    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 4.4k Views 9 Watching
    • jeff hammondJ Offline
      @flippie123 said:
      haha...yes it always point to the center line but it is not magnetic.
      hmm.. it was meant as proof of concept.. the origin in this case is "magnetic"..
      copy a bunch of them around:
      then select them all and move them at once:
      with a less simple DC, you could make it the other way.. the objects stay put and you move the attractor around (though probably moving the the attractor via numerical input).
      • BoxB Offline
        @flippie123 said:
        I tried to use the sketchyphysics tool but it only works for Sketchup7. And it is not easy to use. ๐ŸŽ‰
        My model up there was done in 2015 32bit, the only version it doesn't work in at the moment is 2015 64bit. Make sure you are using the latest version.
        Yes it can be difficult to use, it isn't the most easily understood plugin and the documentation is limited.
        But mostly I don't think it would work for you as it doesn't really work for positioning stuff then placing it. It is more of an animation tool.
        • cottyC Offline
          cotty
          @flippie123 said:
          ... but it only works for Sketchup7. And it is not easy to use. ๐ŸŽ‰
          That's wrong...
          http://sketchucation.com/pluginstore?pln=SketchyPhysics
          my SketchUp gallery
            here's a dynamic component which does the thing in the original post..
            DC_Magnet.skp
            to use it:
            โ€ข double-click the outer component (main) to enter it.. (there are two more components inside: box & attractor)
            โ€ข Move the attractor component with the move tool
            โ€ข exit the main component then right-click on it --> Dynamic Components-> Redraw.
              driven
              @jeff
              that's really good...
                @driven said:
                @jeff
                thanks.
                a few more additions (right-click--> dynamic components -> component options)
                โ€ข pick the number of boxes (square array)
                โ€ข how many beers? (straightness of rows and columns waver)
                DC_Magnet_Beer.skp
                  1024 boxes, a 12-pack, and change the shape of the box component
                  • Flippie123F Offline
                    Flippie123
                    @Jeff
                    I just made this and gave it a twist. Very awesome! ๐ŸŽ‰ ๐Ÿ‘
                      yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
                        sweet!
                        (i'm not sure how to use the code but the gif looks cool ๐Ÿ˜‰ ๐Ÿ‘ )
                          driven
                          @jeff hammond said:
                          ...i'm not sure how to use the code ...
                          just paste into 'Ruby Console' hit return, will run till end of session...
                          it's only active when inside the DC so you can do other modelling...
                          I can put it in a rbz with the DC if you want...
                            oh nice. i see now.
                            it works along with the dynamic component i posted.. i didn't realize things like that were possible.
                            but yeah, that's a lot better than manually triggering the redraw ๐Ÿ‘
                              driven
                              @jeff hammond said:
                              ... i didn't realize things like that were possible.
                              nor did I...
                              I improved the script to only do one redraw after the move [was trigging twice]...
                              there are probably other ways to do this, but it seams to work...
                                driven
                                updated working version...
                                class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                                    def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                                      attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                                      moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                                      @count = 0 unless @count == 1
                                      update = attractor && moved
                                        if update
                                          selection = Sketchup.active_model.selection[0].parent.instances[0]
                                          @count = @count + 1
                                          puts(" first click of " + tool_name.to_s ) if @count == 1
                                          if @count == 2
                                            puts(" second click of " + tool_name.to_s )
                                            $dc_observers.get_latest_class.redraw_with_undo(selection)
                                            @count = 0
                                 Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
                                  driven
                                  here's a fun bit of code...
                                  now it does what the OP asked...
                                  auto update, slows a bit over 64 items...
                                   look below...
                                  EDIT: changed back to original as my counter was failing
                                  BETTER CODE BELOW...
                                    Jim
                                    the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                                    You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                                    This file was made specifically for Jeff's DC Magnet Beer model.
                                      driven
                                      cheers Jim,
                                      that works and is much cleaner than i was attempting...
                                      what other thing can we do with ruby to manipulate DC's?
                                      I'll see if I can turn this into a pick point version...
                                      • sdmitchS Offline
                                        sdmitch
                                        Hey, I want in on the fun too.
                                        http://sdmitch.blogspot.com/
                                          driven
                                          @sam yours looks cooler than my effort...
                                          click anywhere to move 'magnet'...
                                          • sdmitchS Offline
                                            sdmitch
                                            [attachment=1:3ueqjjsy]<!-- ia1 -->driven-dc-tool_v2.rb<!-- ia1 -->[/attachment:3ueqjjsy]
                                            [attachment=0:3ueqjjsy]<!-- ia0 -->driven-dc-tool_v2_2.gif<!-- ia0 -->[/attachment:3ueqjjsy]
                                            ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜†
                                            • 2 / 3
