored clearly so you can see them.
                                    These occur in .menu, .statusbar and .messagebox methods...
                                    Good luck...
                                    Please don't publish the changed .rb outside of your immediate FR 'circle', without more discussions with me...
                                    • L
                                      LarryCarrerra
                                      Oh right. I did that but for some reasons I though it was uneditable... I think I'm a bit slow..!
                                      Thank you very much for your response and advices πŸ˜„
                                        sherwood111
                                        Hello,
                                        Is anyone having problems using "roof" in 2017 pro ?
                                        I get this in the ruby console (for a hipped roof) :
                                        [it works fine in 2016 pro]
                                        Error: #<TypeError: reference to deleted Face>
                                        C:/Users/apache3/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Roof.rb:287:in outer_loop' C:/Users/apache3/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Roof.rb:287:in hip'
                                        C:/Users/apache3/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Roof.v4.rb:4088:in block in <top (required)>' SketchUp:1:in call'
                                          It currently does not work in v2017 because of the way they changed how SketchUp references/IDs exploded entities.
                                          It was reported in a separate post just before Xmas, it's on my list of things to fix...
                                          Meanwhile you can still use it in v2016 and import the roof geometry into a v2017 model
                                            sherwood111
                                            TIG, Thanks for your reply and all that You do.
                                            Yep, I'm finding that I have to utilize a
                                            similar workflow as a workaround with other
                                            plugins too ... (in my transition to 2017).
                                            [slightly off subject]
                                            In general, I also get the annoying extension
                                            manager popup every session :
                                            "There are 'x' extensions ready to be updated"
                                            However, they won't update for various reasons.
                                            Onward and upward, as they say. πŸ˜„
                                            • 5 / 9
