    [Plugin] Cloud
    72 Posts 25 Posters 103.8k Views 25 Watching
    • Didier BurD Offline
      Didier Bur
      What kind of problem to install ? Please describe it more precisely so I can help.
      DB
      • GeorgeG Offline
        George
        Hello Didier,
        It seems Cloud and SU 2014 are not getting along.
        When I open SketchUp 2014, cloud_v8b.rbs throws a Load Error.
        Fixable?
        Error: #<SyntaxError: c:/users/george/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break> c:/users/george/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs
        Dell Precision T3400
        MS Windows 8.1 32-bit
        Intel Core 2 Quad Q9650 @ 3.00GHz
        4GB RAM
        NVIDIA Quadro FX 1800 768GB
        "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
          For v2014 compatibility I suspect that it's something simple that Didier needs to fix is his RB version and recompile into the RBS...
          Unfortunately, because it encrypted only Didier knows what is going on inside the code...
          I suggest you PM him - he needs nagging to get several of his plugins updated to be v2014 compatible.
          Where he has supplied a 'packed' RB file I have offered a temporary fix using the final .to_s -> [0] - which several users are successfully using, BUT unfortunately for his RBS versions that's NOT possible πŸ˜’
          • ninomaydaN Offline
            ninomayda
            Having trouble installing on SU-2014. Am I missing something? Alternatives available?
            Regards
            Nino
              My post [just before yours] already 'explains' this http://sketchucation.com/forums/viewtopic.php?p=518532#p518532
              There are several tools that do some of these things...
              What do you want to do, exactly?
                michelmtl
                Hi Didier,
                I got a problem just trying to load this plugin on SU14, win 8.1
                Error: #<SyntaxError: c:/users/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break>
                Any ideas?
                  @michelmtl said:
                  Hi Didier,
                  Any ideas?
                  If you read the few previous posts you'd see that it's incompatible with v2014.
                  It's probably an easy fix BUT Didier ought to do it πŸ˜’
                  • GeorgeG Offline
                    George
                    @tig said:
                    ...it's incompatible with v2014.
                    Sadly it seems Didier hasn't the time to do it.
                    Might he consider handing the task to a trusted fellow developer?
                    It's a shame to lose such a useful tool for even a short time; more so when left to languish for months.
                      Didier is too busy, but he has given me permission to update his script for him.
                      That new version 'v8.0bx' is available in the PluginStore.
                      http://sketchucation.com/pluginstore?pln=Cloud
                      It is now compatible with v2014...
                        sherwood111
                        very useful, thank you very much !
                        v8 works for me with SU8 pro x32, windows 8.1
                        v8b does not appear to work with SU 2015 x64, windows 8.1
                        vertical (z axis) data appears to be ignored
                        all points are on a flat horizontal plane
                        X Y positions/locations render correctly
                        same .csv data file imports into both SU8pro (v8) and SU2015 (v8b)
                        I don't know if it matters . . .
                        I notice extra characters in v8b 'points cloud options' input dialog window
                        the extra characters "] do not appear in v8 SU8pro
                        I'm unable to tinker with the .rbs file
                        cloud v8, SU8 pro x32 windows 8.1
                        cloud v8b, SU2015 x64 windows 8.1
                          Thanks for the report.
                          I can look to see if there are subtle errors in the code, and its conversion.
                          I'll update it and post again as needed...
                          Watch the PluginStore for announcements...
                            I have found the errors and fixed them.
                            The newer Ruby2 handles the dropt-down parameters for the inputbox more strictly than <=v2013's Ruby, which actually forgave some sloppy coding by Didier !
                            The newest version in the PluginStore should now also work properly in v2014/v2015 πŸ˜’
                              sherwood111
                              Excellent ! . . . works like a champ
                              Thanks so much for the attention and speedy response
                              And especially for filling in for Mr. Bur.
                              The first download I used was from the pluginstore
                              file = Cloud_v8.0bx.rbz
                              The second download I used (and works w/ 2015) was from the
                              'download' button immediately above, in this thread.
                              file = Cloud_v8.0bxx.rbz
                              The extracted/installed extension file has the
                              same name for both versions.
                              file = cloud_v8b.rbs
                              Thanks again, for All you do.
                                Galaxy85
                                Hello Didier,
                                I am very interested using your nice plugin Cloud, but unfortunately, it does not work for me after installation.
                                My config:
                                • Windows 7
                                • Sketchup 2015 Pro (Free Trial version for 30 days)
                                I downloaded the file, unzipped it and placed the resulted folder in the Sketchup plugin folder. When I restart Sketchup, I do not see the "Points Cloud" section under File menu as described in the documentation (Cloud.pdf).
                                I tried previous versions of the plugin (v6, v7...) same result.
                                I am using other plugins that work fine.
                                Any assistance would be very much appreciated.
                                Many thanks for your kind support
                                πŸ˜„
                                Jean-Pierre
                                PS: Oops sorry but it works!
                                I just had forgotten to "install / activate" the plugin in SU... (I am an SU beginner!)
                                Sorry again. 😳
                                • E Offline
                                  ericalderman
                                  Hi, I downloaded the script using the Download button above. I'm using SketchUp 2015 on a Mac running OS X Yosemite. The Points cloud menu shows up under File, and I can select the file (.LAS format). It tells me there are 578245 points to import, but after clicking OK on the Options dialog, nothing happens. Any ideas?
                                  Eric
                                  • RienkR Offline
                                    Rienk
                                    installed latest cloudV8_b in sketchup 2017 pro. It is enabled in the extension manager, restarted Sketchup and the menu "Points Cloud" showed up in the filemenu, but once I click on import the dialog box doesn't show. ❓ Tried it serveral times by reinstalling and dis and enabling
                                    Can anyone eleborate about his. Help is appreciated.
                                    Workstation operates on Windows 10 pro 64 bit
                                      Did you download it from the PluginStore ?
                                      It's version there is not "v8_b" - it's "v8.0bxx" ??
                                      The xx showings it's been updated for compatibility reasons...
                                      There is a clear download link button to its RBZ, on the first page, where the incompatible zips are confusingly still available !
                                      If you do have the latest version, and it's failing, then if you try it with the Ruby Console open are there any error messages ?
                                      • robertWanR Offline
                                        robertWan
                                        I often use a point cloud collected with a laser pointer placed on the CNC Z axis.
                                        The raw CNC file is converted with a macro in Notepad ++ to the syntax appropriate for a plug-in in SU.
                                        "Scan" this is the template.
                                        But the plug-in after triangulating has this effect.
                                        I have to clean it by hand.
                                        The function of creating an outline in the order of coordinates in a text file would be handy.
                                        Robert
                                          Didier Bur
                                          @robertWan:
                                          Don't you think that (in this particular case) creating an outline would take longer than erasing unwanted entities manually ? Just a thought...
                                          DB
                                            robertWan
                                            This is just my suggestion. πŸ˜„
                                            Robert
                                            • 3 / 4
