    [Plugin] Cloud
    72 Posts 25 Posters 100.5k Views 25 Watching
    • ninomaydaN Offline
      ninomayda
      Having trouble installing on SU-2014. Am I missing something? Alternatives available?
      Regards
      Nino
      • TIGT Online
        My post [just before yours] already 'explains' this http://sketchucation.com/forums/viewtopic.php?p=518532#p518532
        There are several tools that do some of these things...
        What do you want to do, exactly?
          michelmtl
          Hi Didier,
          I got a problem just trying to load this plugin on SU14, win 8.1
          Error: #<SyntaxError: c:/users/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break>
          Any ideas?
          • TIGT Online
            @michelmtl said:
            Hi Didier,
            Any ideas?
            If you read the few previous posts you'd see that it's incompatible with v2014.
            It's probably an easy fix BUT Didier ought to do it πŸ˜’
            • GeorgeG Offline
              George
              @tig said:
              ...it's incompatible with v2014.
              Sadly it seems Didier hasn't the time to do it.
              Might he consider handing the task to a trusted fellow developer?
              It's a shame to lose such a useful tool for even a short time; more so when left to languish for months.
              "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
              • TIGT Online
                Didier is too busy, but he has given me permission to update his script for him.
                That new version 'v8.0bx' is available in the PluginStore.
                http://sketchucation.com/pluginstore?pln=Cloud
                It is now compatible with v2014...
                  sherwood111
                  very useful, thank you very much !
                  v8 works for me with SU8 pro x32, windows 8.1
                  v8b does not appear to work with SU 2015 x64, windows 8.1
                  vertical (z axis) data appears to be ignored
                  all points are on a flat horizontal plane
                  X Y positions/locations render correctly
                  same .csv data file imports into both SU8pro (v8) and SU2015 (v8b)
                  I don't know if it matters . . .
                  I notice extra characters in v8b 'points cloud options' input dialog window
                  the extra characters "] do not appear in v8 SU8pro
                  I'm unable to tinker with the .rbs file
                  cloud v8, SU8 pro x32 windows 8.1
                  cloud v8b, SU2015 x64 windows 8.1
                  • TIGT Online
                    Thanks for the report.
                    I can look to see if there are subtle errors in the code, and its conversion.
                    I'll update it and post again as needed...
                    Watch the PluginStore for announcements...
                    • TIGT Online
                      I have found the errors and fixed them.
                      The newer Ruby2 handles the dropt-down parameters for the inputbox more strictly than <=v2013's Ruby, which actually forgave some sloppy coding by Didier !
                      The newest version in the PluginStore should now also work properly in v2014/v2015 πŸ˜’
                        sherwood111
                        Excellent ! . . . works like a champ
                        Thanks so much for the attention and speedy response
                        And especially for filling in for Mr. Bur.
                        The first download I used was from the pluginstore
                        file = Cloud_v8.0bx.rbz
                        The second download I used (and works w/ 2015) was from the
                        'download' button immediately above, in this thread.
                        file = Cloud_v8.0bxx.rbz
                        The extracted/installed extension file has the
                        same name for both versions.
                        file = cloud_v8b.rbs
                        Thanks again, for All you do.
                          Galaxy85
                          Hello Didier,
                          I am very interested using your nice plugin Cloud, but unfortunately, it does not work for me after installation.
                          My config:
                          • Windows 7
                          • Sketchup 2015 Pro (Free Trial version for 30 days)
                          I downloaded the file, unzipped it and placed the resulted folder in the Sketchup plugin folder. When I restart Sketchup, I do not see the "Points Cloud" section under File menu as described in the documentation (Cloud.pdf).
                          I tried previous versions of the plugin (v6, v7...) same result.
                          I am using other plugins that work fine.
                          Any assistance would be very much appreciated.
                          Many thanks for your kind support
                          πŸ˜„
                          Jean-Pierre
                          PS: Oops sorry but it works!
                          I just had forgotten to "install / activate" the plugin in SU... (I am an SU beginner!)
                          Sorry again. 😳
                          • E Offline
                            ericalderman
                            Hi, I downloaded the script using the Download button above. I'm using SketchUp 2015 on a Mac running OS X Yosemite. The Points cloud menu shows up under File, and I can select the file (.LAS format). It tells me there are 578245 points to import, but after clicking OK on the Options dialog, nothing happens. Any ideas?
                            Eric
                            • RienkR Offline
                              Rienk
                              installed latest cloudV8_b in sketchup 2017 pro. It is enabled in the extension manager, restarted Sketchup and the menu "Points Cloud" showed up in the filemenu, but once I click on import the dialog box doesn't show. ❓ Tried it serveral times by reinstalling and dis and enabling
                              Can anyone eleborate about his. Help is appreciated.
                              Workstation operates on Windows 10 pro 64 bit
                              • TIGT Online
                                Did you download it from the PluginStore ?
                                It's version there is not "v8_b" - it's "v8.0bxx" ??
                                The xx showings it's been updated for compatibility reasons...
                                There is a clear download link button to its RBZ, on the first page, where the incompatible zips are confusingly still available !
                                If you do have the latest version, and it's failing, then if you try it with the Ruby Console open are there any error messages ?
                                • robertWanR Offline
                                  robertWan
                                  I often use a point cloud collected with a laser pointer placed on the CNC Z axis.
                                  The raw CNC file is converted with a macro in Notepad ++ to the syntax appropriate for a plug-in in SU.
                                  "Scan" this is the template.
                                  But the plug-in after triangulating has this effect.
                                  I have to clean it by hand.
                                  The function of creating an outline in the order of coordinates in a text file would be handy.
                                  Robert
                                  • Didier BurD Offline
                                    Didier Bur
                                    @robertWan:
                                    Don't you think that (in this particular case) creating an outline would take longer than erasing unwanted entities manually ? Just a thought...
                                    DB
                                      robertWan
                                      This is just my suggestion. πŸ˜„
                                      Robert
                                        ajayneswoodworks
                                        I just installed the plugin on ShetchUp Pro 2020 on a Mac running Catalina. I click to "pick a points for cloud origin", open my .LAS file, click ok in the options, and then nothing happens. The Ruby console shows "
                                        Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                        /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:310:in split' /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:310:in import'
                                        /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:168:in endTool' /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:108:in onLButtonUp'
                                        If I click cancel on the options and then say no to triangulation I get
                                        Error: #<NoMethodError: undefined method getPointsCloudOrigin' for #<GetPointTool:0x00007fc184d4ae20>> /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:172:in endTool'
                                        /users/-/library/application support/sketchup 2020/sketchup/plugins/cloud_v8b.rbs:108:in `onLButtonUp'
                                        Can anyone help?
                                        • TIGT Online
                                          Perhaps the LAS file is not encoded as UTF-8 ?
                                          Can you open it in a plain-text editor, like TextWrangler, and reset its text-encoding to that, re-save it and try again ?
                                          Or attach the LAS file to a post [as a ZIP] so that we can look at it...
                                          • T thendis referenced this topic on
                                          • 4 / 4
