    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
      As Box asked, are you just trying to cut the sheet metal at the angle of the roof? Tools on Surface is an excellent plugin but it would be easier to cut the tin with a cutting plane using the native Intersect Faces. Let SketchUp draw the edge and get into all the curves.
      • fredo6F Offline
        NEW RELEASE: Tools on Surface 2.1a- 19 Oct 14
        This release is required for the support of usernames with non-ascii characters in Sketchup 2014
        You will need to migrate to LibFredo6 6.3 or higher
        Please see main post for download
          chijuiwang
          Thanks Fredo6! very useful plugin!
          • E Offline
            Extractor
            does anyone else have the same issue? ToS works perfectly with SU 2014. In SU 2015 64 bit the faces created on a 3D shape are not separated. It is mysterious: when I export for example a cylinder from SU 2014 to SU 2015 sometimes ToS works properly with SU 2015! Maybe the problem is that both versions of Sketchup are installed in parallel?
            • E Offline
              Extractor
              I am wrong. The problem is not Sketchup 2015. ToS doesn`t work correctly when I use a template with meters as units.
              • BoxB Offline
                It begs a couple of questions.
                How many segments are you working with and what scale is your model?
                If you are working at a small scale and lots of segments SU can have problems forming the edges.
                Also you may have the precision setting different in your metric version.
                Here is a small example.
                The larger circle was draw while the cylinder was scaled down and you can see how it distorts the surface. Scale up and the small circle can even cope with the distortion.
                • jgbJ Offline
                  jgb
                  The same thing happens with intersect, when some of the intersections cause very short lines. Gaps happen. Perhaps ToS uses the same/similar methodology to form the line on the surface.
                  Try adjusting the number of segments forming the curve and see if that helps. πŸ’­
                  jgb
                  • fredo6F Offline
                    It is true that the calculation is not perfect when by chance very small edge are created.
                    One possibility you have is to active the Editor On Surface and join the missing segments
                    • E Offline
                      Extractor
                      Thanks for the tips. I figured out that it was a problem with this particular template (circle: radius: 1m, segments 24: no idea why this problem occurred there). I deleted it and with a new one it works.
                      • H Offline
                        hanaehab
                        Hey, I'm trying to draw arches onto a cylindrical room like in this video ( https://www.youtube.com/watch?v=jDqycuMUYvA ) however on using the joint push/pull tool to clear the arch out, it won't let me push the shape to the inner side of the wall so I'm only able to delete the outside arch. Sketchup thinks I'm trying to delete the rest of the cylinder when I try deleting what should be the inner arch. Also the drawing arc on curved surfaces tool keeps forming rings around my cylindrical room, not normal arcs! Help me please
                          murmurbalsita
                          Hi, may I just ask which version should I use. I have sketchup 2015 right now. THanks a lot πŸ˜„
                            Use the version offered in the Plugin Store. It is also linked to in the first post of this thread. Pay attention to the details and make sure you also install the LibFredo files.
                              blackdogsketch
                              Maybe I'm missing something, but for a tool that's supposed to stay On Surface, this seems to have a tendency to pop onto the z-axis constantly.
                              I sue this tool to trace jpegs of site maps, and trace contour lines, for example. the plane I'm working on is solid, with nothing underneath. The vast majority of the linework I want to create is non-orthogonal (the contours)...but the tool is constantly snapping to x or y axis...which is merely annoying... but all of a sudden it will pop way out on the z axis and I'll discover it maybe 6-12 segments after.
                              Is there any way to turn off orthogonal and produce ALL linework on a plane?
                              Also, it's sort of annoying that every time the line command is interrupted, the tool reverts to dashed line and I have to manually hit the icon for line to get it back to solid again.
                              It's still a useful tool, and maybe I'm missing some user parameters. All constructive crit...thanks for all your efforts for us! πŸ˜„
                                You don't need Tools on Surface to trace site plans. This extension was intended for drawing on 3d surfaces which the native tools won't do easily. For tracing a JPG or a site plan, though, the native tools will work just fine. If you feel the need, set the camera to Parallel Projection and select the Top view to look down on the image. I frequently trace images and leave the camera in Perspective mode.
                                  There must be a place where the edges you drew across the surface don't touch the curved surface. Can you share that part of your model , at least?
                                  • fredo6F Offline
                                    For the start and end point, with the FreeHand tool, make sure you activate the inferencing so that they are on the border edges.
                                    • jgbJ Offline
                                      jgb
                                      Here's how I transfer flat shapes onto a curved surface. I do this on my airplane designs to place a very strict outline onto a curved fairing surface. It is far more accurate to draw a curve on a flat face than try to draw that curve on a curve, Fredo Tools on Surface notwithstanding.
                                      The following set of screen caps should explain it. Ask me if you need more info.
                                      The 2 walls, each grouped.
                                      Copy the colored wall near the curved wall
                                      Edit, Push/Pull every second segment through the curved wall.
                                      Scale the width to fit the curved wall.
                                      Edit curved wall and intersect with model.  This transfers the colored curves.
                                      Delete the copy of the extruded flat wall.
                                      Edit the curved wall and color each segment accordingly
                                      Hope that helps.
                                      jgb
                                        stulutions
                                        Fredo, How do I activate inferencing on the freehand tool? I only see it as a "without inferencing" option.
                                        DAve R - How do i share that part of my model? It's far from top secret or elaborate, as I am a complete novice, so I'm not concerned with sharing the whole original file if that will help. But in the future that might be handy to know, how to share just a portion of the file?
                                        jgb - I just saw your reply, so am literally just about to read through it.
                                        THanks guys!
                                          stulutions
                                          Hello,
                                          I signed up just to get this plugin (which is my first!). Thank you.
                                          Pretty novice user.
                                          I have a contoured surface that I wish to break up into segments of freehand divisions so that I can colour them individually. I can do it on flat surfaces quite easily but have no idea how to do it on this curved surface.
                                          Hopefully my sequence of attached images will make it clear what I am trying to accomplish.
                                          Thanks for any assistance. It is appreciated!
                                          s
                                          this is a flat wall that shows how i would like the curved wall to be editable
                                          ![this is my "finished" wall](/uploads/imported_attachments/tpND_2.png "this is my "finished" wall")
                                          with the curved wall in front of it
                                          using the plugin I was able to freehand the line in i wanted
                                          ![but when i go to select just the bottom or top "chunk" of what i would like to think is my new divisions, it selects the entire face so i can't colour them individually](/uploads/imported_attachments/8U1c_5.png "but when i go to select just the bottom or top "chunk" of what i would like to think is my new divisions, it selects the entire face so i can't colour them individually")
                                            To share just part of the file, you could select that part and copy it to the clipboard (Edit>Copy) and then open a fresh SketchUp session and use Edit>Paste or better, Edit>Paste in place. Then save that file.
                                            Or maybe in this case you can just upload the whole thing.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 31
                                            • 32
                                            • 25 / 32
