    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 4.4k Views 9 Watching
    • jeff hammondJ Offline
      1024 boxes, a 12-pack, and change the shape of the box component
      • Flippie123F Offline
        Flippie123
        @Jeff
        I just made this and gave it a twist. Very awesome! ๐ŸŽ‰ ๐Ÿ‘
          yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
            sweet!
            (i'm not sure how to use the code but the gif looks cool ๐Ÿ˜‰ ๐Ÿ‘ )
              driven
              @jeff hammond said:
              ...i'm not sure how to use the code ...
              just paste into 'Ruby Console' hit return, will run till end of session...
              it's only active when inside the DC so you can do other modelling...
              I can put it in a rbz with the DC if you want...
                oh nice. i see now.
                it works along with the dynamic component i posted.. i didn't realize things like that were possible.
                but yeah, that's a lot better than manually triggering the redraw ๐Ÿ‘
                  driven
                  @jeff hammond said:
                  ... i didn't realize things like that were possible.
                  nor did I...
                  I improved the script to only do one redraw after the move [was trigging twice]...
                  there are probably other ways to do this, but it seams to work...
                    driven
                    updated working version...
                    class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                        def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                          attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                          moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                          @count = 0 unless @count == 1
                          update = attractor && moved
                            if update
                              selection = Sketchup.active_model.selection[0].parent.instances[0]
                              @count = @count + 1
                              puts(" first click of " + tool_name.to_s ) if @count == 1
                              if @count == 2
                                puts(" second click of " + tool_name.to_s )
                                $dc_observers.get_latest_class.redraw_with_undo(selection)
                                @count = 0
                     Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
                      driven
                      here's a fun bit of code...
                      now it does what the OP asked...
                      auto update, slows a bit over 64 items...
                       look below...
                      EDIT: changed back to original as my counter was failing
                      BETTER CODE BELOW...
                        Jim
                        the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                        You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                        This file was made specifically for Jeff's DC Magnet Beer model.
                          driven
                          cheers Jim,
                          that works and is much cleaner than i was attempting...
                          what other thing can we do with ruby to manipulate DC's?
                          I'll see if I can turn this into a pick point version...
                          • sdmitchS Offline
                            sdmitch
                            Hey, I want in on the fun too.
                            http://sdmitch.blogspot.com/
                              driven
                              @sam yours looks cooler than my effort...
                              click anywhere to move 'magnet'...
                              • sdmitchS Offline
                                sdmitch
                                [attachment=1:3ueqjjsy]<!-- ia1 -->driven-dc-tool_v2.rb<!-- ia1 -->[/attachment:3ueqjjsy]
                                [attachment=0:3ueqjjsy]<!-- ia0 -->driven-dc-tool_v2_2.gif<!-- ia0 -->[/attachment:3ueqjjsy]
                                ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜†
                                  driven
                                  with cursor...modified <a class=@Jeff's DC, @Jim's code..." title="modified @Jeff's DC, @Jim's code..." class=" img-fluid img-markdown" />
                                  • gillesG Offline
                                    gilles
                                    Next step is multi- attractors ๐Ÿ’š
                                      heh.. yeah.. i thought about it but it would be really weird to do in DC..
                                      that kind of math is probably possible in DC but once things start getting complex, it's either hard to keep track of or you end up with really long/weird formulas that are equally hard to keep track of ๐Ÿ˜‰
                                      i guess first you'd have to apply a 'strength' to a single magnet (so far, these aren't really magnets.. the objects just all point at the 'magnet' but the attractor isn't actually pulling on them)
                                      then make two of those magnets and let the strengths fight each other
                                        Flippie123
                                        Yep like this image
                                          Flippie123
                                          @jolran said:
                                          Interesting!
                                          I'm working on a parametric modeler that could hopefully(one day ๐Ÿ˜’ ) do this sort of things.
                                          I was able to make this urban plan combining Jeff's Beer tool ๐Ÿ‘ and this new Modelur Pre Beta, urban design plugin which in combination with a 'height-' 'and a build-up-area'-map really awesomefies Jeff's beer tool. ๐ŸŽ‰ ๐Ÿค“
                                          Click on the image for a larger one!
                                            nice Philip ๐Ÿ‘
                                            • 3 / 3
