    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 5.7k Views 9 Watching
    • Flippie123F
      Flippie123
      Hi Jeff, I'm not trying to compete with Zaha. I have been using sketchup since the very beginning. In the beginning I started to do some simple architecture using sketchup but now years later I'm doing some pretty advanced architecture designs using sketchup where I'm trying to reach the limits of the program.
      I'm very exited about sketchup2015 because the 64bit version makes much more possible.
      Off course I can use Rhino to do some modelling. But at the end my clients want to see a Sketchup model because for them a sketchup model is easy to read.
      @jeff hammond said:
      @flippie123 said:
      I did some experimenting with the pathcopy tool and some curved lines. I used 2 magnetic points here. But it will become really interesting if I can add 3,4 or 5 magnetic points.
      I'm just a user...not a developer, but I can assure everyone that we are using sketchup to make the most awesome architecture here in our office.
      don't you guys have a copy of rhino in your office?
      i'm pretty sure zaha used paneling tools to create this.. possibly in conjunction with a custom script..
      it's super powerful for various types of attractors etc..
      [attachment=0:ddwi3rqq]<!-- ia0 -->Screen Shot 2014-12-10 at 10.59.16 AM.png<!-- ia0 -->[/attachment:ddwi3rqq]
      @box said:
      On a side note, there is always Sketchy Physics for using Magnetism.
      But it's a magnetic thread so I had to do something.
      heh.. neat β˜€
      • jeff hammondJ
        my bad.. i suppose i read too literally when you posted her model saying 'i want to make this'
        here are a couple example DC files showing attractor type stuff in sketchup.. maybe some ideas will spring from them:
        created by sketchucation member TAEKLE
        • jeff hammondJ
          here's possibly the most basic dynamic component ever made πŸ˜„
          DC_pointer.skp
          it's a one liner:
          just use the regular Move tool to move it around and make copies (though doesn't seem to work with copy/array)?.. it will always point at the origin.
          (as is, you have to stay on the positive side of the red axis or it will point backwards)
          • Flippie123F
            Flippie123
            haha...yes it always point to the center line but it is not magnetic. I tried to use the sketchyphysics tool but it only works for Sketchup7. And it is not easy to use. πŸŽ‰
            • jeff hammondJ
              hmm.. it was meant as proof of concept.. the origin in this case is "magnetic"..
              copy a bunch of them around:
              then select them all and move them at once:
              with a less simple DC, you could make it the other way.. the objects stay put and you move the attractor around (though probably moving the the attractor via numerical input).
              • BoxB
                My model up there was done in 2015 32bit, the only version it doesn't work in at the moment is 2015 64bit. Make sure you are using the latest version.
                Yes it can be difficult to use, it isn't the most easily understood plugin and the documentation is limited.
                But mostly I don't think it would work for you as it doesn't really work for positioning stuff then placing it. It is more of an animation tool.
                • cottyC
                  cotty
                  @flippie123 said:
                  ... but it only works for Sketchup7. And it is not easy to use. πŸŽ‰
                  That's wrong...
                  http://sketchucation.com/pluginstore?pln=SketchyPhysics
                  my SketchUp gallery
                  • jeff hammondJ
                    here's a dynamic component which does the thing in the original post..
                    DC_Magnet.skp
                    to use it:
                    β€’ double-click the outer component (main) to enter it.. (there are two more components inside: box & attractor)
                    β€’ Move the attractor component with the move tool
                    β€’ exit the main component then right-click on it --> Dynamic Components-> Redraw.
                      driven
                      @jeff
                      that's really good...
                      • jeff hammondJ
                        @driven said:
                        @jeff
                        thanks.
                        a few more additions (right-click--> dynamic components -> component options)
                        β€’ pick the number of boxes (square array)
                        β€’ how many beers? (straightness of rows and columns waver)
                        DC_Magnet_Beer.skp
                        • jeff hammondJ
                          1024 boxes, a 12-pack, and change the shape of the box component
                          • Flippie123F
                            Flippie123
                            @Jeff
                            I just made this and gave it a twist. Very awesome! πŸŽ‰ πŸ‘
                            • jeff hammondJ
                              yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
                              • jeff hammondJ
                                sweet!
                                (i'm not sure how to use the code but the gif looks cool πŸ˜‰ πŸ‘ )
                                  driven
                                  @jeff hammond said:
                                  ...i'm not sure how to use the code ...
                                  just paste into 'Ruby Console' hit return, will run till end of session...
                                  it's only active when inside the DC so you can do other modelling...
                                  I can put it in a rbz with the DC if you want...
                                  • jeff hammondJ
                                    oh nice. i see now.
                                    it works along with the dynamic component i posted.. i didn't realize things like that were possible.
                                    but yeah, that's a lot better than manually triggering the redraw πŸ‘
                                      driven
                                      @jeff hammond said:
                                      ... i didn't realize things like that were possible.
                                      nor did I...
                                      I improved the script to only do one redraw after the move [was trigging twice]...
                                      there are probably other ways to do this, but it seams to work...
                                        driven
                                        updated working version...
                                        class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                                            def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                                              attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                                              moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                                              @count = 0 unless @count == 1
                                              update = attractor && moved
                                                if update
                                                  selection = Sketchup.active_model.selection[0].parent.instances[0]
                                                  @count = @count + 1
                                                  puts(" first click of " + tool_name.to_s ) if @count == 1
                                                  if @count == 2
                                                    puts(" second click of " + tool_name.to_s )
                                                    $dc_observers.get_latest_class.redraw_with_undo(selection)
                                                    @count = 0
                                         Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
                                          driven
                                          here's a fun bit of code...
                                          now it does what the OP asked...
                                          auto update, slows a bit over 64 items...
                                           look below...
                                          EDIT: changed back to original as my counter was failing
                                          BETTER CODE BELOW...
                                            Jim
                                            the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                                            You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                                            This file was made specifically for Jeff's DC Magnet Beer model.
                                            • 2 / 3
