    [Plugin] Cloud
    72 Posts 25 Posters 100.5k Views 25 Watching
    • Q Offline
      qconsult
      Dear Sir,
      Please advise on possible work-flow concerning storing the "ID" tag from CSV as a component attribute.
      Any/all advice will be appreciated.
      Kind regards,
      Q
        jaspergardner
        I am having problems trying to install Cloud_v8b on my mac, does this version work for mac?
        • Didier BurD Offline
          Didier Bur
          What kind of problem to install ? Please describe it more precisely so I can help.
          DB
          • GeorgeG Offline
            George
            Hello Didier,
            It seems Cloud and SU 2014 are not getting along.
            When I open SketchUp 2014, cloud_v8b.rbs throws a Load Error.
            Fixable?
            Error: #<SyntaxError: c:/users/george/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break> c:/users/george/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs
            Dell Precision T3400
            MS Windows 8.1 32-bit
            Intel Core 2 Quad Q9650 @ 3.00GHz
            4GB RAM
            NVIDIA Quadro FX 1800 768GB
            "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
              For v2014 compatibility I suspect that it's something simple that Didier needs to fix is his RB version and recompile into the RBS...
              Unfortunately, because it encrypted only Didier knows what is going on inside the code...
              I suggest you PM him - he needs nagging to get several of his plugins updated to be v2014 compatible.
              Where he has supplied a 'packed' RB file I have offered a temporary fix using the final .to_s -> [0] - which several users are successfully using, BUT unfortunately for his RBS versions that's NOT possible πŸ˜’
              • ninomaydaN Offline
                ninomayda
                Having trouble installing on SU-2014. Am I missing something? Alternatives available?
                Regards
                Nino
                  My post [just before yours] already 'explains' this http://sketchucation.com/forums/viewtopic.php?p=518532#p518532
                  There are several tools that do some of these things...
                  What do you want to do, exactly?
                    michelmtl
                    Hi Didier,
                    I got a problem just trying to load this plugin on SU14, win 8.1
                    Error: #<SyntaxError: c:/users/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break>
                    Any ideas?
                      @michelmtl said:
                      Hi Didier,
                      Any ideas?
                      If you read the few previous posts you'd see that it's incompatible with v2014.
                      It's probably an easy fix BUT Didier ought to do it πŸ˜’
                      • GeorgeG Offline
                        George
                        @tig said:
                        ...it's incompatible with v2014.
                        Sadly it seems Didier hasn't the time to do it.
                        Might he consider handing the task to a trusted fellow developer?
                        It's a shame to lose such a useful tool for even a short time; more so when left to languish for months.
                          Didier is too busy, but he has given me permission to update his script for him.
                          That new version 'v8.0bx' is available in the PluginStore.
                          http://sketchucation.com/pluginstore?pln=Cloud
                          It is now compatible with v2014...
                            sherwood111
                            very useful, thank you very much !
                            v8 works for me with SU8 pro x32, windows 8.1
                            v8b does not appear to work with SU 2015 x64, windows 8.1
                            vertical (z axis) data appears to be ignored
                            all points are on a flat horizontal plane
                            X Y positions/locations render correctly
                            same .csv data file imports into both SU8pro (v8) and SU2015 (v8b)
                            I don't know if it matters . . .
                            I notice extra characters in v8b 'points cloud options' input dialog window
                            the extra characters "] do not appear in v8 SU8pro
                            I'm unable to tinker with the .rbs file
                            cloud v8, SU8 pro x32 windows 8.1
                            cloud v8b, SU2015 x64 windows 8.1
                              Thanks for the report.
                              I can look to see if there are subtle errors in the code, and its conversion.
                              I'll update it and post again as needed...
                              Watch the PluginStore for announcements...
                                I have found the errors and fixed them.
                                The newer Ruby2 handles the dropt-down parameters for the inputbox more strictly than <=v2013's Ruby, which actually forgave some sloppy coding by Didier !
                                The newest version in the PluginStore should now also work properly in v2014/v2015 πŸ˜’
                                  sherwood111
                                  Excellent ! . . . works like a champ
                                  Thanks so much for the attention and speedy response
                                  And especially for filling in for Mr. Bur.
                                  The first download I used was from the pluginstore
                                  file = Cloud_v8.0bx.rbz
                                  The second download I used (and works w/ 2015) was from the
                                  'download' button immediately above, in this thread.
                                  file = Cloud_v8.0bxx.rbz
                                  The extracted/installed extension file has the
                                  same name for both versions.
                                  file = cloud_v8b.rbs
                                  Thanks again, for All you do.
                                    Galaxy85
                                    Hello Didier,
                                    I am very interested using your nice plugin Cloud, but unfortunately, it does not work for me after installation.
                                    My config:
                                    • Windows 7
                                    • Sketchup 2015 Pro (Free Trial version for 30 days)
                                    I downloaded the file, unzipped it and placed the resulted folder in the Sketchup plugin folder. When I restart Sketchup, I do not see the "Points Cloud" section under File menu as described in the documentation (Cloud.pdf).
                                    I tried previous versions of the plugin (v6, v7...) same result.
                                    I am using other plugins that work fine.
                                    Any assistance would be very much appreciated.
                                    Many thanks for your kind support
                                    πŸ˜„
                                    Jean-Pierre
                                    PS: Oops sorry but it works!
                                    I just had forgotten to "install / activate" the plugin in SU... (I am an SU beginner!)
                                    Sorry again. 😳
                                    • E Offline
                                      ericalderman
                                      Hi, I downloaded the script using the Download button above. I'm using SketchUp 2015 on a Mac running OS X Yosemite. The Points cloud menu shows up under File, and I can select the file (.LAS format). It tells me there are 578245 points to import, but after clicking OK on the Options dialog, nothing happens. Any ideas?
                                      Eric
                                      • RienkR Offline
                                        Rienk
                                        installed latest cloudV8_b in sketchup 2017 pro. It is enabled in the extension manager, restarted Sketchup and the menu "Points Cloud" showed up in the filemenu, but once I click on import the dialog box doesn't show. ❓ Tried it serveral times by reinstalling and dis and enabling
                                        Can anyone eleborate about his. Help is appreciated.
                                        Workstation operates on Windows 10 pro 64 bit
                                          Did you download it from the PluginStore ?
                                          It's version there is not "v8_b" - it's "v8.0bxx" ??
                                          The xx showings it's been updated for compatibility reasons...
                                          There is a clear download link button to its RBZ, on the first page, where the incompatible zips are confusingly still available !
                                          If you do have the latest version, and it's failing, then if you try it with the Ruby Console open are there any error messages ?
                                          • robertWanR Offline
                                            robertWan
                                            I often use a point cloud collected with a laser pointer placed on the CNC Z axis.
                                            The raw CNC file is converted with a macro in Notepad ++ to the syntax appropriate for a plug-in in SU.
                                            "Scan" this is the template.
                                            But the plug-in after triangulating has this effect.
                                            I have to clean it by hand.
                                            The function of creating an outline in the order of coordinates in a text file would be handy.
                                            Robert
                                            • 3 / 4
