    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • BoxB
      It's actually easier to go install the plugin store and auto install if from there.
      http://sketchucation.com/resources/plugin-store-download
        rythm
        I am trying to draw a line on a curved surface using Tools on Surface plugin.
        My question is: Once I draw the line does the process take a long time? I now am watching my Mac ball spin for 45 minutes.
        The line is only 37" long. See the screen shot below.
        Should I let it continue to run?
        Thanks,
        The line is drawn parallel to the angle. The end of the line is the red x in the screenshot
          rythm
          I loaded this plugin directly form the Plugin Store and it installed successfully I then restarted SU and the tool was there immediately like it was supposed to.
          After looking at the curve in my screenshot, Should this curve take an hour to process. I have never used the tool before but I cannot believe this curve could take that long to process.
          Any thoughts would be greatly appreciated!
          • BoxB
            The simple answer is , no it shouldn't. But then we don't really know what it is working on.
            Are you just trying to cut the metal panel along the diagonal line?
              rythm
              Thanks for reply.
              Actually I gave up a while ago and started working on something else. I will go back to it and run a couple of tests and try again.
              Mainly I was looking for the short answer to thank you.
              -R
                As Box asked, are you just trying to cut the sheet metal at the angle of the roof? Tools on Surface is an excellent plugin but it would be easier to cut the tin with a cutting plane using the native Intersect Faces. Let SketchUp draw the edge and get into all the curves.
                • fredo6F
                  NEW RELEASE: Tools on Surface 2.1a- 19 Oct 14
                  This release is required for the support of usernames with non-ascii characters in Sketchup 2014
                  You will need to migrate to LibFredo6 6.3 or higher
                  Please see main post for download
                  • C
                    chijuiwang
                    Thanks Fredo6! very useful plugin!
                    • E
                      Extractor
                      does anyone else have the same issue? ToS works perfectly with SU 2014. In SU 2015 64 bit the faces created on a 3D shape are not separated. It is mysterious: when I export for example a cylinder from SU 2014 to SU 2015 sometimes ToS works properly with SU 2015! Maybe the problem is that both versions of Sketchup are installed in parallel?
                      • E
                        Extractor
                        I am wrong. The problem is not Sketchup 2015. ToS doesn`t work correctly when I use a template with meters as units.
                        • BoxB
                          It begs a couple of questions.
                          How many segments are you working with and what scale is your model?
                          If you are working at a small scale and lots of segments SU can have problems forming the edges.
                          Also you may have the precision setting different in your metric version.
                          Here is a small example.
                          The larger circle was draw while the cylinder was scaled down and you can see how it distorts the surface. Scale up and the small circle can even cope with the distortion.
                          • jgbJ
                            jgb
                            The same thing happens with intersect, when some of the intersections cause very short lines. Gaps happen. Perhaps ToS uses the same/similar methodology to form the line on the surface.
                            Try adjusting the number of segments forming the curve and see if that helps. πŸ’­
                            jgb
                            • fredo6F
                              It is true that the calculation is not perfect when by chance very small edge are created.
                              One possibility you have is to active the Editor On Surface and join the missing segments
                              • E
                                Extractor
                                Thanks for the tips. I figured out that it was a problem with this particular template (circle: radius: 1m, segments 24: no idea why this problem occurred there). I deleted it and with a new one it works.
                                • H
                                  hanaehab
                                  Hey, I'm trying to draw arches onto a cylindrical room like in this video ( https://www.youtube.com/watch?v=jDqycuMUYvA ) however on using the joint push/pull tool to clear the arch out, it won't let me push the shape to the inner side of the wall so I'm only able to delete the outside arch. Sketchup thinks I'm trying to delete the rest of the cylinder when I try deleting what should be the inner arch. Also the drawing arc on curved surfaces tool keeps forming rings around my cylindrical room, not normal arcs! Help me please
                                    murmurbalsita
                                    Hi, may I just ask which version should I use. I have sketchup 2015 right now. THanks a lot πŸ˜„
                                      Use the version offered in the Plugin Store. It is also linked to in the first post of this thread. Pay attention to the details and make sure you also install the LibFredo files.
                                      • B
                                        blackdogsketch
                                        Maybe I'm missing something, but for a tool that's supposed to stay On Surface, this seems to have a tendency to pop onto the z-axis constantly.
                                        I sue this tool to trace jpegs of site maps, and trace contour lines, for example. the plane I'm working on is solid, with nothing underneath. The vast majority of the linework I want to create is non-orthogonal (the contours)...but the tool is constantly snapping to x or y axis...which is merely annoying... but all of a sudden it will pop way out on the z axis and I'll discover it maybe 6-12 segments after.
                                        Is there any way to turn off orthogonal and produce ALL linework on a plane?
                                        Also, it's sort of annoying that every time the line command is interrupted, the tool reverts to dashed line and I have to manually hit the icon for line to get it back to solid again.
                                        It's still a useful tool, and maybe I'm missing some user parameters. All constructive crit...thanks for all your efforts for us! πŸ˜„
                                          You don't need Tools on Surface to trace site plans. This extension was intended for drawing on 3d surfaces which the native tools won't do easily. For tracing a JPG or a site plan, though, the native tools will work just fine. If you feel the need, set the camera to Parallel Projection and select the Top view to look down on the image. I frequently trace images and leave the camera in Perspective mode.
                                            There must be a place where the edges you drew across the surface don't touch the curved surface. Can you share that part of your model , at least?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 31
                                            • 32
                                            • 25 / 32
