    Wavy bench in sketchup
    13 Posts 7 Posters 1.4k Views 7 Watching
      I'd use a texture to save time
      • JQLJ Offline
        JQL
        Or try every command on fredo scale.
        If you want to make it interactively though it's better to use other software... Blender is free...
        www.casca.pt
        Visit us on facebook!
        • BoxB Offline
          So many ways to make it, component stringer, path copy, slicer, grow, just to name a few. It's an awfully big question and not a lot of specifics from your image.
          • john2J Offline
            john2
            Oh sorry! Advanced search is written in small font, I couldn't see it. 😳
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
            • BoxB Offline
              I wasn't saying you need to search more, although that never hurts, I was saying the image doesn't give a full idea of what you want to do. So the question is a bit vague.
              Knowing a bit more about what you are trying to do and where you might be having problems would help when giving an answer as how best to go about it.
              • pbacotP Offline
                I'd start with a rectangular snake object made with follow me or some other method. then use scaling lines on selected parts to raise and widen some areas. the best way to scale might be Vertex tools so you can graduate or taper the amount of scaling around a point.
                another approach is draw four different curves varied before hand then skin them with Curviloft or Extrusion tools.
                There may be more to what this bench entails, but that's for the impression I get from the photo. Then texture for the lines, using ThruPaint.
                • BoxB Offline
                  Here's a simple version.
                  A straight array of blocks cut with a curve then bent using ShapeBender.
                  • jeff hammondJ Offline
                    ^ πŸ‘
                    • john2J Offline
                      john2
                      thanks πŸ‘ πŸ˜„ . And how to give a vertical incline as seen in the photo?
                      • BoxB Offline
                        That's why I asked about the photo, I couldn't tell if they were leaning over or if it was the angle of the photo.
                        You could simply array the blocks at an angle and cut them off top and bottom. Or perhaps they are splayed so you could rescale the bottoms of the blocks etc etc etc or maybe you need to everything to stay the same size and not wedge around the bend......
                        Without a specific end result it's impossible to give you one answer.
                        • 3dita3 Offline
                          3dita
                          Try skewing the vertical lines after cutting and before shape-bending (use Fredo scale πŸ˜‰
                          3dita - Digital Visual Motion
                          • john2J Offline
                            john2
                            Oh yeah! Thanks, So many plugins I have but not the wisdom to use them . πŸ˜†
