    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 5.7k Views 9 Watching
    • jeff hammondJ
      here's a dynamic component which does the thing in the original post..
      DC_Magnet.skp
      to use it:
      • double-click the outer component (main) to enter it.. (there are two more components inside: box & attractor)
      • Move the attractor component with the move tool
      • exit the main component then right-click on it --> Dynamic Components-> Redraw.
        driven
        @jeff
        that's really good...
        • jeff hammondJ
          @driven said:
          @jeff
          thanks.
          a few more additions (right-click--> dynamic components -> component options)
          • pick the number of boxes (square array)
          • how many beers? (straightness of rows and columns waver)
          DC_Magnet_Beer.skp
          • jeff hammondJ
            1024 boxes, a 12-pack, and change the shape of the box component
            • Flippie123F
              Flippie123
              @Jeff
              I just made this and gave it a twist. Very awesome! 🎉 👍
              • jeff hammondJ
                yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
                • jeff hammondJ
                  sweet!
                  (i'm not sure how to use the code but the gif looks cool 😉 👍 )
                    driven
                    @jeff hammond said:
                    ...i'm not sure how to use the code ...
                    just paste into 'Ruby Console' hit return, will run till end of session...
                    it's only active when inside the DC so you can do other modelling...
                    I can put it in a rbz with the DC if you want...
                    • jeff hammondJ
                      oh nice. i see now.
                      it works along with the dynamic component i posted.. i didn't realize things like that were possible.
                      but yeah, that's a lot better than manually triggering the redraw 👍
                        driven
                        @jeff hammond said:
                        ... i didn't realize things like that were possible.
                        nor did I...
                        I improved the script to only do one redraw after the move [was trigging twice]...
                        there are probably other ways to do this, but it seams to work...
                          driven
                          updated working version...
                          class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                              def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                                attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                                moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                                @count = 0 unless @count == 1
                                update = attractor && moved
                                  if update
                                    selection = Sketchup.active_model.selection[0].parent.instances[0]
                                    @count = @count + 1
                                    puts(" first click of " + tool_name.to_s ) if @count == 1
                                    if @count == 2
                                      puts(" second click of " + tool_name.to_s )
                                      $dc_observers.get_latest_class.redraw_with_undo(selection)
                                      @count = 0
                           Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
                            driven
                            here's a fun bit of code...
                            now it does what the OP asked...
                            auto update, slows a bit over 64 items...
                             look below...
                            EDIT: changed back to original as my counter was failing
                            BETTER CODE BELOW...
                              Jim
                              the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                              You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                              This file was made specifically for Jeff's DC Magnet Beer model.
                                driven
                                cheers Jim,
                                that works and is much cleaner than i was attempting...
                                what other thing can we do with ruby to manipulate DC's?
                                I'll see if I can turn this into a pick point version...
                                • sdmitchS
                                  sdmitch
                                  Hey, I want in on the fun too.
                                  http://sdmitch.blogspot.com/
                                    driven
                                    @sam yours looks cooler than my effort...
                                    click anywhere to move 'magnet'...
                                    • sdmitchS
                                      sdmitch
                                      [attachment=1:3ueqjjsy]<!-- ia1 -->driven-dc-tool_v2.rb<!-- ia1 -->[/attachment:3ueqjjsy]
                                      [attachment=0:3ueqjjsy]<!-- ia0 -->driven-dc-tool_v2_2.gif<!-- ia0 -->[/attachment:3ueqjjsy]
                                        driven
                                        with cursor...modified <a class=@Jeff's DC, @Jim's code..." title="modified @Jeff's DC, @Jim's code..." class="img-markdown img-fluid" />
                                        • gillesG
                                          gilles
                                          Next step is multi- attractors 💚
                                          • jeff hammondJ
                                            heh.. yeah.. i thought about it but it would be really weird to do in DC..
                                            that kind of math is probably possible in DC but once things start getting complex, it's either hard to keep track of or you end up with really long/weird formulas that are equally hard to keep track of 😉
                                            i guess first you'd have to apply a 'strength' to a single magnet (so far, these aren't really magnets.. the objects just all point at the 'magnet' but the attractor isn't actually pulling on them)
                                            then make two of those magnets and let the strengths fight each other
                                            • 3 / 3
