    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 3.7k Views 9 Watching
      driven
      @jeff hammond said:
      ...i'm not sure how to use the code ...
      just paste into 'Ruby Console' hit return, will run till end of session...
      it's only active when inside the DC so you can do other modelling...
      I can put it in a rbz with the DC if you want...
      • jeff hammondJ Offline
        oh nice. i see now.
        it works along with the dynamic component i posted.. i didn't realize things like that were possible.
        but yeah, that's a lot better than manually triggering the redraw ๐Ÿ‘
          driven
          @jeff hammond said:
          ... i didn't realize things like that were possible.
          nor did I...
          I improved the script to only do one redraw after the move [was trigging twice]...
          there are probably other ways to do this, but it seams to work...
            driven
            updated working version...
            class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                  attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                  moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                  @count = 0 unless @count == 1
                  update = attractor && moved
                    if update
                      selection = Sketchup.active_model.selection[0].parent.instances[0]
                      @count = @count + 1
                      puts(" first click of " + tool_name.to_s ) if @count == 1
                      if @count == 2
                        puts(" second click of " + tool_name.to_s )
                        $dc_observers.get_latest_class.redraw_with_undo(selection)
                        @count = 0
             Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
              driven
              here's a fun bit of code...
              now it does what the OP asked...
              auto update, slows a bit over 64 items...
               look below...
              EDIT: changed back to original as my counter was failing
              BETTER CODE BELOW...
                Jim
                the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                This file was made specifically for Jeff's DC Magnet Beer model.
                  driven
                  cheers Jim,
                  that works and is much cleaner than i was attempting...
                  what other thing can we do with ruby to manipulate DC's?
                  I'll see if I can turn this into a pick point version...
                  • sdmitchS Offline
                    sdmitch
                    Hey, I want in on the fun too.
                    http://sdmitch.blogspot.com/
                      driven
                      @sam yours looks cooler than my effort...
                      click anywhere to move 'magnet'...
                      • sdmitchS Offline
                        sdmitch
                        [attachment=1:3ueqjjsy]<!-- ia1 -->driven-dc-tool_v2.rb<!-- ia1 -->[/attachment:3ueqjjsy]
                        [attachment=0:3ueqjjsy]<!-- ia0 -->driven-dc-tool_v2_2.gif<!-- ia0 -->[/attachment:3ueqjjsy]
                        ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜†
                          driven
                          with cursor...modified <a class=@Jeff's DC, @Jim's code..." title="modified @Jeff's DC, @Jim's code..." class=" img-fluid img-markdown" />
                          • gillesG Offline
                            gilles
                            Next step is multi- attractors ๐Ÿ’š
                              heh.. yeah.. i thought about it but it would be really weird to do in DC..
                              that kind of math is probably possible in DC but once things start getting complex, it's either hard to keep track of or you end up with really long/weird formulas that are equally hard to keep track of ๐Ÿ˜‰
                              i guess first you'd have to apply a 'strength' to a single magnet (so far, these aren't really magnets.. the objects just all point at the 'magnet' but the attractor isn't actually pulling on them)
                              then make two of those magnets and let the strengths fight each other
                              • Flippie123F Offline
                                Flippie123
                                Yep like this image
                                  Flippie123
                                  @jolran said:
                                  Interesting!
                                  I'm working on a parametric modeler that could hopefully(one day ๐Ÿ˜’ ) do this sort of things.
                                  I was able to make this urban plan combining Jeff's Beer tool ๐Ÿ‘ and this new Modelur Pre Beta, urban design plugin which in combination with a 'height-' 'and a build-up-area'-map really awesomefies Jeff's beer tool. ๐ŸŽ‰ ๐Ÿค“
                                  Click on the image for a larger one!
                                    nice Philip ๐Ÿ‘
                                    • 3 / 3
