    How do I move a texture on a surface?
    16 Posts 6 Posters 1.2k Views 6 Watching
      LARV
      I know I can scale a texture using edit, but is it possible to move it around on the surface after it´s been placed? Left, right, up, down?
      • BoxB Offline
        Many many ways.
        But the most basic,assuming it is a flat face, right click on the texture, in the context menu select Texture and then position.
          LARV
          Yes, I did that first when creating a texture to place on a non flat surface. It´s now placed and I need to move it around.
            LARV
            I want to be able to move this texture around without having to bring out a calculator.
            • BoxB Offline
              Thrupaint, part of Fredotools will do it.
              • TIGT Online
                My Texture Tools also lets you Position a textured material on a selected front face, by a given amount [set in a dialog - say 11.5mm] or with arrow-key presses - say -/+1mm per press in two directions, + hold-shift for x10 etc...
                It also has two other tools to Rotate and Scale textures, in similar ways...
                http://sketchucation.com/pluginstore?pln=TIG-TextureTools
                I also have a version to do the same on back-face materials, but it's unpublished - although available by PM request only...
                  LARV
                  Sorry, but I didn´t manage to move the texture at all with the plughin. The interface could be better, those icons made no sense.
                  • TIGT Online
                    For a textured 'surface' - rather than a textured single face - look at ThruPaint... 😒
                      LARV
                      TheuPaint, cool plugin. I managed to move the texture around now, but it doesn´t seem to treat the different faces as "one". I marked "texture with continuity with no deformation".
                      Anyone here who´ve used the tool to make a texture follow an uneven surface who could give me some pointers to making my surface become treated as a single face? I watched a video tutorial but it was too advanced for me I´m afraid.. 😞
                      In my SU the plugin doesn´t show as icons, it´s just a text list. It makes it sort of hard to follow what the guy is doing in the tutorial.
                        LARV
                        This is what happens.
                        • jeff hammondJ Offline
                          use thruPaint first to apply the texture.. in the case of your curved wall, use QuadMeshUV or maybe NaturalUV..
                          it looks like you've projected this one.
                          thrupaint will properly map the surface then when moving the texture as one, it is all handled properly..
                          anyway, my point is more along the lines of..
                          learn/use thrupaint for all of your more awkward texturing needs.
                            LARV
                            "use thruPaint first to apply the texture"
                            Yeah, I saw in the tutorial that the guy never used the paint bucket to apply the texture. It just seemed to happen. There´s no explanation how he did that. Could you tell me where to click to make that happen? Thanks.
                              LARV
                              OK, I made it work with pattern material like roofing. Great, very usefull!
                              I still need to be able to make a single image land correct, though.
                                LARV
                                Now I made it work on a sandbox mesh, much like in the tutorial. Will keep trying to place it correct on an extruded wall.
                                Thanks for all help!
                                • panixiaP Offline
                                  panixia
                                  are the faces all quad? if they are quad are they triangulated? did you checked for reversed faces? could be useful if you share the object or at least a monochrome view of the surface with hidden geometry turned on..
                                  • JQLJ Offline
                                    JQL
                                    It would also help if you could ask nicely.
                                    People here are helpful by nature but even so...
                                    www.casca.pt
                                    Visit us on facebook!
