    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 3.1k Views 9 Watching
    • jeff hammondJ Offline
      @flippie123 said:
      Hi Jeff, I'm not trying to compete with Zaha. I have been using sketchup since the very beginning. In the beginning I started to do some simple architecture using sketchup but now years later I'm doing some pretty advanced architecture designs using sketchup where I'm trying to reach the limits of the program.
      I'm very exited about sketchup2015 because the 64bit version makes much more possible.
      Off course I can use Rhino to do some modelling. But at the end my clients want to see a Sketchup model because for them a sketchup model is easy to read.
      my bad.. i suppose i read too literally when you posted her model saying 'i want to make this'
      here are a couple example DC files showing attractor type stuff in sketchup.. maybe some ideas will spring from them:
      created by sketchucation member TAEKLE
        here's possibly the most basic dynamic component ever made πŸ˜„
        DC_pointer.skp
        it's a one liner:
        just use the regular Move tool to move it around and make copies (though doesn't seem to work with copy/array)?.. it will always point at the origin.
        (as is, you have to stay on the positive side of the red axis or it will point backwards)
        • Flippie123F Offline
          Flippie123
          haha...yes it always point to the center line but it is not magnetic. I tried to use the sketchyphysics tool but it only works for Sketchup7. And it is not easy to use. πŸŽ‰
            hmm.. it was meant as proof of concept.. the origin in this case is "magnetic"..
            copy a bunch of them around:
            then select them all and move them at once:
            with a less simple DC, you could make it the other way.. the objects stay put and you move the attractor around (though probably moving the the attractor via numerical input).
            • BoxB Offline
              My model up there was done in 2015 32bit, the only version it doesn't work in at the moment is 2015 64bit. Make sure you are using the latest version.
              Yes it can be difficult to use, it isn't the most easily understood plugin and the documentation is limited.
              But mostly I don't think it would work for you as it doesn't really work for positioning stuff then placing it. It is more of an animation tool.
              • cottyC Offline
                cotty
                @flippie123 said:
                ... but it only works for Sketchup7. And it is not easy to use. πŸŽ‰
                That's wrong...
                http://sketchucation.com/pluginstore?pln=SketchyPhysics
                my SketchUp gallery
                  here's a dynamic component which does the thing in the original post..
                  DC_Magnet.skp
                  to use it:
                  β€’ double-click the outer component (main) to enter it.. (there are two more components inside: box & attractor)
                  β€’ Move the attractor component with the move tool
                  β€’ exit the main component then right-click on it --> Dynamic Components-> Redraw.
                    driven
                    @jeff
                    that's really good...
                      @driven said:
                      @jeff
                      thanks.
                      a few more additions (right-click--> dynamic components -> component options)
                      β€’ pick the number of boxes (square array)
                      β€’ how many beers? (straightness of rows and columns waver)
                      DC_Magnet_Beer.skp
                        1024 boxes, a 12-pack, and change the shape of the box component
                          Flippie123
                          @Jeff
                          I just made this and gave it a twist. Very awesome! πŸŽ‰ πŸ‘
                            yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
                              sweet!
                              (i'm not sure how to use the code but the gif looks cool πŸ˜‰ πŸ‘ )
                                driven
                                @jeff hammond said:
                                ...i'm not sure how to use the code ...
                                just paste into 'Ruby Console' hit return, will run till end of session...
                                it's only active when inside the DC so you can do other modelling...
                                I can put it in a rbz with the DC if you want...
                                  oh nice. i see now.
                                  it works along with the dynamic component i posted.. i didn't realize things like that were possible.
                                  but yeah, that's a lot better than manually triggering the redraw πŸ‘
                                    driven
                                    @jeff hammond said:
                                    ... i didn't realize things like that were possible.
                                    nor did I...
                                    I improved the script to only do one redraw after the move [was trigging twice]...
                                    there are probably other ways to do this, but it seams to work...
                                      driven
                                      updated working version...
                                      class JcB_MoveToolObserver < Sketchup;;ToolsObserver
                                          def onToolStateChanged(tools, tool_name, tool_id, tool_state)
                                            attractor = Sketchup.active_model.selection[0].definition.name == 'attractor'
                                            moved = tool_state.to_s == '0' && tool_name.to_s == 'MoveTool'
                                            @count = 0 unless @count == 1
                                            update = attractor && moved
                                              if update
                                                selection = Sketchup.active_model.selection[0].parent.instances[0]
                                                @count = @count + 1
                                                puts(" first click of " + tool_name.to_s ) if @count == 1
                                                if @count == 2
                                                  puts(" second click of " + tool_name.to_s )
                                                  $dc_observers.get_latest_class.redraw_with_undo(selection)
                                                  @count = 0
                                       Sketchup.active_model.tools.add_observer(JcB_MoveToolObserver.new) if not defined? JcB_MoveToolObserver
                                        driven
                                        here's a fun bit of code...
                                        now it does what the OP asked...
                                        auto update, slows a bit over 64 items...
                                         look below...
                                        EDIT: changed back to original as my counter was failing
                                        BETTER CODE BELOW...
                                          Jim
                                          the other thing I was wondering if arrow keys can be used to move the dc's 'attractor'
                                          You need a Tool to get the key-presses, then read-update-write the position values depending on which key was pressed, then redraw the DC.
                                          This file was made specifically for Jeff's DC Magnet Beer model.
                                            driven
                                            cheers Jim,
                                            that works and is much cleaner than i was attempting...
                                            what other thing can we do with ruby to manipulate DC's?
                                            I'll see if I can turn this into a pick point version...
                                            • 2 / 3
