    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 4.1k Views 9 Watching
      driven
      here's a fun bit of code...
      now it does what the OP asked...
      auto update, slows a bit over 64 items...
       look below...
      EDIT: changed back to original as my counter was failing
      BETTER CODE BELOW...
        Jim
        the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
        You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
        This file was made specifically for Jeff's DC Magnet Beer model.
          driven
          cheers Jim,
          that works and is much cleaner than i was attempting...
          what other thing can we do with ruby to manipulate DC's?
          I'll see if I can turn this into a pick point version...
          • sdmitchS Offline
            sdmitch
            Hey, I want in on the fun too.
            http://sdmitch.blogspot.com/
              driven
              @sam yours looks cooler than my effort...
              click anywhere to move 'magnet'...
              • sdmitchS Offline
                sdmitch
                [attachment=1:3ueqjjsy]<!-- ia1 -->driven-dc-tool_v2.rb<!-- ia1 -->[/attachment:3ueqjjsy]
                [attachment=0:3ueqjjsy]<!-- ia0 -->driven-dc-tool_v2_2.gif<!-- ia0 -->[/attachment:3ueqjjsy]
                ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜†
                  driven
                  with cursor...modified <a class=@Jeff's DC, @Jim's code..." title="modified @Jeff's DC, @Jim's code..." class=" img-fluid img-markdown" />
                  • gillesG Offline
                    gilles
                    Next step is multi- attractors ๐Ÿ’š
                    • jeff hammondJ Offline
                      heh.. yeah.. i thought about it but it would be really weird to do in DC..
                      that kind of math is probably possible in DC but once things start getting complex, it's either hard to keep track of or you end up with really long/weird formulas that are equally hard to keep track of ๐Ÿ˜‰
                      i guess first you'd have to apply a 'strength' to a single magnet (so far, these aren't really magnets.. the objects just all point at the 'magnet' but the attractor isn't actually pulling on them)
                      then make two of those magnets and let the strengths fight each other
                      • Flippie123F Offline
                        Flippie123
                        Yep like this image
                          Flippie123
                          @jolran said:
                          Interesting!
                          I'm working on a parametric modeler that could hopefully(one day ๐Ÿ˜’ ) do this sort of things.
                          I was able to make this urban plan combining Jeff's Beer tool ๐Ÿ‘ and this new Modelur Pre Beta, urban design plugin which in combination with a 'height-' 'and a build-up-area'-map really awesomefies Jeff's beer tool. ๐ŸŽ‰ ๐Ÿค“
                          Click on the image for a larger one!
                            nice Philip ๐Ÿ‘
                            • 3 / 3
