    Struggling with Artisan
    extensions
    14 Posts 9 Posters 1.7k Views 9 Watching
    • KrisidiousK Offline
      Krisidious
      I think you'd need to show us examples of what you're wanting and what you're getting. namely what you're doing to get what you don't want as well...
      By: Kristoff Rand
        Krisidious
        two of your images didn't take Pilou...
        By: Kristoff Rand
        • bazB Offline
          baz
          Yes, as Pilou says you have to get your head around a different way of thinking.
          I don't have much call for it but find it fascinating.
          The best resource, IMHO, is here at cotty's thread...http://sketchucation.com/forums/viewtopic.php?f=335%26amp;t=42938
          Work your way thru that and try to reproduce the examples yourself.
          Skip thru to the simple ones which also have the progression illustrated, even I can get it πŸ˜„ .
          Baz
          • HieruH Offline
            Hieru
            +1
            I'd be happy to help out if I could see some example images or models.
            www.davidhier.co.uk
              Modeling with subdivision is a special sport! πŸ˜‰
              Because you must imagine the final sculpt from a rough rustic form! πŸ€“
              And difficulties are on the frontieres!( must be a quadrangle, a triangle, a double one (Offset) etc...
              by Nomeradona
              http://i334.photobucket.com/albums/m421/nomeradona_1234/Ignacio/3.jpg
              By Solo
              traits = lines πŸ˜‰
              • Bryan KB Offline
                Baz
                I'll work my way through these examples first and then try the ones from Cotty.
                I'm certain the first set will turn out fine as the simpler shapes have not been a problem. It's the more complex ones that aren't turning out right.
                I haven't saved any for the simple reason of they did not turn out right. I'll save the (possible) failed examples this time and post them here.
                • cottyC Offline
                  cotty
                  And you should always make a copy of your proxy geometry so that you can try Artisan without loosing the original proxy...
                  my SketchUp gallery
                  • Bryan KB Offline
                    Excellent suggestion! Will do that. Thanks.
                    • michaliszissiouM Offline
                      michaliszissiou
                      Box modeling first. You know, all the push pull stuff.
                      However, try to keep topology into quads (avoiding too many Ngons).
                      This is helpful.
                      Then, enter artisan.
                      BTW, my avatar image is still an artisan result.
                      • Bryan KB Offline
                        This is helpful.
                        Thanks! I had heard quads was also one of the keys to a successful result but I had forgotten.
                        • bazB Offline
                          baz
                          I had to look up 'Ngons'
                          Good explanation here...
                          http://blog.digitaltutors.com/ngons-triangles-bad/
                            cuttingedge
                            just like you, i struggled a lot.Depending on what youre modeling , but as much as possible, "Keep the quads" or at least the tris but never ngons.Cotty's simple objects and Alvis' tutorials and samples on making upholstered furniture did help me a lot. You'll find it a pleasure once you get the hang of it.. and as Cotty said... Do keep copies of your proxies on the side every stage possible..πŸ˜„
                            • ely862meE Offline
                              ely862me
                              Don't use proxies, work directly with the geometry. Create your shape, then subdivide it, look at it then Undo and retouch it, then subdivide until you are happy with the result. If you are afraid of bugsplats, just copy the not subdivided geometry nearby once in a while.
                              Elisei (sketchupper)
                              Come and See EliseiDesign
